R/T Engine Code Already - P0730, Gear Ratio Incorrect - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 38 (permalink) Old 11-03-2008, 12:14 PM Thread Starter
vtodd's Avatar
Feedback Score: 3 reviews
So I was driving under normal conditions accelerating normally and the engine coughs...strange. Then it does it again, a very sudden cough like it is struggling for air, the vehicle almost shudders too. Engine code pops up. Head to auto zone and have it checked - P0730 gear ratio incorrect. To dealership tomorrow. Car is stock.
Does anybody know what this might mean, and has anybody experienced this before. Perhaps in a Charger or Magnum?
Thanks.
Semper Fi
2009 Auto RT - Kooks LT's, 6-Speed Stock Exhaust, 85MM TB, Katskins,
Fenderwell FAI, Johan Tune, Catch Can, 180 T-Stat.
vtodd is offline
post #2 of 38 (permalink) Old 11-03-2008, 12:33 PM
1971cuda's Avatar
Re: R/T Engine Code Already - P0730, Gear Ratio Incorrect
Found this on the 300C Forum, don't know if it will help you! Also did a google search and it comes up with different reasons. Good Luck! It read:
I love reading the Service Manual. Just wish I knew how to make use of it!
Here is what it says about P0730
P0730-INCORRECT GEAR RATIO
Theory of Operation
The Transmission Control Module (TCM) constantly calculates the transmission ratio based on the input speed sensor 1 and 2 (N2-N3) signals and the calculated output shaft speed. The intent of this diagnostic is to detect if the transmission is trying to mechanically shift into a lower gear then the TCM intends.
When Monitored:
Engine RPM greater than 450 RPM, output speed greater than 180 RPM, no N2 - N3 input speed sensor errors present, no gear selector lever errors present, no ABS system errors, and all wheel speeds above 450 RPM.
Set Condition:
No shifting operation and detected gear is not the actual gear. No shifting operation - detected (calculated) gear is less than actual (expected) gear, no plausible gear is calculated, actual turbine speed - calculated turbine
speed is greater than 300 RPM or calculated transmission ratio is above threshold. During an Upshift - detected (calculated) gear is less than actual (expected) gear. During Downshift - detected (calculated) gear is less than actual (expected) gear.
Possible Causes
INTERNAL TRANSMISSION PROBLEM
TRANSMISSION CONTROL MODULE
Diagnostic Test
1. CHECK FOR INTERNAL TRANSMISSION PROBLEM
Determine if there are any Transmission mechanical problems present.
Remove the Transmission Oil Pan and inspect for excessive debris or a plugged Transmission Oil Filter. Refer to
21- AUTOMATIC TRANSMISSION-AUTOMATIC TRANSMISSION NAG1/SERVICE INFORMATION for the appropriate service procedure
Is there any Transmission mechanical problems present?
Yes >> Repair as necessary. Refer to 21- AUTOMATIC TRANSMISSION-AUTOMATIC TRANSMISSION NAG1/ SERVICE INFORMATION for the appropriate service procedure.
Perform NAG1 TRANSMISSION VERIFICATION TEST - VER 1.
No >> Using the schematics as a guide, check the Transmission Control Module (TCM) pins, terminals, and connectors for corrosion, damage, or terminal push out. Pay particular attention to all power and ground circuits. If no problems are found, replace the TCM per the Service Information. Refer to 8 - ELECTRICAL/ ELECTRONIC CONTROL MODULES/TRANSMISSION CONTROL MODULE for the appropriate
service procedure.
Performance Mod's 85mm TB/Mopar CAI/Corsa Exhaust/JBA Short Tube Headers/BT Catch Can/Predator Tune/180 degree stat
Styling Mod's SRT Struts & Shocks/Mopar Stage 1 Lowering Springs/SRT Front Spoiler/SRT Hood Vents/Chrome Door Sills/Tinted Glass/SRT 300 Black Chrome 20x9 Wheels with Nitto Motivo's
Other Mod's BT engine dress up kit/392 engine half covers/
28J / EVIC/ Sound Group II and HID's from factory
1971cuda is offline
post #3 of 38 (permalink) Old 11-03-2008, 03:09 PM
Im gonna say probably a speed sensor or bad connection for a speed sensor.
cbrseadude is offline
post #4 of 38 (permalink) Old 11-03-2008, 06:28 PM
I had that code a few times on Chargers and 300c's! It was usually a problem with the transmission torque convertor!
Chryslertech is offline
post #5 of 38 (permalink) Old 11-03-2008, 06:37 PM
djwhog's Avatar
I agree or a bad ground or loose connector for the switch. Should be an easy fix at the dealer!
DYNO Dave
djwhog is offline
post #6 of 38 (permalink) Old 11-03-2008, 07:41 PM Thread Starter
vtodd's Avatar
do you think the the faulty sensor will result in the engine sputtering/coughing when lightly accelerating?
vtodd is offline
post #7 of 38 (permalink) Old 11-03-2008, 08:29 PM
The trans module is programmed to put the trans in neutral as soon as code P0730 is set at speeds above 18 mph.It gets your attention when your cruising down the highway and the trans goes into neutral!!!!!! Mercedes trans programming!! I guess if your are just over 18mph it will chug and go in and out of gear!!!
post #8 of 38 (permalink) Old 11-03-2008, 08:36 PM
djwhog's Avatar
Anytime the light goes o nthe ECM goes into limp mode if it is a hard code, so yes it can thill it is cleared. It is to protect the power train and to make sure it can limp back in for repairs and not get you stranded.
at least that is the theory i nthe design.
djwhog is offline
post #9 of 38 (permalink) Old 01-31-2009, 07:52 PM Thread Starter
vtodd's Avatar
well, had this code again! 2nd time now. the first time the dealership said it had to do something with the transmission software being out of date? they said they updated it, but clearly that didnt solve anything. back to the dealership next week hopefully.
has anybody else had this problem?
vtodd is offline
post #10 of 38 (permalink) Old 02-01-2009, 05:14 AM
Please let us know how this works out !
Semper FI
Jammer223 is offline
Mid-West Owner List Venthos Mid-West 260 01-10-2017 11:39 PM
Check Engine Code P2066, Engine Stalled on Highway... HELP!! ShastaMcNasty Challenger Issues & Problems 3 05-29-2015 01:19 PM
2013 Challenger Information Thread ResumeSpeed General Challenger Discussion 1309 04-14-2015 05:13 AM
2013 Dodge Challenger ResumeSpeed General Challenger Discussion 8 09-02-2012 10:26 AM
Code P000B kbr577 Tuning/Data 3 07-27-2012 02:56 PM
