Gear ratios - Dodge Challenger Forum: Challenger & SRT8 Forums
Old 07-09-2010, 06:33 AM
Gear ratios
OK for those in the know I have a few questions ..
auto has 373 rearend gearing & the Manual has 392 . Why the difference ?
Also I have a manual Rt, 20 in wheels 392 gears .. If I was to go to say 18 or 17 in rims would this make the car rev higher & or have a positive effect on 1/4 mi speeds ??
Old 07-09-2010, 06:44 AM
lukester's Avatar
it's not the wheel size but the overall diameter of your rear tires which will reduce your overall ratio.
just get rear tires with a smaller diameter and you'll reduce the overall ratio.
09 Challenger SRT8 6speed
KW Stage 2, Hotchkis Sways, Front & rear Strut Bars, Catch Can, MBRP, Vortech V3, Hurst Shifter, Magnaflow Catted Mids, 8-Piston Brembos, OZ Wheels (front 10x20, rear 11x20) w 285/35 Toyo R888 all around, Pedders Bushings, Custom Oil Cooler, and much more...
see some of my "keep on rockin" Challenger videos:
http://www.youtube.com/user/lukecustoms
Old 07-09-2010, 09:09 AM
B KIRK's Avatar
All autos have 3:06 gears.
Manual R/T with 18" wheels get the 3:73.
Manual R/T with 20" get 3:91.
All SRT manuals have 3:91.
The rev limiter won't change.
Smaller diameter tires would give a lower final drive ratio that would help in the 1/4 mile time.
Brad
2010 Challenger R/T Classic, Auto, MagnaCharger TVS2300 Supercharger, Zex Nitrous Kit, Arrington 90mm Billet TB, JBA Shorties/Catted Mids, Corsa Exhaust, 3:91 Getrag Rear, PP NAG1 Stage II Valve Body, Hotchkis Front & Rear Sways, Diablo Predator, BT Catch Can, Hurst Shifter, Nitto 420's, LockPick, More!!! Tune By OST Mike 11.1438 @ 123.63
Old 07-09-2010, 10:12 AM
The 20" stock tire size is .5 taller
(90.1" circumference / 28.7" diameter / 703 revs/mile)
than the 18" size
(88.5" circumference / 28.2" diameter / 716 revs/mile)
so comparing the stock tire sizes, the 3.92 gear offsets the loss of effective ratio with the taller 20" tire, so it works out the same as the 3.73 gearing with the shorter 18" tire...
You end up with the same overall ratio - it was done to keep the speedo and rpm/mph the same with the 6-speed setup.
The 3.06 & automatic is used whether the car is equipped with 18" or 20" wheel / tire setup. Its likely MDS (on the 5.7 R/T) offsets the change in effective ratio, so Chrysler didn't bother with different gearing on the automatic setup.
Old 07-10-2010, 06:48 AM
OK
Thanks guys certainly clears things up ..
Imagine putting a 15 in rim w/ 255 x 60 tires .. Certainly would reduce the gear ratio .. But it would look hideous given the enormous wheel wells these cars have .. I guess the only way to change the gear ratio is by actually changing the gears .. ( makes sense )
doing that this fall to my 66 GTO .. Guy i bought it from 10 yrs ago had 3.08s in there .. after restoration ( just completed & broke ) going to go with 3.73 .. Ought to give it some snap huh ?
Had 3.93 gears in my 72 Nova SS when I was a kid .. That thing use to really go ...
Old 07-10-2010, 01:53 PM
At the track, I often see the LX guys (Magnums and Chargers) running 18's on the rear (esp if they have the SRTs which get 20" wheels std.) to get more lower final drive since they may have 3.06 or even 2.81 diffs, depending on the model year...
I'll be that Nova's engine with the old 1:1 top gear (auto or stick) will probably be spinning somewhere between 4 - 4.5K rpm at highway speeds!
Great for the track, but horrible for mileage and just the engine noise trying to drive it on the street. Some folks even went with lower gearing (4.56 or more), but at that point is just a track toy after that - not usable for daily driving.
Old 07-26-2010, 02:14 PM
dmwphoto's Avatar
Feedback Score: 4 reviews
does anyone know where to find the transmission (6 sp) gear ratios? Are all Tremec 6060 trannys the same regardless of make car they are put in?
Old 07-26-2010, 02:26 PM
Photos: (1)
Fwiw, the torque multiplication effect in the fluid coupling of the automatic is essentially like a 1.25-ish gear reduction (varies according to engine load). So that 3.06 axle ratio is effectively like a 3.825, in conjunction with the automatic transmission properties. 1.25:1 being conservative, the effective ratio could end up even shorter than that.
Now, if the transmission activates lock-up clutch mode, then the effective ratios and axle ratio work as you expect they would (at a constant cruise on a city street or the hwy). I don't think it typically enters this mode if you are racing the thing, though.
Old 07-26-2010, 02:54 PM
rubbel's Avatar
The gear ratios on the 2009 Dodge Challenger are:
1st: 2.97
2nd: 2.10
3rd: 1.46
4th: 1.00
5th: 0.74
6th: 0.50
Tuned by Tim Barth@Mr. Norm's
Built with LOVE
Old 07-26-2010, 03:04 PM
WyGoSlw's Avatar
You may also want to keep in mind when you mess with the tires sizes for the sake of changing gear ratios, you also mess with speedometer accuracy and in turn actual mileage on the odometer in the long haul. Granted it's not at all bad when you raise the GR but you lower it you're actually piling on more than the actual miles traveled.
-Thomas Jefferson
Maggie, the other woman.. ^^^
Magnuson SC - Mopar Coilovers - Billet Stuff - Homegrown CAI - CDT Audio upgrade - Misc Other Stuff
How to use Autostick No30fan General Challenger Discussion 11 03-18-2013 12:26 AM
Is the A5 R/T a bad investment omen omega General Challenger Discussion 33 09-28-2012 09:41 AM
Stock gear ratios Chefalan23 Dodge Challenger R/T Specific 6 07-16-2012 05:12 PM
In gear, lots of shifter movement... Normal? grantoser Bolt On's 7 07-02-2012 07:46 AM
Second gear worthless? Rumblefish50 Dodge Challenger R/T Specific 16 06-24-2012 08:40 AM
