How much oil DOES the 6.1L really take ?? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 56 (permalink) Old 09-01-2009, 07:41 PM Thread Starter
mokeman3's Avatar
Ok, this is sorta getting to me now...
6,700 miles, and I changed oil twice now, and I still don't have a good feel on exactaly how much 0W40 oil is required for an oil change to put the oil on the right spot on the dip stick.
When I did my first oil change at ~3,300 miles, I drained the oil, and installed a Mopar 988AB filter (which I later found leaking, but that's is/was a seperate topic). I remember that 7 quarts was too much, and the next day I found the oil level too high when I checked it at the resturant that I frequent after work. I didn't worry about then since it was still using oil at 3,300 miles.
Well, I changed my oil about a week ago for the second time, and this time put in only 6.5 quarts. After I was done, I started it, let it run for a minute or two, then shut it down and waited at least 10-15 minutes, then checked the oil level. The car was perfectly level (checked with a 3-foot level under the rocker panel). It was 1/2 quart low, so I put hte last 1/2 quart in for a total of 7 quarts.
Today I checked it at work in the parking garage of our office building after sitting for at least 6+ hours, and I find that it's too high, and darn near at the first bend in the dip stick which is about equal to 1X the shaded area over the top of the shaded area. The dipstick says to NOT overfill.
So if the shaded (hash mark stamped) portion of the dipstick represents 1-quart, this would indicate that I'm 1-quart too full.
So:
1) how much oil does the thing hold (with either the Mopar 899, or Fram PH-2 filter) ?
2) how much oil does the area in the hash/shaded area of the dipstick represent ?
3) should I drain some oil out? (either with my new drain valve, or dropping the Fram PH-2 filter and replacing it with the new K&N 2010 filter that I just got) ?
Thanks,
MM3
mokeman3 is offline
post #2 of 56 (permalink) Old 09-01-2009, 08:12 PM
snowcat256's Avatar
Do as the owners manual says
The SRT8 takes 7qts.
08 HEMI Orange Upgrades:
AIRAID
Blastin Bobs 3" resonated delete
Powder coated SRT rims w/metal accent
Challenger sills & mats w/pedal dress up
Quad rear tips
Mopar steering wheel upgrade
Blend Mount
Sequential tails
Hurst kit
B.T. c/can
Pettys tower brace x 2
Eibach F & R sway bar
KW V2 coil overs
Pedders F & R
snowcat256 is offline
post #3 of 56 (permalink) Old 09-01-2009, 08:32 PM Thread Starter
mokeman3's Avatar
Well all right then...
Guess I was thinking with my dipstick
YouTube - Castrol EDGE - Think With Your Dipstick
MM3
mokeman3 is offline
post #4 of 56 (permalink) Old 09-01-2009, 08:45 PM
snowcat256's Avatar
Wack !!!
MM3
If that guy wacked me behind the legs like that...He would be trying to talk with no teeth.
post #5 of 56 (permalink) Old 09-01-2009, 08:53 PM Thread Starter
mokeman3's Avatar
Yeah, well, I feel like whacking someone at Chrysler with my dipstick (the one in the car that is)...
Do you guys think it's possible that I got the wrong dipstick in my car?
As I said, 7 quarts is putting the oil level WAY past the full mark, and to the first bend in the dipstick. This seems very wrong. Maybe they put in a 5.7L dipstick in at the factory by mistake? Does the 5.7L/RT take 6 quarts ?
MM3
mokeman3 is offline
post #6 of 56 (permalink) Old 09-02-2009, 11:52 AM
I think it probably is just different because of the times which you are checking it. Right after the engine has been on a lot of the oil will still be in the engine, it hasn't drained down into the pan. After it has been off for a long time most of the oil will have made its way down into the pan.
Boostedfool is offline
post #7 of 56 (permalink) Old 09-02-2009, 06:54 PM Thread Starter
mokeman3's Avatar
True (and I thought about that too), but this still doesn't address my original concern ...
If the book (and everyone else here) is saying that the thing takes seven (7) quarts of oil (0W40 Mobile-1), then why the h3ll isn't the oil level even remotely close to the full mark on the dip stick?
7 quarts puts the oil level well past the full mark, and right at the base of the bend in dipstick. This doesn't seem right. If it did, you can acually be a quart low on oil, and the oil level could still be on, or above the full mark on the dipstick. Somein ain't right.
MM3
mokeman3 is offline
post #8 of 56 (permalink) Old 09-02-2009, 07:51 PM
MoparRick's Avatar
OK Moke,
I tried a little test for y'a.
Not sure this is any good but it may help you.
I went out to the garage and removed my cars dipstick and measured the lenght of the METAL part. I did not include the yellow plastic pull "thigny"
The METAL stick part measured 261/2" long. If yours is the same lenght then 7 quarts is the correct amount of oil to put in your SRT Amigo.
Hope this helps....
Orange, 09 SRT, Loaded 6 speed
MoparRick is offline
post #9 of 56 (permalink) Old 09-02-2009, 08:07 PM
dodgeboy16's Avatar
So:
Thanks,
MM3
Make sure that the engine is hot, or has not been run at all (better). The 6.1s and I don't know why ( I think there is a lot of oil, as much as a quart, trapped up top ) need to be left to drain for awhile, the longer the better. The 6.1s TAKE 7 QTs. Hope this helps you.
Jack
2005 Dodge SRT-10 RC Still Own
2006 Chrysler SRT8 Sold
2008 Jeep GCSRT8 Sold
2009 Challenger SRT8 Sold
2010 Jeep GCSRT8 Still Own
2011 Challenger SRT8 Still Own
dodgeboy16 is offline
post #10 of 56 (permalink) Old 09-02-2009, 08:17 PM
What freaks me is when I look at the other side of the dipstick the oil is significantly, well let me rephrase that to "noticeably" lower that on the marked side. Anyone else notice same ? I'm going by the marked side but what's up with that if it's across the board ?
Valley is offline
Oil Change From HELL!!! KDodge75 General Challenger Discussion 64 03-21-2015 09:56 AM
Arrington Oil Separator install on Kenne Bell, fresh air side. rick s Forced Induction 6 12-27-2012 09:57 AM
First oil change - oil soaked air filter. laurag146 Challenger Issues & Problems 7 07-28-2012 09:03 PM
Code P000B kbr577 Tuning/Data 3 07-27-2012 01:56 PM
OE Oil Type ? 1Fast392 General Challenger Discussion 8 06-16-2012 08:14 AM
