Any Geeks in here? Computer upgrade? - Dodge Challenger Forum: Challenger & SRT8 Forums
Go Back   Dodge Challenger Forum: Challenger & SRT8 Forums > Off-Topic Area > Off-Topic Discussion
Off-Topic Discussion Anything not Challenger-related having legitimate subject matter goes here - must be work-safe. Post ALL social & 'just for fun' threads in the Chat Lounge ONLY). **NOTE: ALL forum rules apply in Off Topic - NO POLITICS**
Old 12-23-2012, 12:25 PM
I think the motherboard died in my desktop, it's a 5 year old Velocity Micro E2020 desktop and came with a nvidia nforce 570 sli MB and Intel Core 2 Duo E6400 chip, it won't boot at all, and won't put any power to the usb hubs to work the light on my mouse, before it died it was also shutting down while idle and then it comes back on right where it left off, I replaced the power supply and that did not help so I was thinking I might try doing a upgrade,can I get a MB to upgraded this to a modern i7 chip? I was looking at some online and the rear hookups are quite a bit different than my ATX case. Is there a modern replacement for my MB?
2012 R/T Classic Redline 3-coat pearl
Automatic
Super Track Pak
Anti-spin
Sunroof
Sound group II
DiabloSport Trinity
Resonator delete
Old 12-23-2012, 02:46 PM
Toxic11's Avatar
Feedback Score: 2 reviews
Send a message via ICQ to Toxic11 Send a message via AIM to Toxic11
ATX is still the standard and you can install anything up to ATX and in some cases even the expanded ATX (Consumer/Server) type Motherboards into an ATX assuming it has enough room.
Stick with ATX form factor Motherboards and you will be fine. It's as simple as changing out the rear IO Port (which comes with the new MoBo) and installing the new Mobo.
I highly recommend Asus, EVGA and Gigabyte MoBo's. I just got done doing a real nice Core i5 based on the new Asus Z series Mobo for one of my co-workers, it's a beast with 8 gig of OCZ Sniper Ram and a 160 Gig SSD. For his needs it's way fast.
An i7 with lots of ram an an SSD for the OS drive will last you years. I'm running an i7 laptop with 16 gig of system ram, 3 gig of video ram and a 128GB SSD (750Gig Data drive) and it boots in 10 seconds.
Brett DiMichele
2011 Toxic Orange
©2011-2029 A Sparkly Moose Beaver Production
www.toxic11.com
Old 12-23-2012, 05:08 PM
Brent60's Avatar
I also agree with the Gigabyte MoBo. They have a new... In touch Bios.... I believe that's what it's called but it's actually a bios you can use your mouse in and it actually has easy over clock settings. My I7 Gen II 2.8 is comfortably over clocked to 4.2 :-)
Also if your looking into new I7s I know mine has the "K" identifier after the number which means 1. It's allowed to be over locked without messing with the bios and 2. It came with a warranty from Microsoft encouraging you to over clock and if it fried anything they will replace it.
BTW you can pick up another 570 first cheap and SLi just make sure to have good airflow. Goodluck.
Sent from my HTC Rezound with the AutoGuide App.
Military Police - 2007-2012, Never Forget the Fallen
MODS: Roto Fab True CAI, Reso Delete w/ SRT Bottle Mids, Skip Shift Delete, Lock pick w/ Back up Cam, 392 Engine Covers Nate Rebadged 345.
Old 12-23-2012, 05:43 PM
Toxic11's Avatar
The Asus boards allow Bios Flashes right from the OS and the GUI in the BIOS is excellent. The board in particular I just used was the P8 Z77 VLE which supports
full overclocking in the Bios and in the OS, it can "auto" overclock (safely) or do extreme over clocking if you run Liquid Cooling. It also handles 6GB/S Sata, USB 3.0 and has Intelligent Pulse Width Modulation for supplying voltage.
I haven't dealt with Gigabyte Mobos in a few years but I know they are also a SOLID company. If I was building my own Gaming rig though, I'd go EVGA.
