I know the 275/40 is popular, but who is running staggared 275/45's? I'm thinking of going with the stock size 245/45's in the front, and putting the 275/45-20's in the rear for that Old School staggered/raked look: the 275/45 is a little over an inch taller, and a little over an inch wider than the OEM 245/45.
If you have/had 275/45's on, please advise:
1. Is your Challenger lowered? If so, how much? Any problems with clearance?
2. Any issues with the ABS or TPMS, or anything due to the taller tires in the back?
3. What brand/model tire did you use, and the size of your front tires?
4. Please post PICS
I wouldn't want an inch taller tire. And for sure not on a lowered car.
Taller tire changes gear ratio and messes up speedo. Personally I'd try to stay within a percent or so of the stock height. I run 275/40 Nitto Invos and really like em. And I am lowered 1".
If there is no major loss in performance, I'd like to put the 275/45 on the rear - I like the beefier look, slightly taller sidewall height, and the slight slant of the car. But if I can't do it, I'll probably go for 255/45's or 275/40's on all fours.
Though I don't like the idea of losing any power, I tend to think the 1" height will only result in a minimal loss. What affect, if any, do you think it would have on MPG?
I agree. The 275/45/20 tire will throw your speedo off by almost 3 mph. When you are going 65 mph, it will read 67.41 mph. I would stick with the 275/40/20 tire. It will give you an accurate reading of 64.96 mph.
I'm running the 275/45 Cooper RS3 on 20x9 viper repo's on the rear of my SRT and have lowered a estimated overall 1.9" . No rubbing, flush , great traction , beefy tire. The morons mounted 245/40's on the front and I hate them and will be switching them to 245/45 or maybe even 275/45 and upgrade rears to 295
Looks good! Just to verify - other than the speedometer being a little off, the 275/45 caused no issues with braking, cruise control, ABS, TPMS, or anything else?
Also, could you please post a full profile shot, showing the "rake"?
I made a typo mistake in telling you the tire sizes. I have 275/40 on rear and 245/45 on front. I have no problems with tpms,handling, fitment , or braking. My speedometer was confirmed and matched my phone speedo app,myGig nav., and my garmin unit . As I said before though the front 245/45 are not as wide as I wanted for the 9"wheels
And as you can tell they tend to roll from the tread section over to the bead instead of being flush or rolling inward towards the bead. Tire place wouldn't change em because The car left on them before noticing. Here's a couple more shots from the side
Firerescue, that set up looks great on your car.:thumbsup:
I'm thinking of going 255/45's all around on an R/T Classic with the SRT WP3 Alcoas..
something is different between the SRT and R/T so I'm not sure if the 255's will
work on the R/T, any idea what the difference is? (steering knuckle?)
I wouldn't think there would be any as I thought the only difference between r/t and srt suspension was the strut/damper , springs and sway bars.
My buddy I car pool with has a R/t charger with 255/45/20 with chrome clad R/T wheels it's beefy lookin
I'm running 275/45-20 Michelins on Hurst 20 x 10 rims.
I've got the Mopar lowering springs installed, no issues.
On the 10" rim it's a little more than 1/2" larger o.d. Than the 255/45 stock tires.
I was wondering how much affect the rim depth has on the height/width of the tire. I'm guessing a 10" deep rim spreads the width and height of the tire about a half inch, as opposed to a 8.5" rim? I was hoping to buy 8.5" wide rims all around.
I just went to the 20" viper reps. Running 20x9, 245/45R20 on the front and 20x10, 275/40R20 on the rear. Im on Eibach Sportlines and dropped around 2" all around. Im on BFG comp 2's (great prices through Costco). No problems with tpms, rubbing, etc.
I was interested in the 275/45 mainly because it would show more sidewall and would raise the rear slightly. But I'll also be addng the Eibach lowering springs (about 1.5") at around the same time. I'm mostly concerned about losing power and/or MPG with that set-up; the speedometer innacuracy I can live with - it may help me not to speed. :wink2:
Of course there is the money issue: Comes July I'll be laying out a bit of green with new rims, new tires, and the springs. If I go staggered, I'll lose tire wear because I won't be able to rotate.
Haven't decided yet - and I have time still - but am also considering the safe bet of putting 275/40-20's on all fours.
In the meantime, let's hear more from the minority group out there that have the 275/45's - pics and suggestions/comments.
Another way to achieve the raked look is to go with adjustable coilovers. Spending a little more cash with coilovers gives you additional options on future tire sizes.
If I had to do it over again, coilovers would be what I'd go with...
Interesting idea, but the other reason I'm considring the taller tire is that it would add a little more to the sidewall profile - I like the beefier look.
I've got continental DWS 275/45/20 on the front and 295/45/20 on the back. It's a bit too much sidewall for me, so I'm going to same width, but 35 series sidewall. I also plan on getting KW V2's so I can go a bit lower, but I'm not sure if I will clear my current tires.
You can run the 275's easy... you can also step up a little more.. with the correct backspacing and tires. Mine are stock 245/45 front, 295/40 rear. A little rub on big bumps, nothing a little fender rolling wont solve.
I was going for the old school, step rim look...Most everyone who sees it, says I nailed the retro look.
I have a pair of 275's on order to be installed tomorrow evening, not sure if they are 45s or 40s, i'll find out when they install them. They are Nitto Motivos. The shop says they'll fit on the stock heritage rims, the nittos tend to look a little narrower. I put 245/45s on the front and they aren't wide enough for my tastes so I plan on trying a slightly wider tire for the rear. We'll have to see if it messes with the speedometer, if it does, i'll use the diablo tuner to compensate for it.
My motivos are 275 40 20s. They fit the heritage rims great, no bulging on the sides, and actually look like the rear tires have some width now.
