Homelink programming issue - Dodge Challenger Forum: Challenger & SRT8 Forums
Old 11-19-2012, 05:02 PM
Hi, need some suggestions. I recently installed a Homelink into a non-Homelink equipped B5 RT Classic. Got it working fine; but, I also have a 13 SRT Charger. It also has a factory Homelink. I programmed the SRT when I bought it 2 months ago, and it worked fine. After I programmed the Challenger, the SRT Homelink stopped working. I reprogrammed it and now it works and the Challenger no longer works. Garage door does have rolling codes, but I used the same remote to program both cars. Looks like I can have Homelink in one or the other, but not both at the same time. I live alone, so it's hard to get a helper to program both at the same time. Any ideas? Tom
10 B5 Classic, 6 spd, TrakPak, Sunroof, Cervini's Shaker and Go Wing, custom 345 Hemi emblems, Dale's louver's, hide a way front plate mount, Mopar hood pins, side hockey style stripes by Ridergraphix, Petty's strut bar, BT anodized dress up pieces, coil covers by 3G Cutomz, Corsa Extreme catback, SRT front brakes, & Dodge Charger HD rear brakes. Soon to come-Magnacharger
Old 11-19-2012, 05:08 PM
Program one and park it down the street, than program the second car... worked for me on GM cars that had the same issue.
Old 11-19-2012, 06:27 PM
Thanks, I'll try that in the morning. Tom
Old 11-20-2012, 07:41 AM
aarcuda's Avatar
If I recall the first step deletes all codes. SO u need to start at step 1 and program the first car then DI the second car without doing the delete all codes step. I did my two that way w a two door garage using two 3 button remotes from liftmaster
Old 11-20-2012, 09:35 AM
Feedback Score: 2 reviews
Sounds like you must be erasing the prior programming in the door opener itself. Read your door opener instructions and make sure you are using the instructions to ADD a new remote, not clear the opener.
Also my opener will only remember a set number of remotes. The next one sync'd to the door erases the oldest one. I ran into this problem when I programmed the truck opener, it deleted the first remote that came with the door opener.
2009 Challenger SRT8
2010 Jeep GC SRT8
11 GMC Sierra Ext Cab, LB
69 Pontiac Grand Prix 428
Old 11-20-2012, 09:50 AM
Yellow Jacket 2012's Avatar
The car learns the frequency from the hand held transmitter, not from the ceiling mounted unit in the garage. I have four car currently opening my two garage doors. Follow the instructions and you hold the hand held near the home link to copy the signal.
Old 11-20-2012, 10:29 AM
I had the same issue you are having. What I found out is that most garage door openers have a limit to the number of transmitters that can be programmed to it. This includes any handheld tramsmitters that came with the opener and any cars you have programmed. I think you have hit that limit. You need to wipe clean the memory in the opener and then reprogram the cars and any handheld tramsmitters up to the maximum number your opener can handle.
Hope this helps.
Mods:
Magnacharger supercharger (8psi), Roto-Fab CAI
Other Car:
2007 Dodge Charger Daytona RT, Sublime Green
Old 11-20-2012, 03:12 PM
Ok, if anyone else has this issue, I found the solution. I tried parking one around the corner while progaramming the other and that didn't work. I then tried programming one right after the other, and, that didn't work. The answer is that you have to erase the codes on both cars first by holding down buttons one and three on each car for about 15-20seconds; then, program the first car on whatever button u choose (1,2,or 3) and keep holding down the transmitter button (do not let the button up) and go to the second car and then program it (using whatever button u choose), then let the transmitter button up and go to the garage and push the reset button on the opener. Within 30 seconds, go to car #1 and push whatever button u set it up on twice for about 2-3 second each, which will cause the garage door to open (or close, depending what position it was in when u pushed the transmitter to program the buttons). Immediately go to the other car and push the button u set it up on twice and it will cause the door to open or close. Both cars are now set. Both cars have to be set within the 30 seconds after hitting the reset button on the opener, or you'll have to start over.
Hope this helps if anyone else runs into this problem. Tom
Old 11-20-2012, 07:11 PM
CrazySRT8Guy's Avatar
I'm going to have to try this because I have had nothing but problems trying to get mine to set. Thanks bluert!
2012 Challenger SRT8
Pitch Black
Silver Stripes
6 Speed
430N Premium Sound
Sunroof
245/255
2012 Dodge Ram 1500
Pitch Black
Regular Cab/Short Box
5.7 Hemi
2 Wheel Drive
20" Wheels
Old 11-21-2012, 10:19 AM
You're welcome, I'm sure it will work for you. I parked both cars side by side, just outside the garage to program them.
Happy Thanksgiving, Tom
Overall Quality of the Challenger? SuBXeRo General Challenger Discussion 81 11-26-2012 01:42 PM
Fall 2012 Issue - Input Welcome Modern Mopar Magazine General Challenger Discussion 1 10-16-2012 10:04 PM
Tip to Start Issue the727kid General Challenger Discussion 7 07-11-2012 06:12 PM
Window and Door Lock Issue Aaroe Dodge Challenger R/T Specific 0 06-21-2012 11:56 AM
Urgent!! Issue with JBA headers. Jsekel13 Dodge Challenger SE/SXT Specific 32 06-16-2012 08:12 AM
