» Sponsors
» Sponsors
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Dodge Challenger Forum > General Challenger Discussion
Old 01-20-2010, 09:26 PM
Hack/Workaround to play myGig in album order and show artist name
With help from some folks here I found that you can play songs in album order in myGig when you select album if you have software version RER2.043. However this lists and sorts your music in alphabetical order by album name, not artist name. Albums from the same artist get scattered all over the place. The problem I've been running into is that as I upload more and more music on here it's just unmanageable. The human brain tends to think artist name first, then album. It's hard to find and remember album names of like thousands of artists you might have on the drive.
I've been playing around with this and have found a way to get myGig to display the artist name and album name together, and also play songs in the correct album order as well. This may have been discussed or figured out before, but I didn't see anything in my searches on here so I wanted to help if I could. This has been driving me insane. I hope that Harmon Becker will allow albums to play in the correct order when artist name is selected in a future release of the software, but I can't wait for that to happen, and it may never happen.
Here's how to do it. It involves updating the Album Name tag of your mp3's using a tag editor. It's actually very easy, and most people that have this volume of MP3's probably already have a tag editor anyways. I use MP3Tag which is a great and free tag editor. It can be downloaded at: (Mp3tag - the universal Tag Editor (ID3v2, MP4, OGG, FLAC, ...))
1) Follow the normal steps to copy your albums to your USB stick using the suggested folder naming method from the manual. I typically put about 5-8 albums on the USB stick at a time.
NOTE: I typically create a folder for each album using the naming standard of "Artist Name - Album Name' for each folder. For example I would create a folder called "System of a Down - Hypnotize" and copy my files to it. If you have multiple albums from the same artist on one USB stick you'll need a separate folder for each album at the root level of the USB stick. I think that is how the manual says to do it was well.
2) Open your tag editor and open the folder on your USB stick that you want to update. Note that you will want to open the folder that is on your USB drive, not the folder where your original mp3 files came from. You want to make changes to ONLY the MP3 files on your USB stick, not your original files unless you want to update the tags on your original files also.
3) Change the tag for "Album" to now include Artist Name and Album Name in the format "Artist Name - Album Name". The screen shot below shows me editing this tag and what the tag looks like before and after the change. Note that your Mp3 Tag Editor should have a batch tag rename or search and replace function so that you don't have to rename these manually one by one. In MP3Tag this is done using the Quick Action replace, then selecting Album tag name and telling it what to replace.
Before Changes to "Album" Tag Name
During Changes to "Album" Tag Name
After Changes to "Album" Tag Name. All Album Tags now include Artist Name - Album Name
3) Upload your music to myGig using your USB drive/stick like your normally do.
4) Browse music and select Album. You should now see the music you just uploaded displaying the Artist Name - Album Name in alphabetical order. When you click on the selection, it maintains the original track order of the album. It should look like this. You can now search by Artist name while you're in album mode, find the artist you're looking for and select the album and it will play in original track order.
Albums shown in order of Artist Name
You can see here that the correct track order is still preserved when I select the album
That's it. The steps are easy but it does take some extra time. Does it suck to have to do this just to get songs to both show Artist Name and play in alphabetical order based on Artist Name? Yes completely sucks and is totally ridiculous. For me it's worth it b/c the music I'm putting on here will pretty much stay on here for good and I won't have to do this again. Most of my main music collection will go on here and I use an iPod for the stuff I download and change more.
Anyways I hope this helps anyone else really wanting your music to show up like this. This should work well for anyone still uploading their music or ready to revamp things. If you already have a bunch of music uploaded, probably not worth the effort to have to delete and re-upload just to get things to show up like this. The other caveat is that if you actually do want to sort or search specifically by album name, that funcitionality is lost with this hack. I should mention the same logic used here could probably also be applied to monkey around with the "title" or "track number" tags to force myGig to play songs in the correct order when in Artist mode. I'm going to play with that next but I have a feeling tags would have to be modified one at a time versus being able to use batch search and replace which is much, much faster.
I called Harmon Becker today and will keep calling until I can get someone to tell me if they're planning to fix this in a later software release. Since they are supposedly using the same software and systems in the 2010's, I'm hopeful they will resolve this since they will need to continue supporting it. Let me know if you run into any issues or have any other ideas to make this work better.
09 Challenger SRT8, Bright Silver Metallic, auto, loaded
65 FFR Shelby Cobra, 5 speed, IRS
67 Mustang Fastback GTA S-Code (Restoration underway)
Old 01-21-2010, 09:56 PM
BryanM's Avatar
I just access the library as playlists - each album shows up as a playlist, all tracks in the same order as on the CD. I don't do anything except pop the CD in and copy it normally.
Bryan
Old 01-21-2010, 10:18 PM
rmfootball69's Avatar
Send a message via AIM to rmfootball69
Yeah Bryan thats what I did too. I would either copy from cd, data cd ( which would then make the whole cd a playlist, kind of annoying when you've got hundreds of songs on one cd) or I used a thumb drive once or twice I think. This time around I'm gonna see how much of my 1 tb external hard drive itl read.
Old 01-22-2010, 06:40 AM
caj's Avatar
caj caj is online now
Subscribe to this thread. Good info guys!!!
Mods: Hood Struts, Stealth Mud Flaps, R/T badge on Spoiler, Challenger Script on Fenders, Locking Gas Cap, Functional (partially lol) Hood Scoop, and (of course) Cubs License Plate Frame.
Maybe the playlists work in the correct song order when ripping directly from Cd's to myGIG, but the playlists aren't in the correct album order when I upload from a USB drive. I don't want to think about how long it would take to rip the thousands of CDs to myGIG. I know it took me weeks on my computer with faster hardware etc when I converted everything a few years ago. If I'm missing something and the playlists do work correctly with USB uploads please let me know.
I wonder how myGIG determines the song order of the discs it rips. Does it use the file name it creates after ripping the disc to determine the song order? That would be my guess. If so the answer for USB uploads may just be to do a batch rename of mp3 files before uploading them on the USB stick using that same naming standard. The upside of going that route would be that all the original MP3 tags would remain in tact, so if Harman Becker puts a fix out there I wouldn't have to re-upload everything with the original tags.
Old 01-22-2010, 07:30 AM
caj's Avatar
I've got mygig and I really wish I just had a 6 CD Changer. This mygig stuff is too much work and it runs down the cars battery.
Old 01-22-2010, 07:33 AM
Photos: (10)
Please explain, how does it run down the battery......I have no problems with my battery and MYGIG.
Old 01-22-2010, 08:18 AM
subscribed.
2009 Silver R/T
From out of the past come the thundering hoofbeats of the great horse Silver!
Old 01-22-2010, 10:22 AM
caj's Avatar
I think I've been spending too much time downloading music and trying to figure this thing out without starting up and charging the battery.
Old 01-22-2010, 10:27 AM
subscribe
1964 1/2 Plymouth Barracuda
(To be finished some day)
1965 Plymouth Baracuda (Donor)
2000 Sportster Sport (Canary Yellow)
2001 Chrysler PT Cruiser
2005 Dodge Magnum
2010 PCP Challenger SRT8 6 spd
(coming soon (not soon enough))
vB code is On
