Front hood bumper seal - Page 3 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #21 of 24 (permalink) Old 04-04-2019, 11:12 PM
PFJsCustoms's Avatar
Originally Posted by 009SRT View Post
I don’t use the plastic rivets. I installed nutplates and I use screws to hold the seal in place.
The problem on the newer model challengers was not the rivets but rather the hood seal just wearing down with the sun. After that the seal just splits and it started to flap around.
PFJsCustoms is offline
post #22 of 24 (permalink) Old 04-06-2019, 07:04 PM
009SRT's Avatar
#10 screws
009SRT is offline
The Following User Says Thank You to 009SRT For This Useful Post:
Tshane72 (04-07-2019)
post #23 of 24 (permalink) Old 04-07-2019, 03:54 PM
Tshane72's Avatar
#10 screws
So when you popped out the old rivets to put on the new hood seal and you just used screws? Do tell....has it worked well?
Tshane72 is offline
post #24 of 24 (permalink) Old 04-08-2019, 07:57 AM
009SRT's Avatar
While the car was in the body shop and the new grille assy. arrived. I installed #10 nut plates with #3-4 pull rivets where the plastic factory rivets go in to the bumper assembly into the grille. Installed the new hood seal using #10 machine screws and it worked well. No need for any other tool except a Phillips screw driver to change out the next hood seal.
Dodge should have done this at the factory....
I posted pictures in post #20 in this thread of the nutplate install.
It’s easy to install the nut plates with the grille assembly removed from the bumper.
The entire front end was removed from the car at the time I did this mod.
1. Locate the holes in the bumper.
2. Drill the holes with a .250 drill bit
3. Fit the nutplate and drill the pull rivet holes with #40 drill bit
4. Countersink the pull rivet holes for the river countersunk heads
5. Install nut plates with 3-4 countersunk pull rivets with rivet puller
6. Reinstall the front bumper assembly on the car
7. Locate hood seal onto bumper assy
8. Install #10 machine screws through the strip and seal. Do not over tighten screws. Bam 💥 Done.
ID:	943113   Click image for larger version
ID:	943115   Click image for larger version
ID:	943117   Click image for larger version
ID:	943119   Click image for larger version
009SRT is offline
Front Hood/Nose seal replacement. swiftjr How-To, DIY and Tips & Tricks 5 09-08-2014 06:39 AM
front end facelift- Do I need to pull the bumper to get out grills go carbon fiber teddyca Exterior Discussion / Modifications 3 11-23-2013 04:49 AM
