General DiscussionThis section contains general discussion about the new Dodge Challenger concept. If it does not fit into a more specific area, it probably belongs in here. (Dodge Challenger General Discussion)
do ur tires scream on the road or like squeel when crusing
and i dont mean burning out im talking 60 70 mph or a smooth road?
oh yeah i do have the upgraded tires as well
car #81 of 6400
bought from Fred Garza
Fiesta dodge
San Antonio Tx
Is the steering wheel straight on your car? The reason for the question is I suspect a toe-in problem. Maybe when the vehicle was bound down for transport, the suspension didn't like it. Anyway, if your dealer has a good tech, he'll find it and fix it.
Jack
Mods:
Bright Pedal Kit/ 180 degree Tstat
S.S. door sills/ Mopar locking gas cap
Bullet Resonators/ Hood to Fender stripes
BT Catch Can w/custom bracket/ Hood pins
Rear Spoiler R/T emblem
Painted Calipers
C&L CAI & modded lower box
waiting for Predator update
Jack
car #81 of 6400
Fiesta dodge
San Antonio Tx
My GM 4X4 had the same issues, worse on certain types of roads kinda like you say ( some of the roads if you look close are not a tight smooth finish, this pulls the tire), was told tires, drive shaft etc.
Jacked up the front end and LF tire felt loose when trying to tilt tire up and down., lugs were tight, found bearing was bad. Most all new rides have sealed bearings, not sure on the new Challenger what type of bearing,could even be loose if it is not a sealed unit? But sure sounds like a bearing, or seriously out of toe...unless it is a tire seperation starting?
So I replace the bearing $345 later for the part and no more noise. You could not tell the bearing was bad when out, felt smooth, no play etc. But a 1/64th of play with big tires and man you get a lot of tire wobble etc.
Get that baby in asap so not to chew the tires up..good luck..let us know what the fix was..
I have the upgraded performance tires and do not have the problem you are describing. If I were you I would take the car in for an allignmentment check and close inspection of each tire. Are you noticing any vibration or seeing any signs of abnormal tire wear.
Also, after driving can you feel one wheel / hub hotter than the others. This might indicate a bad bearing location.
