Hemi "tick"- Cause & Cure - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 65 (permalink) Old 01-19-2010, 12:58 PM Thread Starter
Cuda340's Avatar
On the chargerforums web site there was a interesting discussion about what causes the "ticking' sound in modern Hemi engines and how it can be quieted. Here is the post:
Many here know what we do to stop the Hemi Tick, but we figured that since there are so many new faces here, they may not have heard that you don't have to have it in your engines.
We have discussed previously that there are 3 culprits that cause the "Hemi Ticking" that is heard in idle and just off idle.
1) Intake and exhaust valves do not have any kind of cushioning from the fuel. Fuel usto have higher amounts of sulfur and tetra ethyl or tetra methyl lead to lubricate and cushion intake and exhaust valves in the old days. When EPA decided to go to unleaded fuels, hardened valves and seats were produced trying to deal with the lack of lubricant. This was adequate at best, but did allow engines to live longer than if they had soft valves and seats. However, when they went to ethyl alcohol, that all changed. Alcohol absorbs moisture and strips lubricity. That was bad enough, but when they reduced the sulfur content from 130 parts per million (ppm) to 30 ppm, it really produced a perfect storm. Both the intake and exhaust valves are now hitting against the valve seats with no cushioning at all. This causes wear, and then of course....noise or TICK.
2) Fuel injectors depend on at least 70 ppm of sulfur to stay alive. When EPA went to the ethyl alcohol and less than 30 ppm, they have no cushioning allowing them to click or tick also while building up gum and varnish. This restricts the flow of fuel and turns the vaporized spray pattern into an atomized spray pattern. Atomized fuel doesn't burn as well, and helps wash down into the cylinders and wipes out the detergents and dispersants much faster. This is the second part of the Hemi Tick.
3) Because the Hemi has a very short skirt and thin rings with virtually no land area, the piston wants to rock in the bores. This is another reason for the moly piston skirt coatings. It is designed to cushion the short skirt. The problem is that as miles rack up, the moly is worn off and a louder engine or tapping noise begins to occur. This is the third part of the Hemi Tick. This part actually contributes to more aluminum in your oil analysis. An oil analysis is always important to do on any engine you want to take care of as a baseline, and then every 3rd oil change, do one just to be sure nothing is leaking or causing problems.
BND Automotive has addressed these issues by:
1) ACES IV Gasoline Formula introduced into your gasoline to replace the lack of lubricity. However, this is not just for the valves, but also for the injectors and the in tank fuel pump. The pump is cooled by the gasoline, but it needs plentiful or copious lubricity as well. ACES IV addresses these three issues to produce a protected, lubricated, and more powerful engine with a great quieting effect stopping 2 parts of the Hemi Tick. This is the injector and the valve ticking.
2) QuantumBlue Custom Blended Lubricants are designed for the different aspects that make up not just the piston slap by adding the right ratios of additives, but also producing much better filmstrength that is necessary to protect the Moly coating that is put on from the factory. This works great not just for the 5.7 and 6.1, but also the 2.7 and 3.5L 4 valve Polyspheric Hemi V6 engines as well. Taking all these into consideration..... cast iron block or aluminum block, cast heads or aluminum heads, carbureted or injected, what RPMs and what mods are added to the car along with what temperatures and conditions the car will encounter matter. Salt from the sea shore is different than what comes from snow removal. Silicates from desert conditions and extra high temperatures need to be addressed as well. Really cold temperatures in Canada and British Columbia also need to be adjusted for. Upper cylinder rocker assemblies are important to consider whether single rocker (SOHC) V6 or double rocker shaft (DOHC) V6. The 5.7 and 6.1 also have duel rocker shafts and are a weak spot for scuffing. Dads SRT even showed on a billet steel cam that the typical Mobil 1 0w40 is NOT protecting the cam. The rollers need to spin on the cam, and not slide. Without proper lubricity, correct filmstrength, and frictional capabilities of the lubricant, engine will damage and wear will occur!
These two in combination will address the Hemi Tick noises which will increase the life of your engine and keep your peace of mind.
