Tire Pressure ???????????????? - Dodge Challenger Forum: Challenger & SRT8 Forums
Sponsored by: Discount Tire
post #1 of 7 (permalink) Old 10-29-2009, 07:51 PM Thread Starter
What is the correct tire pressure 245/40/20 fr, 295/40/20 r. currently TPMS shows 40 front and 42 rear. Thanks
kade is offline
post #2 of 7 (permalink) Old 10-29-2009, 08:12 PM
Look on the inside of the driver's door. There is a sticker listing tire size and correct tire pressure. Hope this helps.
onebadss is offline
post #3 of 7 (permalink) Old 10-30-2009, 09:25 PM
yladrd61's Avatar
Tire Pressure
Should be 32 psi if it is to high you lose ride quality and handling but get better mileage on the freeway. Get a good tire pressure guage TMPS is not very accurate.
'08 SRT8, #533, Black, All Options
JIMI
2016 SRT Hellcat 6.2L, 6 Speed Manual, Plum Crazy
Black Laguna Seats, Pirelli P Zero Summer Tires. [Delivered 12/31/15]
2013 Challenger SRT8, 6.4L, 6 Speed Manual, Plum Crazy [SOLD]
2008 Challenger SRT8 [#533] , 6.1L, 5 Speed Auto, Brilliant Black Crystal [SOLD]
"I don't do anything halfway" Lawrence Taylor #56 NY Giants
yladrd61 is offline
post #4 of 7 (permalink) Old 10-30-2009, 10:18 PM
Grey Ghost's Avatar
Well, the sticker inside the door jam is only accurate if you still have the stock tires on the car. Look at the sidewall of the tire, and the MAX pressure acceptable for that tire will be written on it. I run my tires on the high side, because that's how I like them. It helps improve fuel mileage, and I like the way they handle when they are pumped up firm. Less pressure will improve ride quality.
Grey Ghost is offline
post #5 of 7 (permalink) Old 10-31-2009, 12:53 AM
WICKDD's Avatar
I had an interesting 1st hand experience that showed me the importance of proper tire pressure. After getting my new suspension, tires and wheels, I was disappointed. The car had more understeer at the limit than stock, it just didn't handle as well. So I checked the tire pressure. 47 psi hot!!! The tire shop forgot to air the tires down after setting the bead with high pressure. I aired them down to 32 psi and it handles like a dream. I don't know the optimum pressure, but 32 psi cold is what I run. I agree with Grey Ghost that higher pressure will reduce rolling resistence, but I think performance suffers.
My Prized Ride: 2008 Challenger SRT8, Brilliant Black
Eibach Pro System Plus - Springs, Dampers, Sways
Vossen VVS-078 Wheels, Staggered, Silver with Stainless Lip
Front: 22" x 9" with 265/35ZR22 Dunlop SP Sport Maxx
Rear: 22" x 10-1/2" with 285/35ZR22 Kumho Ecsta SPT
WICKDD is offline
post #6 of 7 (permalink) Old 10-31-2009, 02:59 PM
JayR04's Avatar
Send a message via AIM to JayR04
cheap 22s don't like pot holes so I run mine pretty high.
Mods: 20% tint, removed resos, 7" touchscreen radio, Boss 329 22" rims, smoked tails, Phoenix Gold RSD65CS, 12" FI SSD, MTX 1000XD, Phoenix Gold V752.
PSN: JayR04
JayR04 is offline
post #7 of 7 (permalink) Old 10-31-2009, 03:51 PM
Too high pressure will cause premature center tread wear. You could also not be running on the full width of the tread as a result. Under-inflation causes the other treads to wear more.
General rule is for high speed operation/handling you can go about 4 PSI (cold inflation) above the recommended pressure above the sticker/placard on the vehicle.
Always check the tire pressure when COLD (not sitting in sun, not driven for 4 hours, etc) best to check after sitting overnight for lowest reading . I've observed PSI readings go up by 5 PSI over the cold reading per TPMS.
The max pressure molded into the sidewall is the MAX inflation pressure for installing/seating the bead on the rim by the tire installer.
Any higher than those posted pressures can cause seperation of plies within the tire's casing - not intended to be driven at those pressures (sometimes in the 50 PSI range) nor supporting the weight of the vehicle with the tires inflated at that high a pressure.
ALSO - check your cold pressure as your ambient temperatures (winter) drop. Every 10* of temperature will drop your PSI readings.
For example, the overnight lows in my area are mid 40s right now...in another month it can drop to low 30s/high 20s or lower if we get unusual weather.
Torred / Ruby Red/Black leather
Hal H is offline
Tire Pressure Alert stortzie Challenger Issues & Problems 12 06-14-2015 12:05 PM
Tire Pressure Monitoring Problem SanDiegoCharger Wheels, Tires, Brakes, and Suspension 10 10-06-2012 11:29 PM
Low Tire Pressure Light DallasRT Challenger Issues & Problems 5 09-19-2012 06:03 AM
Tire Pressure Sensor no_pulse Wheels, Tires, Brakes, and Suspension 5 08-22-2012 01:19 AM
Proper Tire Pressure. hans96791 6.1L (2008 - 2010) 24 08-17-2012 12:36 AM
