2008-2014 Dodge Challenger Technical Service Bulletins and Recalls
Includes all bulletins released through: July 23, 2014
Compiled by ResumeSpeed
Part 1. TSB's (Technical Service Bulletins)
TSB Date .. Model Yr … TSB # …............................ Description......................
07/17/14 … 1214 … #18-056-14 …. This bulletin involves replacing the Amplifier if required (SRT only)
07/15/14 … 1314 … #18-034-14a .. P0520- Engine Oil Pressure Sensor Circuit
05/09/14 … 1114 … #08-024-14 …. RHW RHP Radio Software Enhancements
04/15/14 … 0814 … #22-002-14a .. Tire Flat Spotting Identification, Prevention and Resolution
04/02/14 … 2014 … #18-027-14 …. Flash: Powertrain System Improvements/Enhancements
03/11/14 … 2014 … #18-015-14 …. Flash: Malfunction Indicator Lamp (MIL) Illumination. Includes Various Driveability Improvements (5.7L)
02/19/14 … 0814 … #22-001-14 …. Steering Wheel Vibration at Highway Speeds
02/13/14 … 2014 … #19-002-14a .. Steering Column Squeak / Moan While Turning Wheel (5.7L models)
12/10/13 … 2014 … #18-053-13 …. Flash: MIL Illum. P0606- Internal Control Processor / Auto Oil Change Indicator Accuracy (3.6L)
11/09/13 … 1314 … #08-087-13 …. Flash: Audio Enhancement, Reduce Audio Distortion
10/19/13 … 2012 … #08-070-13c .. RHR RHW Or RHP Radio Navigation Map Enhancements
07/30/13 … 2013 … #08-056-13a .. Flash: Cluster Incorrectly Displays Suspension And Shifting Track
06/11/13 … 2013 … #08-043-13 …. Flash: SRT Auto Transmission, Adding Launch Control Feature
06/11/13 … 2013 … #08-046-13 …. Flash: SRT Manual Transmission, Adding Launch Control Feature
05/15/13 … 0910 … #18-021-13 …. Flash: Performance Derate Above 55 MPH Immediately After Start-Up When Accelerating At WOT
05/14/13 … 0811 … #08-035-13 …. Flash: SRT Subwoofer Thump Noise After Vehicle Is Turned Off
05/11/13 … 1213 … #08-033-13 …. Flash: Two Or More Speakers Will Mute When Playing Certain Media Sources
04/20/13 … 1113 … #23-016-13 …. Driver And/Or Passenger Seat Fore/Aft Movement During Acceleration And/Or Braking
03/29/13 … 2012 … #08-021-13 …. Flash: Hands Free Module Customer Satisfaction Enhancements
03/06/13 … 1112 … #18-010-13 …. Flash: MIL Illumination P0340- Camshaft Position Sensor Circuit - Bank 1 Sensor 1 (5.7L/6.4L)
02/27/13 … 2013 … #23-011-13 …. Passenger Compartment Odor
02/12/13 … 2013 … #18-007-13 …. MIL Illumination P0300 and/or Engine Runs Rough With Factory Fill Fuel
12/20/12 … 2012 … #08-065-12 …. RHR Navigation Map Enhancements
12/15/12 … 1112 … #18-031-12a .. Flash: MIL Illumination P0108 - Manifold Absolute Pressure Sensor Circuit High
11/15/12 … 1113 … #08-053-12 …. Flash: RHR, RHW Or RHP Radio Software Enhancements
10/30/12 … 2012 … #08-050-12a .. Flash: Hands Free Module Prompts Begin To Play Without Pressing Phone Or Voice Recognition Button
10/30/12 … 2012 … #17-002-12 …. Incorrect Rear Ride Height
09/21/12 … 2013 … #07-004-12a .. Attention! Release Of New Engine Coolant Organic Additive Technology (OAT)
09/14/12 … 1112 … #23-028-12 …. Headliner May Droop 1/4" (6mm) to 1/2" (13mm) At Rear Edge Of Power Sunshade Opening
