What does everyone recommend as the best way to try and prevent our Challengers from rusting. I've read the many posts about the rocker panel rust issues caused by the spray foam and the cloth pad in the rear wheel wells. I plan on removing the pad this summer. I also would like to coat the wheel wells and other parts with something to try and prevent rust if possible. I seen some suggestions for Por-15, Rusfre, Eastwood rust prevention kits, and also just using oil to coat as much as can be done. I don't know much about these products. In the past I've just used rubber undercoating on my truck. I wasn't sure what would be the best way to go, so I wanted to see what others feel is the best shot at this. Thanks.
