Lowered with the H&R springs - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Wheels, Tires, Brakes, and Suspension
Sponsored by: Discount Tire
Old 11-23-2012, 04:37 PM
Send a message via AIM to 707 HEMI
I just lowered my 09 R/T 6speed with H&R lowering springs. The stance is so nice, lost the wheel gap and stiffened the suspension up. But every time I go over a bump I hear thump noise from the side I hit the bump. Any suggestions?
Lowered with the H&R springs-get-attachment-1-.jpg   Lowered with the H&R springs-side.jpg   Lowered with the H&R springs-drop-1.jpg   Lowered with the H&R springs-drop2.jpg
Old 11-23-2012, 04:48 PM
How is the quality of the ride?
Old 11-23-2012, 05:22 PM
cannonballcobb's Avatar
You may want to check this out...
I may have an easy fix for the ā€œDreaded Suspension Popā€ a lot of us are hearing, especially
car’s built in the fall of 2008.
The problem (for me at least) was in the sway bar end links. Thanks to Grey Ghost for the heads-up on this.
Here’s a picture of how it came assembled from the factory.
Looking from left to right is the ball socket, rubber boot, flange (rusty), washer, sway bar, nut and then the stud end (also rusty).
Report this image
The problem is that the stud is a smaller diameter than the hole it’s meant to fit in, for both the sway bar and the strut connection points. I’m sure some bean counter decided they could get away with it because ā€œno one would noticeā€ and they’d save a few pennies.
There is a tremendous amount of force exerted on this link, and it seems the factory ā€œsolutionā€ was to put a cheap washer on one side to spread the load and try to hold it in place. It didn’t work. When the stud was forced to move in the larger hole, the popping sound was born.
The fix is easy. You’ll need a 21mm box wrench and a 10mm socket. Since I didn’t have a box wrench in that size, I used a 21mm (or 13/16ā€) deep socket and Vise-Grips. The object is to make sure the stud (and therefore the ball socket) does not rotate when removing the nut. It’s probably best not to use an impact wrench for this to avoid spinning the stud. I easily held the stud stationary by clamping on to the ā€˜flange’ with the Vise-Grips.
Here’s a picture as it’s being disassembled showing the difference in size between the end link stud and the sway bar hole. (red arrow)
Report this image
When the end link has been removed from the car, just take a hammer and knock off the washer. It’s lightly press-fit on the ā€˜shoulder’ portion of the stud (red arrow) and will come off easily.
Report this image
Report this image
Why remove the washer? This is the answer to the whole problem. The ā€˜shoulder’ area of the stud is just the right diameter to fit in the sway bar and strut tower holes without any slop. The ā€˜flange’ on the stud will center it in place, so just re-assemble the end link without the washer and everything fits nice and snug. The washer could be used on the other (nut) side, but I left it off.
You'll use this same procedure for the upper connection point on the strut.
Report this image
I’ve driven the car now for a few weeks and put many hundred’s of miles on it and I’ve never heard that ā€˜poppingā€ sound again…not once.
I can’t guarantee it will work for you, but I found a solution that didn’t cost me a dime and I’m now a whole 4 washers lighter!
Old 11-23-2012, 05:56 PM
Variable's Avatar
Photos: (5)
Sexy!. She's Looking good.
Old 11-28-2012, 09:47 PM
Old School 1975's Avatar
Photos: (1)
Man that looks good! Love the gray R/T fender strip too!
Michael
Corsa Sport Catback and Eibach Pro Kit springs.
SOLD 76 Chevy Camaro, 496 BBC, 4L80E Trans, street driven to the track, 6.74 N/A 1/8 mile.
Old 11-29-2012, 12:29 AM
Thanks, the ride quality is great, but then again most of the cars I owned were lowered. A 78 Camaro, 94 Toyota Corolla and 03 Expedition. I found out, I didn't put the a washer between the shock mount and shock, no more noise... yay!! I'm getting a lot of ideas on different mods. I only had the car for 3 weeks and done over a 12 dozen mods. The biggest were the 2.5" dual exhaust and lowering it on H&R springs. Takes turns great, sway bars next. Waiting on my side markers tint from Big Worm.
Old 11-30-2012, 09:56 AM
What noise was it making? Also, do sway bars go under the car or behind the engine?
Old 12-08-2012, 12:25 PM
doughboy's Avatar
I sent you a pm...the drop looks soooooooo good man!!
2010 Challenger R/T T/A
Front strut bar,Airraid Intake t.b and spacer,Borlas,Diablo tuned, 392 chin spoiler, oracle red halos & fogs, hurst gunslinger shifter,custom made lexani LX15 20"wheels,BT catch can,kenwood double din touch screen,392 engine covers,Mopar T/A hood, Mopar Functional Ram Air Hood Kit,T/A side stripe kit,Blacked Out Spoiler,eibach sportlines w/bilstiens,hurst line lock
To Do list: Mopar hood pins,black fuel door
"I love my car F.T.W"
Old 12-08-2012, 12:35 PM
Yahooligan's Avatar
Do the 2009 6-speeds also have the black load-leveling Nivomat rear shocks? Something to check, if they are then you'll need to swap out your rear shocks if you didn't do that as part of the spring install.
Your car looks great! Stock height is just too high.
Old 12-08-2012, 05:48 PM
doughboy's Avatar
Mine is an 09 and after he answered my pm i went out and crawled under to be slightly dismayed by finding the nivomats in there..i mean there great shocks but I need to drop my bish baaaad!! I love the look of 707 hemis car..thats the exact look im going after...do you guys know of some good affordable rear shocks as replacements? they are only in the rear right?
h&r lowering springs part #50888 2012srt8chally Wheels, Tires, Brakes, and Suspension 10 02-02-2013 11:44 PM
SXT to SRT shock/springs or Eibach Sportline springs? escadan Wheels, Tires, Brakes, and Suspension 6 02-01-2013 03:53 PM
H&R lowering springs 2012srt8chally Wheels, Tires, Brakes, and Suspension 0 11-20-2012 07:44 PM
15 September 2012 - The Capon Springs Fire and Rescue 3rd Annual Car, Truck, Motorcyc GreatAmerican Mid-Atlantic 0 09-10-2012 08:36 AM
Lowered my 2012 SRT8 - some questions about alignment.. SRTDogg Wheels, Tires, Brakes, and Suspension 47 08-15-2012 02:50 PM