08/06/12 … 2012 … #08-050-12 …. Flash: Hands Free Module Prompts Begin To Play w/o Pressing Phone Or Voice Recognition Button
07/06/12 … 0912 … #03-001-12 …. Rear Axle Gear Whine
02/16/12 … 0912 … #22-001-12 …. Chrome Clad Wheel Adapters For Proper Balancing
02/09/12 … 2012 … #18-008-12 …. Flash: MIL Illumination P0441 - Evap Purge System Performance
01/10/12 … 0812 … #23-003-12 …. Light To Moderate Paint Surface Imperfections On Factory Applied Paint Finish (revised 02/07/12)
10/26/11 … 2011 … #08-036-11a .. Audio Device Compatibility Issues Including iPod and iPhone
10/18/11 … 2011 … #22-005-11 …. Chrome Wheel Delamination
10/18/11 … 2011 … #18-033-11a .. Flash MIL Illumination P2097 And/Or P2099 (6.4L)
10/06/11 … 2011 … #23-039-11 …. Door Smart Glass Self Cycling And/Or Battery Drain
08/20/11 … 2012 … #08-051-11 …. Radio Anti-Theft Codes - 2012 models
08/10/11 … 0811 … #23-031-11 …. Outer Door Belt Weatherstrip Cracked And/Or Drooping Down
08/06/11 … 2011 … #08-047-11 …. (DTC) B25AA-01, B25A9-01, Service Keyless System Message, Or Passive Entry Door Handle Inoperative
06/29/11 … 2011 … #08-036-11 …. iPod and iPhone Compatibility Issues
06/24/11 … 2011 … #18-033-11 …. Flash MIL Illumination P2097 And/Or P2099 (6.4L)
06/24/11 … 2009 … #18-032-11 …. Flash: MIL Illumination For P2181 - Cooling System Performance
06/21/11 … 2011 … #25-001-11 …. Incorrect Positive Crankcase Ventilation Valve (PCV) Installed (6.4L)
06/16/11 … 0910 … #18-031-11 …. MIL Illumination for P0128 - Thermostat Rationality
05/19/11 … 2011 … #08-024-11 …. Flash: Intermittent No Start Or Intermittent RKE Function
05/05/11 … 2011 … #08-020-11 …. SiriusXM™ Travel Link™ Update Policy
05/03/11 … 2011 … #23-017-11 …. Missing T-Handle Shift Knob, Pedal Kit, Floor Mats, Car Cover And Door Sills
04/18/11 … 2011 … #18-020-11 …. Flash: MIL Illumination And Driveability/Transmission Improvements
04/06/11 … 2011 … #08-015-11 …. Loss Of Communications With HFM
03/29/11 … 2011 … #18-018-11 …. Flash: MIL Illumination For Any P06DD, P0522, P0108, P1239 (3.6L)
03/15/11 … 2011 … #08-002-11 …. Decklid Can Be Opened Without The Key Fob Being In The Proximity Of The Vehicle
02/16/11 … 2011 … #07-001-11 …. Coolant Weepage At The Coolant Reservoir Hose
02/11/11 … 2011 … #18-008-11 …. Flash: Idle Boom Condition (3.6L) (supersedes 18-024-10)
02/05/11 … 0910 … #18-005-11 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor (3.5L) Intermittent Set
11/02/10 … 2010 … #08-028-10a .. RBZ Radio Software Enhancements
10/30/10 … 0910 … #18-029-10 …. Flash: MIL Illumination P0138 And/Or P0158 (3.5L)
10/21/10 … 0810 … #23-018-10 …. Lower Door Hinges Make Popping or Groan When Opened Or Closed
08/13/10 … 2010 … #22-003-10 …. Slight Vibration at Highway Speeds (18" wheels)
07/28/10 … 0910 … #19-005-10 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers (5.7L RWD)
07/28/10 … 0910 … #08-020-10 …. Remote Start Intermittently Inoperative
07/23/10 … 0910 … #18-024-10 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
07/08/10 … 2009 … #18-015-10b .. Flash: MIL Illumination For P2181 - Cooling System Performance (3.5L)
06/28/10 … 0810 … #08-014-10 …. REN and REZ Radio Lock Up. Flash Radio with DVD Update Disc
