Stock Throttle Body Issues - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 15 (permalink) Old 09-28-2009, 04:21 PM Thread Starter
I've been having issues where my SRT8's idle falls off in gear. When approaching a stop sign/light, idle settles into 700 rpm for a few seconds, and then drops off to about 575. I can bump the shifter in Neutral or barely touch the accelerator, and it'll jump back to 700, and idle steadily until the next full stop.
I took it to the dealership today for unrelated service work, and they called to say that there were stored DTCs in the computer and that they were related to the ETC. I hadn't seen any MILs, and didn't find any when I last checked with my Dashhawk. Regardless, the stored codes were P2111, P0222, P0123. The tech also performed an "ETC follower test while observing TPS numbers" and found "ETC Assembly is sticking."
The Service Writer said they need to replace the ETC (throttle body), but it is on backorder and he hopes to have it in a couple of weeks. I have my SRT8 back for the time being, and I'm hoping that a new throttle body will correct the idle issue, but I have no idea if it's related.
Can anyone describe the "ETC follower test." And how likely is it that the "sticking ETC assembly" is affecting idle speed?
Rocky Rotella is offline
post #2 of 15 (permalink) Old 09-28-2009, 06:22 PM
The throttle body lets the air into the engine.So anything sticking or acting up with the throttle, will cause idle issues.The ETC (electronic throttle)has an internal tps (throttle position sensor) This can be checked for smooth, accurate operation.(ETC follower test)Also a throttle relearn can be done to put the gas pedal sensor and throttle motor (ETC) in sync.Could be your problem,but had a few that the PCM (engine computer) was bad.
Chryslertech is offline
post #3 of 15 (permalink) Old 09-28-2009, 06:44 PM Thread Starter
How can you determine if the PCM is the culprit?
post #4 of 15 (permalink) Old 09-28-2009, 06:59 PM
djwhog's Avatar
I have a stock oe, but then you need to get it don under warranty.
The stepper motor position is calculated with the PCM on imput from all engine sensors like coolant, air, OS, TPS etc.
Most like it could be a binding motor, do you know however if was attempted to be rest for the base idle / throttle adjustment proceedure?
I have to give the beni of the doubt.
good luck!
DYNO Dave
djwhog is offline
post #5 of 15 (permalink) Old 09-28-2009, 09:09 PM
If the codes are not active,it's hard to verify the failed part.Diagnostic tests are for active codes.If you have a failure code,it could be the sensor,PCM or wiring issue.It's possible the throttle is bad,but haven't seen many fail.I've replaced a few throttle bodies over the last year.All 3 cars had the codes comeback and the pcm was at fault.Recently had a 09 300 hemi with throttle codes,600 miles on car,PCM fixed it.Just my experience.
post #6 of 15 (permalink) Old 09-28-2009, 10:21 PM Thread Starter
Interesting. Are there any other indications that the PCM if faulty? And would that be the next component replaced if the DTC(s) return?
I guess I should ask too, have you seen low idle conditions before? Was the PCM the solution?
post #7 of 15 (permalink) Old 09-29-2009, 07:26 AM
Haven't seen any Challengers with idle conditions yet.Have them replace the throttle and see if any codes return.If they do,the wiring should be checked and wiggle tested.If thats ok,its probably the pcm.
post #8 of 15 (permalink) Old 09-29-2009, 09:44 AM Thread Starter
Thanks for the help. I'll let you know what becomes of it.
post #9 of 15 (permalink) Old 09-29-2009, 10:09 AM
bluesrt's Avatar
it may have a poopy tps sensor and not throw a code-chrysler tps sensors are junk
2010 srt8 b5 blue auto hard loaded-
bluesrt is offline
post #10 of 15 (permalink) Old 10-04-2009, 11:04 AM Thread Starter
Have you had a TPS fail on your SRT8 without throwing a code? What were the symptoms?
Stock Throttle Body size Great White Dodge Challenger R/T Specific 8 01-12-2016 07:28 PM
Throttle Body JMar SRT// 6.4L / 392ci (2011 - ?) 55 01-26-2015 02:52 PM
Speedlogix Ported Throttle Bodies-V6, 5.7, 6.1, 392 SRT8U Speedlogix 45 01-06-2015 10:36 PM
aFe Releases Throttle Body Spacer for Dodge Challenger R/T / SRT8 11-12 V8-5.7/6.4L aFePower Vendor Deals 4 12-19-2013 08:11 PM
