Posi trac? - Dodge Challenger Forum: Challenger & SRT8 Forums
Old 11-19-2012, 09:05 AM
Posi trac?
Hi guys, I have a 2013 base R/T and it has an auto with the 3.06 ratio, I didnt see anything about a positrac on the window sticker/build sheet, but it does dual tire burnouts with traction control off......so do I have a "Anti-spin Differential Rear Axle"....which I thought was only an option or part of the supertrac pac?
Old 11-19-2012, 10:28 AM
Go Goody's Avatar
The brakes engage to trick the open diff into thinking it is slipping unless you have the limited slip rear...$100 option and well worth it.
08 SRT8 #6077, InTune, AFE CAI, 180 TT, Catch Can, Cabin Air Filter, Speedlogix Strut Brace, Best time of 12.85@109.66
Go Goody's Avatar
Not part of super track pack
Old 11-19-2012, 10:55 AM
So with traction control off why am i doing dual tire burnouts? and I wish i could add it for $100....haha
Old 11-19-2012, 10:59 AM
Bills RT's Avatar
like this
18 inch chrome clads, BT Catch Can,More to come as funds allow.
Old 11-19-2012, 11:00 AM
OmahaRumble's Avatar
Feedback Score: 8 reviews
If you have a two tire fire going, you have a limited slip differential. I believe Dodge calls theirs the "Sure Grip." Posi, is a Chevy term IIRC.
-= 2010 Dodge Challenger R/T Classic =- in Brilliant Black. Super Track Pack, sunroof, leather, 3.92 gear, 6 speed.
MODS:
Zoomers catback exhaust
AFE Stage II cold air intake
Fastman ported throttle body
Diablo CMR tune by Johan
Mopar splash guards
SRT8
6.1 chin spoiler
SLP skip shift eliminator
BT catch can
3M 20% window tint
functional hood scoops
Old 11-19-2012, 11:24 AM
Originally Posted by Bills RT View Post
like this
Yep like that! Is it a different positrac than the one they list as an option (anti spin differential)....since mine didnt say anti spin?
Old 11-19-2012, 04:10 PM
Photos: (1)
The reason you can put 2 stripes down with an open diff even with TC disabled is because irs pretty well neutralizes the problem when it comes to standing burn-out kind of launches. A closed-diff won't make much difference in such a scenario...the car is sitting level even under torque, so there is no reason for 1 tire to break loose by itself.
You really have to be cornering the car on-power for this to become an issue with the open diff, and even then, you get a good amount of leeway with power going down in both tires before it peg-legs. You really got to turn hard and abruptly to lift the inside tire far enough to blow-out traction. It's probably not even all that natural a turn, as far as skillful navigation through an apex...so not all that much to worry about, imo.
My theory is that the LSD is still a highly desired item because people are still thinking in the context of sra cars (where you truly do need that type of control). Now that modern muscle sits on an irs, it's a totally different ballgame. People may still want the LSD, but it's not nearly the dire necessity as it used to be, as far as actual utility.
From my personal experience, there's plenty of instances where you would think the inside is going to break loose, but it doesn't. If you are doing it "right", both tires are putting down good thrust, and it is even quite likely the outside tire is at the threshold of breaking lose between thrust and lateral traction. So you'll be getting tail-out just like if you were on an LSD...not really missing out on being able to put more power into a turn, because adding any more is only going to trigger more oversteer.
Old 11-19-2012, 04:29 PM
LURCH's Avatar
Photos: (3)
I didn't think you could cut the traction control completely off on an R/T??????
Old 11-19-2012, 04:35 PM
BNB BNB is offline
On my 2013 M6 R/T I hold the button down for bout 5secs and beast mode turns on!
Posi or limited slip? RippTyde General Challenger Discussion 7 09-26-2012 02:27 PM
08 srt8 do the cars have posi? Via Video posted Indésirables General Challenger Discussion 13 04-15-2008 08:14 PM