Many here have taken advantage of these technologies and are now thinking about other things other than ticking engines since they don't have them any longer.
Regards,
Brian
BND Automotive LLC
Cuda340 is offline
iamawild1 (01-02-2015)
post #2 of 65 (permalink) Old 01-19-2010, 01:05 PM
bluesrt's Avatar
---------great info
2010 srt8 b5 blue auto hard loaded-
bluesrt is offline
post #3 of 65 (permalink) Old 01-19-2010, 01:09 PM
Mark052's Avatar
Feedback Score: 3 reviews
Thanks for the info Cuda340
Has anyone used these products to see if they work as good as they claim? It sounds promising, if these products work as stated. However, the guy who originally posted that is apparently from the BND company so I'm being a little cautious.
2009 DWB R/T Auto and 2010 Detonator Yellow Classic w/6 speed manual.....gone but not forgotton.
Mark052 is offline
post #4 of 65 (permalink) Old 01-19-2010, 01:17 PM Thread Starter
Cuda340's Avatar
I'd be a little skeptical, too. I have no idea if his products perform as claimed. Just thought his discussion about the "ticking" was very informative. I might bring this up at the next SRT Engineers Chat Session.
Cuda340 is offline
post #5 of 65 (permalink) Old 01-19-2010, 02:01 PM
Yes, very interesting info on the "ticking" phenomenon! It does sound very scary about the whole ethanol + low sulphur issue. If our engines are slowly getting damaged out of all of this environmental fervor, that really makes me angry.
I wonder if that special cylinder head/valvetrain lubricant oil that you add to your gasoline could help?...you know, that "mystery oil" stuff?
I may not use the full 370 hp that often, but bolting out of the gate with a ready 170 hp and the roar of a v8 definitely puts a smile on my face day after day, mile after mile. It's not such a big number, rather how soon that number emerges.
v8 is #winning
v8 is America
v8 4ever...
randycat99 is offline
post #6 of 65 (permalink) Old 01-19-2010, 03:02 PM
Speed Racer's Avatar
I was over on the Arrington Engines forum and a lot of people feel that the pushrods are the culprit. They are supposedly a hair short in the exhaust side. Owners there have changed their pushrods out and used 6.1 push rods with success.
Makes sense from what I read over there.
Speed Racer is offline
post #7 of 65 (permalink) Old 01-19-2010, 03:33 PM
pwr2tow's Avatar
MMO has worked for years and it's still non-ULS complient.
09 R/T
pwr2tow is offline
post #8 of 65 (permalink) Old 01-19-2010, 03:55 PM
It's in the red bottle, right? I didn't think I should need it on a brand new car, but seems like I should go get a bottle ASAP...
post #9 of 65 (permalink) Old 01-19-2010, 04:26 PM
I'm REAL skeptical considering the guy with all the "insight" just happens to sell the products he's hyping up.
When the SRT8 engineers rec. a specific product or line of products I'll believe it.
DETOUR is offline
post #10 of 65 (permalink) Old 01-19-2010, 05:38 PM
Yes, that is always a red flag.
It's kind of something just left open for that sort of exploitation, admittedly. I mean- does anyone really know or understand the nature of the "hemi tick"? I've read all sorts of explanations. Does Dodge/Chrysler really stand behind the line that this phenomenon is utterly, entirely normal, harmless, and inherently cannot be "fixed" because nothing is broken?
My point is, I really have no idea. My impression is that there is no single, widely-accepted explanation. This gap in information is only a natural point for various "snake oil" solutions to proliferate, imo.
Hemi and Header Orange Challengers olskooljr Picture/Media/Art Post 122 09-07-2014 08:02 PM
Is My SXT Looked Down Upon??? challenger-dan General Challenger Discussion 343 04-14-2013 02:36 PM
What's Up With 392 Hemi Owners In Philly Area??? 6SPD4ME North-East 9 08-14-2012 04:58 PM
2010 Hemi Orange & Furious Fuchsia joined by New Hemi 6.1 LETSJET General Challenger Discussion 6 07-17-2012 12:44 PM
