How can I make it faster? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 7 (permalink) Old 03-18-2019, 12:31 PM Thread Starter
What are some things I could do to my stock 2010 srt8 challenger in order to make it faster? 'I already bought a Cold Air Intake'
Adam Vilaysouk is offline
The Following User Says Thank You to Adam Vilaysouk For This Useful Post:
jgraham70 (03-18-2019)
post #2 of 7 (permalink) Old 03-18-2019, 05:26 PM
trippytro's Avatar
Faster at the track?
If you’re looking for time slips, slick tires are the way to go. Easily cut your time down.
Long tubes make good power if you’re not emissions exempt
A tune should be easy since you dont have a locked pcm
Many more directions to go
trippytro is offline
post #3 of 7 (permalink) Old 03-18-2019, 05:39 PM
Cuda340's Avatar
It all depends on how much money you want to spend and how fast you want to go.
Your cold air intake will not give you much, if anything. I would recommend a Diablo tuner to start.
If you have a big budget ($4k plus labor), you could install a supercharger.
Cuda340 is offline
post #4 of 7 (permalink) Old 03-18-2019, 05:46 PM
Nitrous gives best bang for the buck in terms of $/HP. Next is supercharger, followed by cam/heads. Basically you are looking at $50-$100 per HP on these cars. Fortunately you have a 2010 so you don't need a modified PCM saving you ~$250.
Then you get to a point that it's hard to stop wheel spin off the line.
ChallyTatum is online now
post #5 of 7 (permalink) Old 06-12-2019, 12:42 PM
TaeKwonJoeSRT8's Avatar
Adam, are you trying to hit the 13.2s ¼ mi. ET benchmark or exceed it–i.e. 12s?
After 20 passes I still can't break into the 13s... best is 14.104s. The elevation at LVMS is 1961.9 ft. and DA is typically 3000–6000 so I'm not certainly not running in near-optimal conditions especially on these hot summer nights in the desert. However on one cold 48° November evening I was able to do a 4.7s 0-60 according to the onboard performance pages.
2009 Challenger SRT-8
AEM DryFlow Performance Air Filter
Nitto NT555R 305/35R20 (rear)
Cuda340, I've been considering a DiabloSport inTune i3 8300 or Platinum 8345 for CMR custom tunes. According to the DiabloSport product pages:
• 91 Octane Performance Tune: 23HP 23TQ
Might this translate to significant reduction in my ET given the conditions I'm running in?
2009 Challenger SRT-8 6.1L • HEMI Orange
stock with Nitto NT555R 305/35R20 drag radials and Voxx Demon Replica rims (rear)
TaeKwonJoeSRT8 is offline
post #6 of 7 (permalink) Old 06-12-2019, 01:10 PM
The DS tunes typically reduce the amount of timing being pulled when the throttle is applied "tip-in" and they also desensitize the knock sensors which translates to more power being made available.
TaeKwonJoeSRT8 (06-12-2019)
post #7 of 7 (permalink) Old 06-12-2019, 02:50 PM
MiHiHemi's Avatar
Seriously loaded question. Sky's the limit...only depends on how deep your pockets are
MiHiHemi is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > Model Specific Discussion > Dodge Challenger SRT8 Specific > 6.1L (2008 - 2010)
Speedlogix Catch Can Braided Lines Speedlogix-Sales Speedlogix 14 04-08-2019 08:17 AM
Amateur Sq install Bigdodge Car Electronics- Lights, Fuses, Audio & Video 43 07-26-2014 10:20 PM
