Trunk popping open ? - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 35 (permalink) Old 01-20-2010, 05:29 PM
I may have a solution for anyone having this issue. I work for the company that makes the FOBIKS. We have had quite a few warranty FOBIKS returned lately for this issue. The trunk opens by itself, or the doors lock/unlock themselves, even the windows roll down.
After analyzing these parts, we were able to figure out what was causing these "Hauntings".
Here's the issue,
The FOBIK has a rubber mat with the button graphics on it. If you open your FOBIK, the bottom side of the rubber mat has metal discs called "Snap Domes". The sanp domes are what give each button that snap feel when you press it. Each of these snap domes are made of stainless steel, coated in a black carbon paint to give them extra conductivity. When you press the button, the snap dome completes the circuit for that button and the FOBIK transmits.
The issue is that sometimes a small piece of the carbon coating can break away from the stainless steel and get trapped under the snap dome. Even a very, very small piece of this is enough to create this problem.
Because the carbon material is very conductive, and it is trapped beneath the snap dome, it can complete the circuit very easily and make the FOBIK transmit. Depending on which button this happens to, this can create a variety of issues.
If this phenomenon occurs beneath most buttons, the outcome is very predictable but is most annoying when it happens beneath the Unlock button. That can randomly unlock the car, but also can make your windows roll down. Not good if it's raining out.
The FIX is very simple. Just open up the FOBIK, and use a q-tip and wipe both the PCB where the snap domes make contact, and also wipe off the underside of the snap domes. Remove any loose black residue. Once gone, the problem should go away as well.
Firebird2000 is offline
post #12 of 35 (permalink) Old 01-20-2010, 05:37 PM
Originally Posted by WVU Hemi View Post
I think my 09 R/T is haunted, 3 times in about a week I have went into the garage and the trunk lid is popped open. It is put away for the winter, there is nobody around, the key fob is in a drawer and it is coming open on its own? Anybody else seen this? Is it mpossible that my daily driver (Honda Accord) or a neighbor has the same frequency as the Challenger? Got me puzzled.
This is happening to mine also. 2009 R/T
TorredAT is offline
post #13 of 35 (permalink) Old 01-20-2010, 05:46 PM
Cuda340's Avatar
The "snap-dome" fix sounds like the solution to your problem. If that doesn't cure it, I would either remove the trunk light bulb or disable the switch to prevent it from draining your battery.
Cuda340 is online now
post #14 of 35 (permalink) Old 01-21-2010, 05:38 AM
STONEWHITE R/T's Avatar
All is takes is a bunch of coins in your pocket or other keys on the ring while in your pocket to depress the button. Look at your FOB. The bottons on the Challenger fob are raised. Except for the panic button. It does not take much to depress the button and you will - open the windows, open the trunk, unlock your doors. But almost never set the panic mode.
Conceived - 12-03-08
Born - 03-09-09
First seen On the truck Easter Sunday - 04-12-09
Brought home - 04-13-09
Mods so far.
Mopar hood props
Mopar locking gas cap
RiderGraphix - Challenger R/T script in gloss black on spoiler
Mopar locking lug nuts
Mopar T-shifter
Mopar Challenger door sill guards
Mopar Challenger car cover
Mopar Cat-back exhaust system
Billet Tech. - Satin Catch Can
STONEWHITE R/T is offline
post #15 of 35 (permalink) Old 01-21-2010, 06:41 AM
I cant count the number of times I get into my car, sit down and hear the trunk open....
I now carry my keyfob in my jacket or shirt pocket.
These Are My Principles. If You Don’t Like Them, I Have Others
RBart is offline
post #16 of 35 (permalink) Old 01-21-2010, 05:36 PM
392Powr's Avatar
Feedback Score: 4 reviews
Here's the issue,
These are the kind of posts that make this forum simply awesome
A big thank you to Firebird200
2009 DWB R/T gone, but fondly remembered
2013 SRT8 Bright White A5 w/Radar Red interior (1 of 64)
392Powr is offline
post #17 of 35 (permalink) Old 01-21-2010, 05:51 PM
You are very welcome. Happy to help.
post #18 of 35 (permalink) Old 01-21-2010, 06:10 PM
MoparRick's Avatar
Here's the issue,
Great info Firebird, Thanks!
Orange, 09 SRT, Loaded 6 speed
MoparRick is offline
post #19 of 35 (permalink) Old 01-21-2010, 07:05 PM
340GTS's Avatar
Firebird 2000's post needs to be archived with all the other valuable tips & tricks.
That is GREAT info! Thanks.
xxxxxxxxxxxxxxxxxxxxxxxxxxx -Ordered May 15,2008 -
xxxxxxxxxxxxxxxxxxxxxxxx BORN on November 13, 2008
xxxxxxxxxxxxxxxxxxDelivered to Dealer on November 28, 2008
xxxxxxxxxxxxxxxxx xxxBrought Home on December 1, 2008
xxxxxxxxxxxxxxxxxxxxPAID in FULL April 22, 2011
340GTS is offline
post #20 of 35 (permalink) Old 01-21-2010, 08:23 PM
High Rise Torker's Avatar
Actually I've set the panic button off about 5 times in the past year at work.
High Rise Torker is offline
How To Diagnose/Fix Trunk Light Circuit ChuckR How-To, DIY and Tips & Tricks 20 04-06-2016 08:15 PM
Bolts through the trunk floor ceri Interior Discussion / Modifications 29 10-29-2012 07:47 AM
Weathertech Trunk Liner gavinpapa Interior Discussion / Modifications 0 09-06-2012 05:39 PM
Disabling the trunk release on the key fob? JT19 General Challenger Discussion 4 08-22-2012 05:02 PM
