Input before upgrading - Page 2 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #11 of 19 (permalink) Old 06-03-2019, 06:02 PM
Tshane72's Avatar
Originally Posted by hemi1031 View Post
Thanks Tshane and also for yours. We head d back to our home in Pinehurst, so perhaps we’ll be able to meet up sometime up in your area, grab some coffee and talk about the cars. We make trips up to the triangle every so often, mainly to hit up the stores that we don’t have down by us or just to get out of the house.
Tim
Sent from my iPad using Tapatalk
Actually I'm a little south and east of Pinehirst, I live in Hope Mills, just south of Fort Bragg...about an hour from you so that's pretty close! We'll definitely have to get together sometime! Have a safe trip back to the states!
Tshane72 is offline
post #12 of 19 (permalink) Old 06-04-2019, 11:22 PM Thread Starter
hemi1031's Avatar
So it seems I am am missing some of my notes and photos. With that being said this may end up not being as thorough of a write up as I intended. So hat I am going to do is wait till I get back stateside and have my own big garage (compared to typical German garage) to work in. I will go through the process again and ensure that I do not lose my notes, maybe I’ll give recording the process a try.
Reason being for doing this..... The sway bars are squeaking pretty bad anyhow and need more grease on them. Also, there is some clunking sounds, but not the same as when the sway bar bushings are bad. I believe it is the fact that I am installed adjustable sway bar end links. There are no bushings on them, so it’s metal to metal. At least this is my assumption. If anyone has other ideas please let me know. I am also wondering if the noise is due to what I believe it is, is there a solution? It sounds as though parts are loose. Perhaps I should switch to non-adjustable end links that have bushings? Any thoughts are welcome.
Once again I apologize for the delay in a write up. Hopefully the end product will help folks in the future.
Tim
2013 Challenger SRT8-Airaid CAI, Hurst Short Throw Shifter, Zoomers Cat-Back Exhaust, Mopar Stage 1 Lowering Springs, BT Catch Can, BT under hood dress up kit, Petty’s Garage Front & Rear Sway bar, Petty’s Garage bolt on Sub-Frame Connectors, SX/Razors Edge Front & Rear End Links, SX Rear Tension Arms, SX Front & Rear strut/shock tower braces, Diablo 93 canned tune, Nitto 555G2 (summer)/Motivos (winter)
2008 Chrysler Aspen Limited 5.7L-Airaid CAI, Eibach rear 3” lowering springs
hemi1031 is offline
post #13 of 19 (permalink) Old 06-05-2019, 12:12 AM
trippytro's Avatar
Tim
My links make the same noise, emailed speed logix and they claim its normal. Some of the comforts we give up for racecar parts lol. It could be that the link aren’t adjusted properly but yes metal on metal is noisy.
I bet she feels like your on rails though
trippytro is offline
post #14 of 19 (permalink) Old 06-05-2019, 02:14 AM
Gila Hemi's Avatar
Tim
My Whiteline sway bars are adjustable and don't make a sound, and I don't see how they would when properly installed.
So tell me, how do you work on a car in a German garage? The passengers have to get out before the car is pulled in, and with the passenger side almost touching the wall, the driver's door still can't be opened all the way, and there isn't room to walk in front of the car if the garage door will close, nicht wahr.
Member:
Gila Hemi is online now
post #15 of 19 (permalink) Old 06-05-2019, 05:32 AM
steve37887's Avatar
Some noise is to be expected when changing things. Getting rid of cushiony rubber bushings for less compliant better handling ones that's the trade off. Double check tightness of all your bolts. My guess is they're all tight and the clunk is normal. Mine does it too.
Sent from my SM-S907VL using Tapatalk
steve37887 is offline
post #16 of 19 (permalink) Old 06-06-2019, 10:55 PM Thread Starter
hemi1031's Avatar
Thanks guys. I have checked tightness a few times just to be sure nothing is loose. I am cool with noise for improved handling. The noise I keep hearing just sounds “off” to me. Truly as though something is loose. I really don’t know how else to describe it. She does handle great though!
Either way I’ll get under there in a couple months, after it gets off it’s boat ride, and take a look at everything again.
Gila,
I was lucky enough to live in the same house all three times that I was stationed over here. The landlord built the house in 05-06 to rent to Americans, so the garage is a bit bigger. Really it’s a two car, one side for the downstairs apartment/living space and one for the upstairs. Two family home for those that aren’t familiar. That’s how they like to do it here, sometimes even more. Anyhow, I was always able to pull in and stay more to the middle to clear the wall, for passengers to get out. Depth was never really an issue. But clearance was never enough to fully open doors and doing things such as wheel removal where done in tight quarters.
First photo is the last (2nd) time I was stationed here and got the Challenger. Installing the Stage 1 springs. Second photo is from being here this time and doing the suspension work described in my OP. One of the photos that I found, not sure whee the rest went. Third photo is the truck I brought with me the first two times I was here. It actually fit in the garage, which my landlord loved, took a photo of and used in his on-post house advertising at the housing office. Miss that truck... diff blew up before moving here though and had to get rid of it. Well gotta go. Catch y’all later
Tim
hemi1031 is offline
post #17 of 19 (permalink) Old 06-07-2019, 02:52 PM
Gila Hemi's Avatar
Gila,
Tim
That garage is huge for Germany, and it's the first German garage I've ever seen with anything in it besides a car! Thanks for the photos!
post #18 of 19 (permalink) Old 06-07-2019, 10:47 PM Thread Starter
hemi1031's Avatar
Figured you would get a kick out of that.
hemi1031 is offline
The Following User Says Thank You to hemi1031 For This Useful Post:
Gila Hemi (06-08-2019)
post #19 of 19 (permalink) Old 06-07-2019, 10:51 PM Thread Starter
hemi1031's Avatar
My mistake.... I thought you said you were up in the Cary area. Maybe that’s someone else. Hmmm.... My memory isn’t that good anymore. Hope Mills isn’t far either. I’ll be working on Camp MacKall. I’m sure we’ll get together at some point or drive past each other and not realize it. Lol.
hemi1031 is offline
thinking about upgrading my challenger falcompsx General Challenger Discussion 13 06-23-2017 11:26 PM
Upgrading base and oem amplified systems IMCHALLENGEN Car Electronics- Lights, Fuses, Audio & Video 4 12-02-2015 05:13 PM
Head Unit w/HDMI input for iPhone5 Grey Car Electronics- Lights, Fuses, Audio & Video 1 04-20-2013 04:50 PM
Thoughts on Upgrading after 2 Years seebz13 General Challenger Discussion 19 10-25-2012 02:27 PM
