Google Links
» Sponsors
» Sponsors
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Dodge Challenger Forum > General Discussion
Old 07-18-2008, 03:26 PM
Points: 915, Level: 11
Points: 915, Level: 11 Points: 915, Level: 11 Points: 915, Level: 11
Activity: 0%
Lug Nut Torque Spec
I've looked through the Owners Manual and cannot find the torque value for the lugnuts on the '08 Challenger. Anyone know where to find this info? I'm guessing 85 ft-lbs but would like to have the actual factory number.
Old 07-18-2008, 03:32 PM
SRT8 WOOLF's Avatar
Points: 2,006, Level: 18
Points: 2,006, Level: 18 Points: 2,006, Level: 18 Points: 2,006, Level: 18
Activity: 0%
Re: Lug Nut Torque Spec
its same as the 1970 model tighten till u cant tight no more then one extra crank
car #81 of 6400
bought from Fred Garza
Fiesta dodge
San Antonio Tx
Old 07-18-2008, 03:37 PM
Cuda340's Avatar
Points: 10,760, Level: 44
Points: 10,760, Level: 44 Points: 10,760, Level: 44 Points: 10,760, Level: 44
Activity: 37%
Activity: 37% Activity: 37% Activity: 37%
Photos: (4)
The Charger manual states 110 ft/lbs. Should be the same for the Challenger.
Old 07-18-2008, 03:56 PM
Activity: 0%
[quote=SRT8 WOOLF;36397]its same as the 1970 model tighten till u cant tight no more then one extra crank[/QUOTE
Now I know why your tires are screaming........
Old 07-18-2008, 05:34 PM
SRT8 WOOLF's Avatar
Activity: 0%
all is cool
must be the roads here in sa[quote=ltaverna;36405]
car #81 of 6400
Fiesta dodge
San Antonio Tx
Old 07-18-2008, 05:55 PM
09 R/T's Avatar
Points: 3,017, Level: 22
Points: 3,017, Level: 22 Points: 3,017, Level: 22 Points: 3,017, Level: 22
Activity: 46%
Activity: 46% Activity: 46% Activity: 46%
Ha how many tires have you snapped clean off?
Old 07-18-2008, 06:54 PM
JS29R0B's Avatar
Points: 6,312, Level: 33
Points: 6,312, Level: 33 Points: 6,312, Level: 33 Points: 6,312, Level: 33
Activity: 8%
Activity: 8% Activity: 8% Activity: 8%
Smile Re: Lug Nut Torque Spec
...tire store that changed my wheels torqued them to 115
1970 Challenger T/A....Plum Crazy, 4spd
Old 07-18-2008, 07:37 PM
Activity: 0%
Thanks. Number is much higher than I am accustomed to. I guess if there is no spare to change on the side of the road 115 works. Otherwise you would need a 3 foot long lug wrench! Also my experience with wheel locks has been to be careful with the torque...they generally can't handle too much.
Old 07-19-2008, 10:59 AM
Points: 695, Level: 9
Points: 695, Level: 9 Points: 695, Level: 9 Points: 695, Level: 9
Activity: 5%
Activity: 5% Activity: 5% Activity: 5%
Its the same as the Charger-110Ft/lbs. And definately DONT tighten them as much as you can as a couple of others have told you. Chrysler has a problem with the cap part off the lug expanding when you over tighten, and if you ever are in a spot you have to get them off, your lug wrench(21MM) wont go over the cap. I found this out the hard way on my '07 SuperBee. And definately dont use an impact wrench. Thats wht causes the problem.
vB code is On
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
