Posi trac? - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
  #11 (permalink)
Old 11-19-2012, 05:59 PM
Yahooligan's Avatar
Originally Posted by LURCH View Post
I didn't think you could cut the traction control completely off on an R/T??????
R/T auto with STP or R/T 6-speed you can indeed. 2011+ makes it easier than pre-2011 since you no longer have to do the "key trick."
  #12 (permalink)
Old 11-19-2012, 06:08 PM
Photos: (1)
Traction control is a bit different from stability control. You can turn off TC in any Challenger by just pressing Mr. Squiggly button...then your rear tires are free to go up in smoke any way you choose (in fact, even default-on TC allows you to burnout in a straight line quite liberally). What remains is base level stability control. All those extra contortions are about shutting off stability control completely. The only real thing you are missing out on by not doing that is very wide power slides and the prospect of a full 180 if you get "too" careless.
Just using the Mr. Squiggly button is really all you need to open the car up to a fair amount hooligan activity. I've never tried it, but I'm guessing a full 360 deg circle is possible as long as you are staying in one place.
  #13 (permalink)
Old 11-19-2012, 06:10 PM
BNB BNB is offline
They are soooooooooo fun though!
The Following User Says Thank You to BNB For This Useful Post:
USRWDV8 (11-19-2012)
  #14 (permalink)
Old 11-19-2012, 06:21 PM
Photos: (1)
Yes, if you are in an area where there is room to do it, I wouldn't mind indulging it a bit. Unfortunately, there isn't any place like that for me around here, so it is mostly an academic topic for me.
  #15 (permalink)
Old 11-19-2012, 06:46 PM
If you had anti-spin it would be on the sticker as an option for either $100 or $195 I have seen both prices on 2013 stickers, and if you look under the car the anti-spin Getrag housing is aluminum and it has a flat bottom with cooling fins, the regular housing is cast iron and no fins.
2012 R/T Classic Redline 3-coat pearl
Automatic
Super Track Pak
Anti-spin
Sunroof
Sound group II
DiabloSport Trinity
Resonator delete
  #16 (permalink)
Old 11-19-2012, 07:25 PM
Thanks for the great answers guys, I really appreciate it. I have been turning off the squiggle TC button, idk anything about the STP you guys are talking about or holding anything down for 5secs?
  #17 (permalink)
Old 11-19-2012, 07:39 PM
Flat Top's Avatar
Moderator
My TC button dont need held in, just one push. I also had both tires burn with the open rear end. Common.
However at times in the water box, as one tire would stick causing the peg leg to show itself. I did go to an srt lsd. Very happy.
FlatTop
09 5.7 to 392 Stroker, Vortech, Edge 4000 stall TC, Mr.Trinity. Quantum Blue BND oils.
Johan, Diablotoona@gmail.com email Tuned
SHR Viking Trans DSS 1000hp half shafts. Getrag 3:07 rear. SRT springs. Dual fuel pumps. 28x10 Hoosier wrinkle walls.
Posted in 11sec. et club 9-9-11 NEW PB 11:449 @ 118.8 1.58 60ft Tulsa Ok.
9-23-11 Backed it Up MOKAN Joplin Mo.
New PB 11:4446 DA 1650
392 Stroker New 1-29-13 ET unknown.
SPEED cost MONEY How FAST you wanta go ?
  #18 (permalink)
Old 11-19-2012, 08:35 PM
BNB BNB is offline
Holding it down will turn the ESP off...
  #19 (permalink)
Old 11-19-2012, 08:46 PM
What is the ESP and whats the difference between it and traction control being off?
  #20 (permalink)
Old 11-19-2012, 08:59 PM
BNB BNB is offline
Electronic stability protection...helps keep the car in check while TC is off...you turn ESP off and she gets as loose as Sally at the strip club...
Posi or limited slip? RippTyde General Challenger Discussion 7 09-26-2012 02:27 PM
08 srt8 do the cars have posi? Via Video posted Indésirables General Challenger Discussion 13 04-15-2008 08:14 PM
