Locked keys inside my 09 RT....HELP ! - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 15 (permalink) Old 04-08-2012, 08:43 PM Thread Starter
vichris's Avatar
Feedback Score: 3 reviews
I only have one key FOB. I was getting out of my car and had the keys sitting between my legs. I popped the trunk and got out of the car. As I was getting out my leg pressed on the FOB and it locked the car just as I shut the door. Can you get inside from the trunk? Any ideas guys.
MODS: GWE/white rally stripes, Sequential tail lights, BT GWE engine bling, Sill guards,
Torque Thrust Wheels, Cutouts, Hurst line locks & shifter, Hood pins, Fastman TB
Strut tower brace, Billet strut covers, custom embroidery, Drake fuel door,
Splash guards, Quarter side scoops, T/A hood, Engine rebuild with
forged internals, Whipple 2.9L SC
PB 11.60 @ 120mph
vichris is offline
post #2 of 15 (permalink) Old 04-08-2012, 08:46 PM
WyGoSlw's Avatar
If you're the original owner the dealer can cut you a door key.
I don't know if you can get into the passenger compartment from the trunk via a seat latch.
-Thomas Jefferson
Maggie, the other woman.. ^^^
It's stock.. Really..!
WyGoSlw is offline
post #3 of 15 (permalink) Old 04-08-2012, 08:58 PM
Robo's Avatar
The rear seats are locked in place and only the pull straps from inside will release them.
The quick and dirty option would be to make a straight coat hanger with a closed U shape end (to keep from ruining the window seal when starting out). Feed through the top window seal and try to push down on the unlock button. Need to use some armor all on the window seal to make things slippery for the hanger to not cause marring damage.
Do you know anyone who works for a Tow Truck company - if not this will be kind of expensive route to take. The other option would be to purchase a Slim Jim from a near-by auto parts store and have it around for future lockouts. Call first before going to one and see if they have it. I saw that Sears has one: Sears: Online department store featuring appliances, tools, fitness equipment and more
The other question - you only have one fob? Where's the other one?
2009 R/T Challenger
Bought on Dec 26, 2008
Robo is offline
post #4 of 15 (permalink) Old 04-08-2012, 09:04 PM
aarcuda's Avatar
im surprised it did that. the car should have sensed the key inside and unlocked the door. i know i had my key in the cup holder and locked the door using the switch on the dor and when i shut the door, the horn beeped and the car unlocked. it knew the key was inside
aarcuda is offline
post #5 of 15 (permalink) Old 04-08-2012, 09:10 PM
Robo's Avatar
If he has the base 27F model then there's no remote start or key sensor in the car... our '09 is the same way.
Robo is offline
post #6 of 15 (permalink) Old 04-08-2012, 10:05 PM Thread Starter
vichris's Avatar
No mine is not the base model...its the 28J. I have remote start, key sensor, and push button start. Not sure why it stays locked????
vichris is offline
post #7 of 15 (permalink) Old 04-08-2012, 10:13 PM
Immortal1's Avatar
Chris, sorry to hear of your problem. I suspect there is some sort of programming issue as this should not have happened. Mine works as AARCuda stated. To the best of my knowledge, if the car is locked and I have the fob in my pocket I can open the truck without problem. As for the seats not flipping down from inside the trunk I have not tried that yet. Assuming you have tried all the obvious suggestions I suspect a dealer will be your next best bet, sorry.
There is a fine line between "Hobby" and "Mental Illness." Some of us may have crossed the line.
Mods:
Functional hood scoop, DRL's enabled, Charger intake tube, Solo Mach X cat-back exhaust, Diablo InTune, SX catch can, Sequential taillights, Pistol Grip shifter, Custom smoothed intake manifold, Custom built covers for coolant tank, fuse box, valve covers, and ABS.
Immortal1 is offline
post #8 of 15 (permalink) Old 04-08-2012, 10:32 PM
NewMuscle's Avatar
Unlock a car door with a tennis ball - YouTube
2009 DWB Challenger S/E
Factory Style Rear Spoiler
Hood Struts
K & N Intake System
FlowMaster Dual Exhaust CatBack System
SRT Exhaust Tips
Factory Dual Exhaust Bumper Trim
WebElectic Sequential Taillights
Billet Technology Nose Badge
Blue Halo Driving Lights
Challenger Trunk Mat
If you're not turning around and looking at your car as you walk away, YOU OWN THE WRONG CAR!!!!
NewMuscle is offline
post #9 of 15 (permalink) Old 04-08-2012, 10:39 PM
Kivuli's Avatar
If the fob is in the car, and you have keyless enter, will touching the handle not work?
Tweaks:
Functional Hood Scoops
Amber Delete Turn Signals
OEM HID headlight retrofit
Plastidipped: Stock 18" wheels, AC Panel bezel, console bezel, fuel door
MOPAR black steering wheel inserts
Rebadged by Nate
MOPAR sequential tail lights
Two-tone Katzkin interior
Purple cupholder LEDs
LED map/trunk/plate lights
Kivuli is offline
post #10 of 15 (permalink) Old 04-08-2012, 10:42 PM Thread Starter
vichris's Avatar
I even tried disconnecting the battery to see if that would activate anything. I WILL be having a copy of the valet key made tomorrow.
In the meantime I have emergency road service that comes with car lockout service. Someone is on their way out to unlock it. Thanks for the help everyone.
vichris is offline
Tips on removing inside quarter trim panel? Cuda How-To, DIY and Tips & Tricks 1 10-14-2012 06:25 PM
Odd Noise Inside Cabin, while turning... OutlawRT General Challenger Discussion 1 09-08-2012 08:25 AM
Free Shipping All Speedlogix Brand Today 7/27 - Details Inside Speedlogix Speedlogix 0 07-27-2012 08:15 AM
New Wheel From Hurst, Dazzler, Pic Inside cannonballcobb Wheels, Tires, Brakes, and Suspension 3 07-13-2012 03:09 PM
Help! MyGig 730N locked out YellowHammer Challenger Issues & Problems 6 06-29-2012 12:04 AM
