Direct Fuel Injection - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
Articles - Engine, Other Everything else relating to engines
post #11 of 20 (permalink) Old 11-21-2013, 05:13 PM
i know this is a old post but DI is superior for fuel milage,emissions as well as power. and yes you do get oil build up on the valves as well as carbon. im a diesel mechanic for 25 yrs and have seen the evolution of DI. from its simplest form to todays systems its a beast. but with that said we still have power loss due to carbon/oil build up on valves.. till we can figure out a way to do away with lubricating the valve stem or removing valve completely this will always be a issue. it just needs to be a common practice to do a motorvac or equivalent procedure to take care of the issue.
killerride is offline
post #12 of 20 (permalink) Old 11-26-2013, 04:04 PM
rscarawa's Avatar
From what I am reading, not all DI has carbon buildup issues on the valves. For instance, I have heard that GM's version does not. Seems like a problem more with the VW/Audi design than a DI design issue.
rscarawa is offline
post #13 of 20 (permalink) Old 11-26-2013, 04:44 PM
RWL11's Avatar
Isn't this what a Catch Can helps to reduce, these deposits, as quoted from the above article?: "DI engines are prone to forming oily deposits on the intake valves, unlike in port fuel-injected engines, where a constant spray of fuel into the port allows any deposits to wash away." The PCV (Postive Crankcase Ventilation) Valve sends these crankcase vapors, which are caused by piston ring blowby and oil vapors (if I remember correctly), into the air intake and travels into the combustion chamber to be burned by the combustion of fuel. As these oily vapors travel across the valve, these are what contribute to these deposits, correct? Maybe not causing 100% of the deposits, but a major portion I would assume, in any PCV equipped engine.
I am in no way an engine expert, but from what I do know from working around the garage on various combustion engines, anything that helps reduce the oil vapors from traveling into the intake runners will help reduce these deposits on the intake valves.
Any thoughts on this? Why not add a catch can system on a DI engine to help reduce these deposits, or is their a mandate that a PCV be used to keep these fumes from being sent into the atmosphere like they were before PCV valves? I know from reading up on Catch Cans, the auto makers wouldn't want to add a Catch Can and require it's emptying. Too many people would forget or neglect to perform this needed maintenance.
EDIT: If I had read the entire article first, I would've found this: "All modern gasoline engines return some crankcase and exhaust gases back through the intake manifold in order to help control emissions, but, according to Chick, some exhaust-gas recirculation designs are “dirtier" than others. Some, he said, are less-effective at preventing the passage of tiny bits of oil, carbon and other particulates that eventually get baked onto the intake ports and valves."
RWL11
PDX, OR
2016 R/T Scat Pack, A8
Belle II
Drake All-Satin Fuel Door with Billet Tech Fuel Door Insert, EZ Pull Trunk Straps, Razor's Edge Front Strut Bar, Mopar Bright Pedal kit, Splash Guards, Door Sills, WP3 wheels & Hellcat Airbox with aFe Power Dynamic Air Tube and Merrick Motors Torred inserts. Tint & Clear Bra by Tommy's. DD XML2 Fogs. Billet Tech Engine Bay Dress Up Kit. Hurst Quad Tips. Silver Leaf Stripes by Mitch Kim.
"there are many like it - but this one is mine"
RWL11 is offline
post #14 of 20 (permalink) Old 01-29-2014, 02:59 PM
SRT8Tech's Avatar
GM still has a major problem with the DI cars. GM says they don't but the mechanics I know see major carbon build up still to this day on the DI GM stuff. A catch can will help but its only a matter of time before there is carbon build up again. A lot more going on other than just the intake charge carrying the oil in.
I will NOT buy a car with DI until its proven that there is no more carbon build up problem. Right not its no where near fixed.
