Huge upgrade!!! I had aftermarket rotors and pads. A Set Of Akebromo Brake pads and pro stop carbon rotors platinum all around my car.
So I decided to go with the new z26
Pro Stop Kit Including The Calipers As Well. Thicker Rotors,drilled & Slotted changed out the calipers in the rear,even though the calipers are the same size as the stock calipers
Ok it is Bolt on. CAN i just Buy the rotor and Would it fit my stock caliper and pads ? So they Make some for the front? Like bigger rotor or some thing like that?
I have the Z23 on mine and yes the dust is WAY less then the stock Brembo's, but they lack the initial bite and don't grab as well. If they had the Z26's for mine I'd give them a try.
Does anyone know if the Z26 is Made for a 2011-2014 charger? I Only find z23 in rockauto. I should Look elsewhere. Summit has them? What's the difference between the z23 and z26?
We would be glad to supply a set for you. If you have any questions on fitment just consult with our expert over the phone and complete your order! The tel# is in my signature
Any good options to replace 2010 R/T Classic w/STP, front rotors and pads only? I am unsure about the size of my rotors, I guess I have to measure them.
I installed on 2012 R/T stock calibrators, Power Stop K2560 - Power Stop Evolution Sport Z23 Front Brake Pad & Rotor Kits
High Performance Brake Upgrade Kit Cross-Drilled and Slotted Rotors
Z23 Evolution Sport High Carbon Ceramic Brake Pads, came with good hardware kit.
Front Kit, JEGS Part Number: 419-K2560, I drive past JEGS to work. $205 at my door w/OH tax.
I have 700 miles on them and for me it stops very good. Show little rust after a rain there old rears lot of rust.
I cleaned the hell out of the calibrators to remove rust under guides. I suggest a good course file to help clean so the guides are down on cleaned flat metal before adding hardware. I think the last rotors 28K went to hell because pads were not able to slide too much drag. Lot of rust under guides. The car was used and old Slots/Drilled were on the car. Outside looked ok the inside were a mess.
