I used to own a Black 2012 R/T, but this winter acquired a Sublime 2015 SRT 392. It was a pre-production pilot car, so a couple of the items in the car are different than it should have been for 2015. The car has been in the garage since the day it arrived, since it was snowy, but I've finally gotten to get it out and play. It has way more power than the crappy tires can handle, so I will need to get some better tires, asap.
So, the car has the large head unit, and the build sheet states it's Harmon Kardon, but the speak and amp setup is the earlier nine speaker, lower wattage Alpine setup. The other strange thing is that it has the Brass Money wheels listed, but I was told that Chrysler had supply issues with them, so the car was fitted with flat black wheels. The car was built in early spring of 2014, and I was told the Brass Monkey shortage lasted into the actual production run of 2015 cars, so that would make sense.
In any case, does anyone know if the earlier 5-spoke Alcoa SRT8 wheels fit over the 2015 brakes, an have the same offset as the 2015 SRT? I've always liked how the black pocket Alcoas looked, and I have a set of the regular wheels in the shed I could get powder-coated, if I want, but I wasn't sure if the wheels had the same specs as the 2015 392s or not. If anyone has any insight, I'd appreciate it.
Thanks!
Thanks!
