Aaaaand 5x115 is the bolt pattern, not the offset.
OP, which are you wanting to know? Bolt pattern or offset? I would stick with 5x115 for the bolt pattern, don't risk causing mounting or centering issues. Offset is something totally different and refers to the distance from the wheel mounting surface to the wheel centerline.