05/14/10 … 2010 … #08-010-10 …. Flash: WIN Module For Intermittent RKE Functions
04/30/10 … 0910 … #08-008-10 …. Flash: Amplifier for Speaker Distortion
04/28/10 … 2009 … #18-014-10 …. Flash: Engine Runs Rough At Low RPM or MIL Illum. For MDS Reactivation and Misfire DTC's (5.7L)
03/27/10 … 2010 … #18-008-10 …. Flash: MIL Illumination Or Failed/Rejected At State I/M Test Station Per Symptom/Conditions
12/11/09 … 2009 … #18-021-09a .. Flash: MIL Illum And/Or MDS Driveability Improvements And/Or Shift Improvements (supersedes 18-021-09)
11/05/09 … 2010 … #18-032-09 …. Flash: MIL Illumination P0133 And/Or P0153 (SRT8 6-speed)
10/15/09 … 2009 … #18-030-09 …. Flash: Driveability Improvements (SRT8)
09/15/09 … 0910 … #05-002-09b .. Pre Delivery - Front Brake Rotor Corrosion Inspection & Procedure (supersedes 05-002-09a)
09/01/09 … 0809 … #14-001-09a .. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly (supersedes 14-001-09)
08/13/09 … 2008 … #08-013-09 …. Flash: Incorrect Translation For "Oil Change Required" On EVIC Display In Spanish & French Language
08/01/09 … 2009 … #19-004-09 …. Steering Wheel Returnability
07/29/09 … 0809 … #22-002-09 …. Chrome Clad Wheel Adapters For Proper Balancing
07/11/09 … 2009 … #18-021-09 …. Flash: MIL Illumination And/Or MDS Driveability Improvements And/Or Shift Improvements
07/10/09 … 2009 … #19-003-09 …. Steering Gear Honk, Hiss or Groan During Low Speed Parking Lot Maneuvers
07/09/09 … 2009 … #18-006-09a .. Flash: MIL Illumination For P0307 And/Or P0133 And/Or P0153 (supersedes 18-006-09)
05/28/09 … 2009 … #21-005-09 …. Flash: Harsh 4-3 Shift And Shift Quality Improvements
04/15/09 … 2009 … #14-001-09 …. Hard To Fill With Fuel Or Fuel Nozzle Shuts Off Repeatedly
03/31/09 … 2008 … #23-006-09 …. Decklid Spoiler Fit
02/13/09 … 0809 … #08-003-09 …. MyGig REN or REZ Radio Inoperative After Battery Disconnect
02/11/09 … 2009 … #18-006-09 …. Flash: MIL Illumination For P0307 - Cylinder 7 Misfire (SRT8)
01/29/09 … 2009 … #18-002-09 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (SRT8)
11/22/08 … 2009 … #18-040-08 …. MIL Illumination DTC P0339 - Crankshaft Position Sensor Intermittent Set (3.5L)
11/04/08 … 0809 … #05-005-08 …. Flash: ESP Lamp Flashing While System is in Full Off Mode Or ESP Pump Howl, Groan Sound After A Turn
10/21/08 … 2009 … #08-031-08 …. Flash: Trip B Functionality Does Not Reset Using The Odometer Knob
10/08/08 … 2009 … #21-022-08 …. Torque Convertor Shudder On Vehicles With Less Than 4000 Miles (4-speed only)
09/18/08 … 2008 … #08-028-08 …. Voice Recognition Screen Lock-up on REN or REZ Radio Equipped With Uconnect
09/17/08 … 2008 … #21-021-08 …. Automatic Transmission Diagnostic Tear Down Procedure
08/29/08 … 2008 … #08-027-08 …. UConnect and Voice Recognition Inoperative
08/20/08 … 2008 … #08-025-08 …. Keyless Go Feature Inoperative
08/07/07 … 2008 … #23-035-07 …. Exterior Lamp - Lens Fogging
03/08/06 … 0809 … #23-014-06 …. Windshield Wiper Blade/Element Maintenance
Part 2. RECALLS
RCL Date .. Model Yr .. Recall # ….......................... Description......................
