Front hood bumper seal - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 24 (permalink) Old 03-25-2015, 09:49 AM Thread Starter
I finally found out what the noise was in the front appearing to be coming from the dash. It was the front hood rubber seal bumper being sucked out and flapping against top of hood. I have a 2010 challenger SE and I Ned a part number for this seal. Also, what sized of plastic rivets do I need ? I want to do this myself to avoid being robbed at the squealership.
One guy online says it takes two different sized rivets in the end and the rest are another size. Any opinions ? I would need the bumper and rivers and rivet gun.
Challydeano is offline
post #2 of 24 (permalink) Old 03-25-2015, 10:41 AM
zimbo's Avatar
Give a shout to Steve White Motors - Luke will certainly be able to help you with this.
MODS: Re-done interior, Hurst shifter, aeroforce guages, custom dash guages, Speedlogx ram air hood, custom true-fire paint under hood and trunk deck, chrome 6.1 intake, Arrington TB, CC, polished valve and coil pack covers, strut tower brace, JBA shorty headers with high flow cats and mid pipes,HHP tune, BT stainless engine bay parts.
These forums are keeping me broke!
zimbo is offline
post #3 of 24 (permalink) Old 03-25-2015, 10:59 AM
Sudz's Avatar
Dodge Challenger Hood Front Fascia Bumper Seal Weatherstrip with Rivets Mopar OE | eBay
2014 R/T Bright White 28F, STP, Anti-Spin, 4861940AC, 82211622, 82211234, 82211683AC, 82211684AD, BT Catch Can
Sudz is offline
The Following User Says Thank You to Sudz For This Useful Post:
jgraham70 (03-29-2019)
post #4 of 24 (permalink) Old 03-25-2015, 12:36 PM
SRTbatmobile's Avatar
Feedback Score: 2 reviews
This is a common problem. Probably a million threads on this if you search the forum. Most parts depts will carry the seal for a couple bucks. Get the rivets from online rather than the $5-7 a piece at the dealer. I used christmas tree style clips that you can purchase from an autostore instead of the rivets. Easier to replace later on if the same thing happens and still looks like a factory install.
2010 Challenger SRT8 6M Brilliant Black
Personal Best: 12.92 @ 108.6
Performance: Zoomers (Modified), LMI Hammer, Trinity w/ Johan Tune, 180 T-Stat
Wheels: Black Chrome Alcoa SRT, Staggered BFG Comp2's, SRT Center Caps, Black Lugs
Appearance: BT Catch Can w/ Z-Bracket & Braided Hoses, SRT Nose Badge, Satin Black Fuel Door, Sequential Tail Lights, LED Lights, Big Worm Tints, 20% Window Tint, RPI Mud Guards
SRTbatmobile is offline
The Following User Says Thank You to SRTbatmobile For This Useful Post:
post #5 of 24 (permalink) Old 03-25-2015, 03:04 PM
What SRTbatmobile said. The weatherstrip from Dodge isn't all that bad, like 30 bucks or so. But those $8 rivets are absolutely RIDICULOUS! Harbor Tool and Freight sells the gun and the rivets in a kit for like $15 total. Or you can just use any old Xmas tree rivets.
Funny story: I had mine replaced under warranty. Picked up the car and the seal looked wrong, with a bulge? I pop the hood and the attention to detail "Technician" had missed the rivet hole on the end. I told the service guy to fix it and guess what, they ran out of the rivets. I told him GREAT WORK! I'll fix it the right way myself. Drove to Harbor, bought the rivet gun and installed the rivet through the hole.
Confidence very low in my local Dealer Service Department.
Topshelf22 is offline
post #6 of 24 (permalink) Old 03-25-2015, 05:32 PM
swiftjr's Avatar
Send a message via Skype™ to swiftjr
Here's my how to with links to the parts.
https://www.facebook.com/media/set/?...5013764&type=3
2009 R/T Deep Water Blue 6-Speed (Only 450 made in this trim in 2009)
20" Foose Legend Wheels and HD Brakes
Drilled and Slotted Rotors with Ceramic Pads
Hurst Linkage w/ G & K Mods and Hurst Pistol Grip Shifter
Lowered 1.7" with Eibach Springs and Sway Bars
Blue BT Catch Can-K&N Air Intake-Cabin Air Filter
Mopar Exhaust Tips,Caps,Front Badge,Steering Wheel,and Fuel Door Insert
Caliper Covers, Polished Stainless Steel Under the Hood
swiftjr is offline
post #7 of 24 (permalink) Old 03-25-2015, 07:33 PM
ns1aar's Avatar
Or you could just leave it off.
09 DWB 6sp R/T
70 AAR Cuda
70 Cuda Vert
ns1aar is offline
The Following User Says Thank You to ns1aar For This Useful Post:
SoCalChallengerLover (09-09-2016)
post #8 of 24 (permalink) Old 09-08-2016, 05:12 PM
Nice pic of your Cuda. We have a 1970 Cuda - 383 Convertible with automatic. Just had her repainted in the original Burnt Orange Metallic color. She is amazing!
Anne Harper Knowles is offline
post #9 of 24 (permalink) Old 09-09-2016, 12:57 AM
SoCalChallengerLover's Avatar
Why bother replacing, they only last about a year.
"If the PC game is called "FINAL Fantasy" why are there 15 versions of it??"
PAST PLEASURES......
2014 Bilitt Silver Rallye Redline
2016 Jazz Blue Purple Stripe SXT PLUS
CURRENT RIDE....
2018 Torred R/T
SoCalChallengerLover is offline
post #10 of 24 (permalink) Old 09-09-2016, 05:04 AM
Cuda340's Avatar
Here is a cheap and permanent DIY solution to the problem that was previously posted by one of our members.
Instead of paying the dealer $70+ for a flimsy rubber strip that will eventually dry out and crack, simply buy thin 2 1/4" weather stripping for garage doors. It's angled and can be attached below the plastic retainer, as well as on it, using 3M double-sided tape. The material is made to withstand constant exposure to the elements as well as weight resting on it.
Here is a photo of it installed.
Cuda340 is offline
The Following 2 Users Say Thank You to Cuda340 For This Useful Post:
mval (09-09-2016), tdubi708 (09-10-2016)
Front Hood/Nose seal replacement. swiftjr How-To, DIY and Tips & Tricks 5 09-08-2014 06:39 AM
front end facelift- Do I need to pull the bumper to get out grills go carbon fiber teddyca Exterior Discussion / Modifications 3 11-23-2013 04:49 AM
