Oil Change Interval - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 48 (permalink) Old 01-28-2013, 07:28 PM Thread Starter
Immortal1's Avatar
Oil Change Interval
I realize there has been many threads started regarding how many miles you should get between oil changes and of course if you should have a catch can or not but....
My question is regarding oil change intervals when you DON'T reach 3,000 miles within 6 months.
I understand with normal mineral based oils you should probably change the oil every 6 months due to break down of the oil from gasoline blow bye and / or moisture condensation within the oil system. But what about the synthetic oils? Do these follow the same 6 month change interval, regardless of mileage?
I am asking as I know little about the synthetic oils other than that they cost more and provide better lubrication.
Anyway, give me your thoughts :-)
There is a fine line between "Hobby" and "Mental Illness." Some of us may have crossed the line.
Mods:
Functional hood scoop, DRL's enabled, Charger intake tube, Solo Mach X cat-back exhaust, Diablo InTune, SX catch can, Sequential taillights, Pistol Grip shifter, Custom smoothed intake manifold, Custom built covers for coolant tank, fuse box, valve covers, and ABS.
Immortal1 is offline
post #2 of 48 (permalink) Old 01-28-2013, 07:35 PM
wasp392's Avatar
Oil Change Interval
With synthetic, I was told by my mechanic that the 6 month rule does not apply. Unless the car has been in non operating mode for a while.
HEMIPHEVER TUNED, BARTON SHIFTER WITH MOPAR SHORT THROW SHIFTER, MAGNAFLOW COMP SERIES 16885, MOPAR CAI, RIDETECH TQ LEVEL 3 COILOVERS, MOPAR FRONT & REAR STRUT BRACES, PETTY'S FRONT & REAR SWAY BARS, PETTY'S SUB FRAME CONNECTORS, REM FRONT & REAR SWAY BAR LINKS, REM FCA, REM BUMP STEER KIT, REM RCA, REM REAR TRAILING ARMS, REM FRONT & REAR BUMPER SUPPORTS, APR SPLITTER & WING, CARBOTECH XP12 RACING BRAKES, STOPTECH BRAKE LINES, 275/40/20 NITTO NT05 TIRESx4
wasp392 is offline
post #3 of 48 (permalink) Old 01-28-2013, 07:41 PM Thread Starter
Immortal1's Avatar
So HEMIZSP, if what you were told is true, it might make much better sense for us "weekend drivers" to run more expensive synthetic oil and only change it once a year (assuming you only drive around 5,000 miles per year or so)?
post #4 of 48 (permalink) Old 01-28-2013, 07:48 PM
rscarawa's Avatar
I have done yearly oil changes in some cars that I rarely drove. I would not push it much more than that though as the oil can gel up. And that is based on mineral oil too.
rscarawa is offline
post #5 of 48 (permalink) Old 01-28-2013, 07:48 PM
R/T Bee's Avatar
I have been thinking of this very thing! I am going to ave 5000 a year (as this is what I did in 2012) so ..... I might have to think about synthetic!
R/T (used to be Cuda Cliff) Bee
1954 Plymouth Savoy
1959 Chevy Apache
"She may not be the youngest gal at the ball ... but she can still turn a head or two"
R/T Bee is offline
post #6 of 48 (permalink) Old 01-28-2013, 07:49 PM
wasp392's Avatar
Oil Change Interval
Actually I bought my car 9 months ago and I only put on 2400 miles so far. But I plan to change it at 3k miles. Just because its the first oil change. But then again you can only put synthetic in the 392. I plan on changing it every 3k. That's once a year. Just to be on the safe side.
wasp392 is offline
post #7 of 48 (permalink) Old 01-28-2013, 09:04 PM
RWL11's Avatar
- Bob is the Oil Guy
Try finding the answer on this motor oil forum. They have LOTS of information here, all you ever needed to know about oil, and then some!
RWL11
PDX, OR
2016 R/T Scat Pack, A8
Belle II
Drake All-Satin Fuel Door with Billet Tech Fuel Door Insert, EZ Pull Trunk Straps, Razor's Edge Front Strut Bar, Mopar Bright Pedal kit, Splash Guards, Door Sills & Hellcat Airbox with aFe Power Dynamic Air Tube and D.I.P.S., Tint & Clear Bra by Tommy's. DD XML2 Fogs. Billet Tech Engine Bay Dress Up Kit. Stripes by Mitch Kim. Hurst Quad Tips. DRL's:ON!
"there are many like it - but this one is mine"
RWL11 is offline
The Following User Says Thank You to RWL11 For This Useful Post:
PlumCrazy392 (02-02-2013)
post #8 of 48 (permalink) Old 01-28-2013, 09:13 PM
wasp392's Avatar
Oil Change Interval
If you do 5k a year, just do the synthetic and change it once year. I would not let it go past one year even if you gonna do UP to 8-9k miles.
wasp392 is offline
post #9 of 48 (permalink) Old 01-28-2013, 09:43 PM Thread Starter
Immortal1's Avatar
Wow, you are not kidding about LOTS of info. Have not found my answer yet but did find a lot of other good info.
post #10 of 48 (permalink) Old 01-28-2013, 09:45 PM
Yellow Jacket 2012's Avatar
I'm doing mine every six months regardless of mileage.
Yellow Jacket 2012 is offline
Oil Change From HELL!!! KDodge75 General Challenger Discussion 64 03-21-2015 10:56 AM
Oil Change - Frequency and Type seebz13 Detailing / Car Care 23 05-17-2013 04:07 PM
Arrington Oil Separator install on Kenne Bell, fresh air side. rick s Forced Induction 6 12-27-2012 10:57 AM
Just completed first oil change...one quick question RootsRadical 6.4L / 392ci (2011 - ?) 12 11-11-2012 11:38 PM
First oil change - oil soaked air filter. laurag146 Challenger Issues & Problems 7 07-28-2012 10:03 PM
