MUST-HAVE First Mods - Page 3 - Dodge Challenger Forum: Challenger & SRT8 Forums
  #21 (permalink)
Old 12-21-2012, 12:17 PM
Heywood's Avatar
No worries
Originally Posted by Trainwreck2997 View Post
What is the purpose of a catch can and is it really worth it?
Yes. Catches any oil from getting into your manifold from the PCV. Not all of it gets to the pistons to get re burnt. It's not a must have , but anything that keeps it from getting gummed up is good. Proper warm up and long spirited drives helps a bit.
The same with the 180* thermo?
If you live in a warmer climate, it helps as heat robs power. The gas molecules are less dense when hot. You'll need a tuner to adjust the fan kick on thresholds.
As well as the Hurst short throw shifter
Some say it woks better. I have no 1st hand experiance with it. I like my stock shifter as is
As far as tuning what would be my best option I was looking at the diablo but I dont know anything about tuning should I go to a dyno for that and let them do that
It has canned tunes and you can fiddle after the fact. Most just drop the canned tunes in and say good enough. Custom maps are usually done an a dyno. More cost, but results are better depending on where you live. You can do a lot on your own. You need it if your going with the 180 thermo. You can also get rid of the skip shift as it's in most of their canned tunes. Also throttle boost. Theres more, but you should be able to find it around here.
Does the diablo let you change settings on the fly such as great mpg and then when someone wants to get beat put it on pure performance?
Not on the fly. It's not something that stays connected to your car. Saving your stock map, re-writting the map in the cars CPU, then disconnecting. The tuner is married to the car once you use it there. Keeps people from buying 1 tuner and using it on 6 different cars. I think it can be un-married buy putting the stock tune back in the car. Otherwise, how could you buy a used one? Not sure on that step?
Sorry about all the questions again Im new to this. Thanks
We all start somewhere. Lots of your questions are here. The search function is great and I'd suggest the 100 tips sticky.
I didn't know that ... Challenger Tips and Tricks
The Following User Says Thank You to Heywood For This Useful Post:
Trainwreck2997 (12-21-2012)
  #22 (permalink)
Old 12-21-2012, 12:22 PM
JS1977's Avatar
Everyone has made some great suggestions but let me add one more...
Exhaust - Blastin Bob's Resonator delete kit. The 6spd cars already have a great setup, you just need to remove the resonators. Plus the kit is super cheap compared to the others. Look up Blastin Bob's at least before you pull the trigger on something else.
6.4 cam, BBK CAI, BBK 85mm Throttle Body, JBA Shortie Headers, Blastin Bob Resonator Delete Kit, Diablo Trinity/ExaTorq custom tune, Petty Garage front strut brace, Mopar rear strut brace, 392 spoiler/air ducts kit, Hurst short throw shifter
378.9 RWHP/ 374.4 RWTQ AFR 12.2 to 12.4
  #23 (permalink)
Old 12-21-2012, 03:16 PM
georgethedog's Avatar
Photos: (4)
Originally Posted by Heywood View Post
6. California Duster
NO!!! Unless you like tiny scratches on your clear coat...
Go to YouTube and look up "The Junkman" on how to properly clean, polish, and wax your car.
  #24 (permalink)
Old 12-21-2012, 04:06 PM
rscarawa's Avatar
Originally Posted by blackdeuce View Post
If your concern is keeping the car nice, definitely do the mudflaps. I went with the Mopar version. You will especially want these if you go to wider rear tires.
I sure like mine.
  #25 (permalink)
Old 12-21-2012, 04:10 PM
Heywood's Avatar
I have more than enough wax over the clear coat. And have done the clay bar. It's not scratching or hurting anything.
  #26 (permalink)
Old 12-22-2012, 07:11 AM
We've had our car two weeks and it's got mudflaps, Solo exhaust and a catch can....
  #27 (permalink)
Old 12-22-2012, 07:30 AM
beamg5's Avatar
Photos: (9)
Agreed 100%. Given a proper "top coat" of a good carnauba, the California duster is perhaps the best cosmetic maintenance item I've yet to purchase. Even on amy pitch black car, it leaves no scratches, whatsoever. I have a cousin who uses a mini California duster (among other finishing products) on a $75K Steinway piano without issue.
Respectfully,
Gary aka "beamg5"
  #28 (permalink)
Old 12-23-2012, 07:29 AM
Photos: (4)
Respectfully,
Gary aka "beamg5"
OK, I'll give because you seem to know what you are doing and I have used one inthe past VERY carefully. However, the average user does not use it properly and it tears up the clear coat. Most people will leave too much dirt & dust on the car when they use the duster and they use too much pressure leading to small scratches all over the place. Proper usage (very light and in one direction) barely touching the surface when there is only a small amount of dust on the car can yield good results, but I caution because it is abused and to some is a substitute to washing...
OK, back to the main topic. Sorry to take it in a different direction, but maybe someone learned some caution with the duster.
  #29 (permalink)
Old 12-23-2012, 08:18 AM
BEIST's Avatar
Best quick mods = Chrome Challenger Door Sills (have dealer install them so you don't have to worry about messing up the placement) and Hood Strut Supports. You can probably get them done at the same time for $200 if you talk to the service department nicely.
Couldn't get the Mopar mud flaps back when Chrysler went "ten toes up" in 2009. Got the Invisible Flaps from RPI (for like $40 front & back) I have been EXTREMELY happy with their product and customer service. Bring them with you to the dealership and they'll put them on during a tire rotation.
Doing What Men Do Best!
2009 Stone White R/T 27J
6-Speed, Sun Roof, Heated Leather
20x8's, HID Lights, Challenger Door Sills, Mopar CAI,
1970 Challenger & R/T Emblem on the rear spoiler,
Gas Charged Hood Supports, Mopar Nose Badge
276-watt 6 Speaker Sound
Exhaust: Flowmaster 40's
Mopar Strut Tower Brace
Fuzzy White Dice
"Keep your eyes on the road, your hands upon the wheel!"
  #30 (permalink)
Old 12-23-2012, 08:37 AM
rscarawa's Avatar
If you are referring to the sills that come from Mopar, I think they are stainless, not chrome.
How much do you spend on mods per month? Isaac-1 Performance Modifications 21 12-14-2012 07:38 AM
Performance Mods for the Holidays Bonic4 Bolt On's 4 12-12-2012 11:19 PM
Any Must do mods for MT 6.1 SRT8? Isaac-1 Performance Modifications 19 10-06-2012 04:46 AM
Calling all 392 available performance mods... hemipowerv8 6.4L / 392ci (2011 - ?) 41 08-18-2012 08:15 AM
Charger SRT8 engine mods = Challenger SRT8 engine mods DarthChallenger Performance Modifications 34 06-02-2008 07:08 AM