Old 12-23-2012, 08:11 PM
Thanks for the input, I was looking over the choices over on newegg.com and I'm not sure what to get, i7's with 22nm vs. 32nm Sandy bridge/Ivy bridge, I don't game but do run some rather intensive picture processing programs that need a lot of speed and ram. I want something simple to set up and air cool, any suggestions?
Old 12-24-2012, 07:39 AM
Photos: (1)
I always go Asus or MSI boards.
Newegg.com - MSI Z77A-G41 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Newegg.com - ASUS P8Z77-V LK LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
Newegg.com - Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I72600K - Sandy
Newegg.com - Intel Core i7-3770S Ivy Bridge 3.1GHz (3.9GHz Turbo) LGA 1155 65W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770S - Ivy
I don't use Intel because I'm cheap but ive heard the new Ivy bridge is about 5% faster at the same clock speed.
If you were going for gaming I would say i5 would be better.
2009 Stone White R/T
JLT Cold Air Intake | 180° T-Stat |SRT Hood Scoops
85mm Ported Throttle Body | Corsa Exhaust
Old 12-24-2012, 08:31 AM
Roomraider's Avatar
Asus For The Win!!!!
Kooks LT's,cat delete mids,Corsa Ext,Vint Hurst S/T "Pistol Grip",170 therm,BT Bling,Focal Audio,Henn CAI, Vint 70 Blk Hood buldge w/DODGE & 392 Hood emb,Blk Mopar 10 Hood Pins,Vint 70 Script fender emb,Blk SRT8 rr Spoiler,Lockpick w/rr cam,Webelectric Seq Litg,Magnuson SuperCharger,Arrington PCM Swap & Strut tower brace,Canton SC tank,Morosso xpan tank,braided w/AN
Pred Tuned by "HemiTuner A.J."572.7 rwhp/581.6 tq @ 8.1psi.boost
Old 12-24-2012, 09:20 AM
Madcoder's Avatar
When you boot up your computer does the power supply fan spin?
As long as the MB supports the CPU you're running then the ports in the back won't matter.
Newer MB's don't have PS2, printer or serial ports normally but most likely you don't have any devices that use them anyway
Depending on the software that you use to render/process images it may utilize the CPU or the GPU so find out before you dump too much money into a video card that doesn't get used.
Gigabyte is who I've used for years now. Good products, so-so support.
DD: '12 Challenger SRT8 in Brilliant Black Crystal Pearlcoat (Stock #s:416hp/414tq 13.0130@107.22)
- BT Catch Can, LMI 4" fender CAI, 84mm TB, 180 t-stat, DS 93 CAI tune
Project: 1993 Honda Del Sol
- 1.8L JDM GSR swap w/LSD, CAI.
DD: 2009 Challenger SRT8 in Brilliant Black - SOLD
DD: 1999 Porsche 911 Cabriolet - SOLD
Old 12-24-2012, 09:27 AM
Madcoder's Avatar
Normally the difference between MB's that can handle the same CPU have different types of technologies they can handle.
I.e. The new Ivy bridge supports PCIe 3.0 and DDR3L
Either way you're not going to notice a difference in your daily use between the two.
Old 12-24-2012, 04:20 PM
Toxic11's Avatar
Roomraider,
I don't think you have enough hoses inside that case.....
The Following User Says Thank You to Toxic11 For This Useful Post:
Roomraider (12-24-2012)
A quest for a Brembo Upgrade (My story) Chargerdude70 Wheels, Tires, Brakes, and Suspension 23 04-30-2013 11:11 AM
To upgrade or not to upgrade, that is the question PatrickY General Challenger Discussion 34 12-02-2012 04:55 PM
Yet another stereo upgrade post dart_man440 Audio, Video and other Car Electronics 3 08-05-2012 06:39 AM
FS: Challenger 10" Kicker Subwoofer Upgrade Steelios R/T Parts For Sale/Wanted/Trade 2 08-01-2012 11:59 AM
Computer rmfootball69 Interior Discussion / Modifications 8 10-28-2008 05:46 PM