02/12/2014 … 0912 … RC-P01 …... Engine Timing Chain and Chain Guide
05/00/2013 … 1112 … RC-N07 ..…. Seat Wiring Harness Connectors
04/00/2013 … 2013 … RC-N18 ..…. Engine Starter Battery Positive Terminal
08/00/2010 … 2011 … RC-K08 ..…. Wireless Ignition Node Receiver
11/00/2009 … 0910 … RC-J27 ….... Front Wheel Hub Nuts
02/00/2009 … 2009 … RC-H41 …... Tire Pressure Monitor Sensors
09/00/2008 … 0809 … RC-H29 …... Reprogram Wireless Ignition Node (USA)
09/00/2008 … 0809 … RC-CH29 …. Reprogram Wireless Ignition Node (Canada)
Part 3. Rapid Response Transmittals
RRT Date .. Model Yr … RRT # …............................ Description......................
06/11/10 … 2010 … RRT-10037 …. Low Power Steering Fluid
05/25/10 … 2010 … RRT-10030 …. RBZ Radio – Direct Tune Buttons Inoperative
04/23/10 … 2010 … RRT-10024 …. Manual Transmission Pops Out Of Second Gear
04/22/10 … 2010 … RRT-10023 …. Cruise Control Inoperative
04/19/10 … 2010 … RRT-10022 …. Flash: WIN Module (Intermittent FOBIK Functions)
03/25/10 … 2010 … RRT-10019 …. RBZ Radio - Video Disable
02/26/10 … 2009 … RRT-10013 …. Sunroof Mechanism Cover Loose and or Cracked
02/08/10 … 2009 … RRT-10006 …. Steering Wheel Returnability
11/11/09 … 2010 … RRT-09085 …. Center Console Lid
10/19/09 … 2009 … RRT-09047b .. Roof Molding Paint Cracking (supersedes 09-047)
10/14/09 … 2009 … RRT-09073 …. Flash: Driveability Improvements (SRT8)
09/28/09 … 2009 … RRT-09066 …. Grille Blister
09/17/09 … 2009 … RRT-09060 …. Sun Visor Vanity Mirror Cover Looseness
09/11/09 … 2009 … RRT-09059 …. 5/100 Powertrain Warranty (Owner Manual Kit Replacement)
08/12/09 … 2009 … RRT-09047 …. Roof Molding Paint Cracking
08/10/09 … 2009 … RRT-09046 …. Deck Lid Misalignment
08/04/09 … 2009 … RRT-09043 …. Flash: PEM Module ("Key Not Detected" issue)
06/03/09 … 0809 … RRT-09037 …. Passenger Side - Heated Seat Wire Retention
05/01/09 … 2009 … RRT-09028 …. Door Glass Chip
04/29/09 … 2009 … RRT-08098a .. Right Outside Rearview Mirror Loose (supersedes RRT-08-079)
04/07/09 … 2009 … RRT-09019 …. No Start, Hard Start, Long Crank (See CSN-J21)
03/30/09 … 2009 … RRT-09018 …. MYGIG Radio - Splash Screen Frozen or Locked Up With Battery Drain
02/11/09 … 2009 … RRT-09009 …. Flash: MIL Illumination With DTC P0307 - Cylinder 7 Misfire Set
01/23/09 … 2009 … RRT-09005 …. Right Camshaft Not Built To Proper Specification
12/22/08 … 2009 … RRT-08098a .. Flash: Whistle Sound From Engine Compartment/Purge Solenoid
11/10/08 … 2009 … RRT-08088 …. “DODGE” Lettering Loose On Rear Deck Appliqué
10/09/08 … 2009 … RRT-08079 …. Right Outside Rearview Mirror Loose
09/25/08 … 2009 … RRT-08077 …. Sirius Satellite Radio Inoperative
08/22/08 … 2008 … RRT-08066 …. RKE FOBIK Loss Of Keyless Entry Function
Part 4. Customer Satisfaction Notices
10/00/2012 … 2011 … CSN-M24 …. Smart Glass Switch
03/00/2012 … 2012 … CSN-M04 …. Engine Oil Addendum Card and Tip Card (SRT)
