Originally Posted by Toad10
Well, Four months later back with the same problem. Started again about a week ago. let it go till it go bad again then called my chysler guy back and had him re open my case. Took it back to the dealer and they can't replicate it. Have to go tomorrow to test drive with the tech again. This is getting old real quick.
I'm not saying that this is your problem, but I have 2 points:
#1 My 2010 had ZERO power steering fluid when I heard it making noise. The steering was bad. It was leaking from a seal down onto the tierod
#2 My friend's jeep made the noise you described at 3000miles. On HIS, it was "bent" suspension components, which when braking or turning one direction would lower the driveshaft enough to grind on his exhaust.
I doubt this is your issue, but at least its something else to check.