2007 Procharged SRT8 Charger..........SOLD
2010 Mopar 10 Challenger.................SOLD
2010 R/T Classic Challenger...............SOLD
2011 392 Challenger.........................SOLD
2012 mid 10 second 1/4 mile GT500.... SOLD
Current ride
100% stock 2013 Plum SuperBee............best of 12.407 @ 114.28
With drag radials, tune and CAI...............best of 12.008 @ 115.74
SRT8Tech is offline
The Following User Says Thank You to SRT8Tech For This Useful Post:
salvy59 (01-29-2014)
post #15 of 20 (permalink) Old 02-02-2014, 10:18 PM
Direct injection is awesome, for like a year. Just did a carbon cleaning on a VW 2.0L FSI engine with 40k miles on it. Im a mech. at VW and we do those on the regular. Got a used Cadillac 3.6 DI in that needs a carbon cleaning too. Its a big issue with any direct inject car really. And is it worth it? Chrysler is making 300hp with a v6 that gets 30mpg...with MPI. That Cadillac is also a 3.6. Same power (i think, nothing greatly different) Gets the same, if not less gas mileage and its direct injected...more stuff to go wrong if you ask me. The injectors are a PITA to service also. Personally, from a mechanics POV its not worth the effort. The little Direct Injection badges look and sound cool though. On the plus side, Audi's new FSI motor contains DI and MPI for both efficiency and valve cleaning lol. Talk about over engineered.
eviper21 is offline
post #16 of 20 (permalink) Old 02-28-2014, 07:10 AM
Flat Top's Avatar
Alot of the timing we see pulled in our is from the oil/carbon build on the pistons.
I have 5000miles on the new motor, catch can always been on it.
In 5000 miles the oil the CC misses, is on my piston tops right now. Causing ST timing to be pulled.
This is why I dont vent into my motor anymore. I vent to open air and use a electric vaccum pump. Look for a thread write up soon on this issue of carbon and decarbon the motor and one for the vac pump system I use..
FlatTop
Flat Top is offline
post #17 of 20 (permalink) Old 03-02-2014, 08:47 PM
FlatTop
Very interesting cant wait to see your post/write up on this.
brandy16 is offline
post #18 of 20 (permalink) Old 06-29-2014, 06:53 PM
Does anyone know if someone makes parts to fit a viper motor into a 3.6l challenger or knows someone who can do it? If I can get a viper motor, trans, and harness
repoman1 is offline
post #19 of 20 (permalink) Old 08-08-2014, 02:38 PM
GSMC's Avatar
The only experience I have with DFI (if you want to call it that) is with my wife's '13 Kia Optima I bought last year. It has a tiny 1.8 liter turbo and makes 276 HP!! Gotta be honest, I'm truly impressed with that little engine. A couple guys with a chain and a 2x4 could yank that engine out! :yes nod:
At least I got the lifetime warranty in case it does decide to "carbon up" down the road. So far so good though, but it only has a bit over 14K on it.
USN - Retired
'15 SRT Hellcat, Jazz Blue A8
Other Cars:
-1983 Camaro Z28 Magnacharged 408
-2000 S-10 4WD 4.3 V6
GSMC is offline
post #20 of 20 (permalink) Old 09-06-2014, 08:54 PM
Originally Posted by rscarawa View Post
I know oil builds up on my truck's throttlebody too. How does oil get in there?
Is this a problem on all direct injection motors or just certain brands?
It is due to intake air pulse reversion. It is a feature of any naturally aspirated four stroke engine that uses old tech intake and exhaust valves. The valve coking problem on DI engines has not been resolved yet to my knowledge.
The valve coking is one problem where I think a oil catch can could possibly help, however valve face and seat life will be shortened.
Sometimes new technology brings new problems.
workerunit is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > TECH Exchange > Articles - Engine, Other
Pulling Fuse #2 Q8Chally Performance Modifications 69 05-11-2018 10:49 AM
Goodbye, V-8s, the Engines That Could GreatAmerican General Challenger Discussion 111 03-08-2015 06:26 AM
Speedlogix Billet Fuel Rails - 5.7, 6.1, 392 Challenger SRT8U Speedlogix 17 04-10-2013 10:09 PM
Fuel pump replaced at 2700 miles!!! SunCityChally Challenger Issues & Problems 8 09-07-2012 07:37 PM