03/00/2012 … 2011 … CSN-L28 …. Front Exterior Door Handles
05/00/2011 … 2011 … CSN-L19 …. Floor Mats
04/00/2011 … 2011 … CSN-L10 …. Coolant Reservoir Outlet Hose
04/00/2010 … 2010 … CSN-J36 …. Audio Control Switches
11/00/2009 … 2009 … CSN-J21 …. Hot Start Engine Cranking (replaces RRT-09019)
Part 5. Miscellaneous issues
TT Number .. Model Yr ….…................................... Description......................
TT9002047 … 0809 … Door glass freezes to outer belt molding when vehicle subjected to rain then freezing temperatures (Application of (AQUAPEL) glass treatment to the outer door glass surface)
TT9001995 … 2009 … Taillamp letters falling off (Letters available individually, D= P/N 68060396AA, O= 68060397AA, G= 68060398AA, E =68060401AA
TT9001970 … 0809 … Seat cushion to seat back frame bolts too long (New shorter replacement bolt available, p/n 68039245AA)
TT9001942 … 0809 … Rear fascia wavy/warped (Fascia is not defective, black surround trim piece is the root cause)
TT9001825 … 0809 … Rear speakers inoperative, balance not working (Select stereo mode in EVIC and recheck sound from rear speakers)
TT9001932 … 0809 … Ticking or buzz noise in engine compartment when cooling fan running, vehicles built before 7/31/08 (Check the upper radiator seal, move up & back into position if necesssary)
TT9001897 … 0809 … Fuel fill door rubber bumpers (Rubber bumpers are serviced separately by ordering P/N 68054811AA)
TT9001868 … 0809 … A-pillar gauge pod, Mopar p/n 77060062, interference with side air bags (NOT compatible with 2008-2009 Challengers)
TT9000723 … 0809 … Decklid - hard to close or binding condition (Adjust striker if binding; chk emergency trunk handle to verify cross-car play to insure decklid will latch)
K55325103 … 2009 … Unable to shift vehicle out of park (body wiring harness in drivers kick panel may contact parking brake assembly, chk wiring)
Chart notes:
Model Year:
Model Year "2008" = 2008 models
Model Year "2009" = 2009 models
Model Year "2010" = 2010 models
Model Year "2011" = 2011 models
Model Year "2012" = 2012 models
Model Year "2013" = 2013 models
Combo examples:
Model Year "0809" = 2008 and 2009 models
Model Year "1112" = 2011 and 2012 models
Important:
Some bulletins may apply only to specific production dates, models and/or equipment. Not all affected vehicles will exhibit described problems, failure rates may vary widely. Not all bulletins involve repair issues, some are issued for informational purposes only.
TSB's are not Recalls. "Preventive" service repairs will normally not be performed under warranty if a vehicle is not exhibiting the particular symptom or problem.
For vehicles that are out of warranty, any TSB related work that is performed is usually charged at the normal dealer service rate.
--Compiled and maintained by ResumeSpeed.
Part 2. RECALLS
Chart notes:
Model Year:
Combo examples:
Important:
