Jacking up the car under the differential - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 16 (permalink) Old 11-07-2009, 07:04 PM Thread Starter
snakepitt1's Avatar
Is it safe to jack the car up by putting a jack under the differential and lifting? I know that there are the 4 lift points, but since I need to get the entirs rear up off the ground at the same time, it seems that the rear differential would be the best place. Will this work? Has anyone done this?
2009 TORRED 6 spd, Blown Arrington 426 engine, Arrington 90mm Billet TB W/ nitrous, MBRP exhaust, 1400hp axles, Spec 900TQ clutch, Hurst shifter, catless mids, Hotchkis suspension, HopNot stage 2, Sport Muscle wheels, SLP Line lock, Carbon Fiber front / rear spoilers, CAI and fuse cover, Mopar strut tower brace, Custom paint and graphics, ZEX nitrous, Braided lines, 792.3hp and 821.2 torque on Superflow Dyno, and frikkin laser beams.
snakepitt1 is offline
post #2 of 16 (permalink) Old 11-07-2009, 07:50 PM
bwbike's Avatar
Feedback Score: 4 reviews
I do. I always use a block of wood in the jack saddle and place it just behind, but up against the bottom drain plug. The wood distributes the weight evenly on the body & fins (you don't want to break a cooling fin off).
2015 Jeep Renegade Traihawk
2009 R/T 27F, 6-Speed Tremec
Traded
bwbike is online now
post #3 of 16 (permalink) Old 11-07-2009, 09:56 PM Thread Starter
snakepitt1's Avatar
Thanks for the confirmation. I was thinking of the exact same location, but wanted to know if anyone else has used this spot. I am doing the rear sway bar change next weekend and need to get the rear end up as high as possible.
post #4 of 16 (permalink) Old 11-07-2009, 10:06 PM
dodgeboy77's Avatar
Snakepitt,
I've jacked up under the differential several times with a floor jack. I usually have a hunk of 2X4 on the jack.
I also have jacked up under the rear-most front crossmember with no apparent ill effect. There are two front crossmembers and the rear one seems to be more sturdy. It's hiding under the belly pan. I had a piece of wood on the jack for that, too. First I had the front of the car up on ramps and I went from there.
Trying to jack the car up using the recommended jack points is a pain when you're using a floor jack and jack stands.
Bill
Predator
Pype's Cat-Back
180 Thermostat
Eibach Pro Springs
SRT8 Front Spoiler
Sport Muscle Dyno 5 Rims (20x9 and 20x10)
245/45/20 and 275/40/20 Toyo Proxes 4 Tires
dodgeboy77 is offline
post #5 of 16 (permalink) Old 11-08-2009, 01:25 PM
I've done the same thing for changing the rear sway bar as well. Use the notched rear rockers for the jackstand heads to support the body.
When lowering the rear subframe, you don't want to lower any more (4"-5")than needed, otherwise the tops of the rear springs will drop free of the upper cup/rubber isolator (one more thing to guide back in).
Support the driver's side rear exhuast pipe so it doesn't get kinked when you unbolt the rear resonators - you can leave the hangers attached at the differential area, the angle isn't that much and the exhaust can tilt with it.
When you raise the subframe back up to re-install it start the longer (rear bolts) by hand, then tighten and raise the subframe more with the jack and then start the front bolts by hand and then tighten them.
If you have the Nivomats (black body) if you have an R/T. [N/A for the SRT-those have the yellow Bilsteins], you don't need to remove the shocks from the car - the lower attachment bolt in the control arm is sufficient.
Once you have the car on the ground again, re-torque the four big bolts that secure the subrame to the body. With the rubber biscuits compressed by weight, you might need more tightening.
Don't forget to put that sticky grease that Hotchkis supplies onto the bushings - and install the new bracket zerk fittings facing outward.
You'll like what the new swaybars will do for cornering...
2016 392 Hemi Scat Pack Shaker 23Y pkg (6 speed MT) ordered 8/28/15, born 10/23/15, home 11/20/15
Hal H is offline
post #6 of 16 (permalink) Old 11-08-2009, 03:53 PM
Have jacked the rear under the differential w/o any problems, then used the jackstands at the rocker panel points for stability. Car has waaaaay too much plastic underneath. In the future, these cars will be impossible to restore, where will you get all the plastic parts?
Yooperman is offline
post #7 of 16 (permalink) Old 11-08-2009, 04:33 PM
808srt8's Avatar
I know jacking by the rear diff is doable, but if you look weel, just behind the rear diff is a steel crossmember just behind it. That is a WAY better location to jack it up by...
808srt8 is offline
post #8 of 16 (permalink) Old 11-08-2009, 06:17 PM
hemiuberalles's Avatar
On the same subject... how about the front of the car? Can you jack up the front from a single point?
test
hemiuberalles is offline
post #9 of 16 (permalink) Old 03-23-2010, 01:01 PM
This is where I jacked mine. It's painted or powder-coated black and it works just fine, with no damage to anything. If you put a 2x4 on the jack saddle, you won't even mar the black. It'd be nice if there was a similar spot to use on the front...
____
Bob
1analguy is offline
post #10 of 16 (permalink) Old 03-23-2010, 01:19 PM
Crush's Avatar
X2
This is the point I used - looked like a sturdy part of a subframe right behind the pumpkin.
2009 HO R/T M6: SOLD
2013 HO SRT8 Core M6 (aka "HELLKITTEN"
Mods: R2C Black Hex CAI, 180 stat, catch can, CDV delete, Magnaflow axle-back
Crush is offline
My 2010 Challenger is the most problematic new car I have ever owned, bar none danondorf Challenger Issues & Problems 16 09-15-2013 02:28 PM
My Plum Crazy SRT8 at Bob's now! Pics inside! Syko General Challenger Discussion 152 02-11-2013 09:25 AM
Car is back on Road now..Hats off to Steve White Motors samlab General Challenger Discussion 6 09-18-2012 06:23 AM
I love my car... BBRT General Challenger Discussion 8 09-17-2012 06:24 PM
