Forced induction for 392's. a thread to end them all. - Dodge Challenger Forum: Challenger & SRT8 Forums
Forced Induction From Blowers to Turbos
post #1 of 24 (permalink) Old 05-25-2019, 12:16 PM Thread Starter
Exclamation Forced induction for 392's. a thread to end them all.
Greeting to you all
This subject has probably been discussed many time and in numerous threads throughout all challenger forums.
But the reason I am opening it again is to once and for all have a clear vision on how to safely super/turbo charge the infamous 6.4 392 engine without tearing it apart.
Now I know the majority simply would advise not to waste money and brain cells due to the weakness of the engines internals. In fact all of you probably would advise trading it for a hellcat. Now if that was easy and accessible to everyone. this discussion wouldn't be opened over and over.
So, yes I regret not buying a hellcat. not just because its more powerful. but I was a rookie and did not realize the politics behind it. Dodge probably realized that everyone would go to the cheaper alternative and buy a 6.4 and modify it and it would leave the hellcat with a handful of buyer, thus maybe intentionally giving the 392 weak internals that do not handle boost. So by modifying your 6.4 would probably empty your pockets and you would have saved a lot of money by simply buying the 6.2 supercharged Hemi.
Now all that aside (regret, Money wasting and headache). I cannot replace my 6.4. it is not that simple in counties outside of the U.S.
I am left with an ultimatum. Boost my 2016 srt 392 challenger :')
Now, Other than forged pistons, rods, Fuel system and gaskets. What other parts/internals do I need to take in consideration to make my 392 engine withstand at least hellcat power. I'm not talking 1000+ HP. something within the 650-700 Whp.
And if it helps. how could you even improve it to 1000+ HP I am guessing of course changing more internals.
I would really appreciate help from you guys who have had experience with such matters.
And if you cant be bothered to help out, I am pretty sure there are threads that are clear as crystal on the steps and parts needed.
Huss is offline
post #2 of 24 (permalink) Old 05-25-2019, 05:18 PM
Supercharged Scat's Avatar
Wow I didn't realize dodge put that much thought into their designs, intentionally building a weak link in the 2011 Apache engine to help with sales on the 2015 Hellcat platform.
On a serious note, Luke at Steve White is a forum vendor and does exceptional work, reach out to him.
Supercharged Scat is offline
The Following User Says Thank You to Supercharged Scat For This Useful Post:
stevewhiteparts (06-18-2019)
post #3 of 24 (permalink) Old 05-25-2019, 06:37 PM
John Matthews's Avatar
The 392 does not have weak internals but rather a piston design not ideal for forced induction. As noted, Luke at Steve White Motors is a good source (I used). There are others such as high horse performance with a good reputation.
HellCat power levels require internals to the same standard as a hellcat.
I don’t know what year SRT you have you must also have all the externals that can support the power levels; half shafts, differential, drive shaft, etc.
2012 SRT automatic, PB 12.0490 with DR, then 11.56 with 5.5psi magnuson Sold
2017 hellcat A8 stock, 10.86 with DR's
John Matthews is offline
post #4 of 24 (permalink) Old 05-26-2019, 12:40 PM
Problem is that when you boost you are adding more power and heat. The 6.4 ring gaps are meant for NA so when things get too hot (tune is not conservative on fuel) the ring expands until the gap closes. You can bust a ring landing on a 5.7 just as on a 6.4.
I doubt the engineers would purposely put in weaker components...otherwise why go through the trouble of adding squirters and forged crank?
stevewhiteparts (06-18-2019), Toxic11 (05-29-2019)
post #5 of 24 (permalink) Old 05-26-2019, 04:48 PM
INNOV8R's Avatar
Wouldn't a 180° thermostat help with the heat? Wouldn't water/meth injection help. What about E85 or something we have, 93 octane that has 30% ethanol. Doesn't that run cooler than gas? With all 3 of those things maybe the heat is lowered enough that the ring gap is no longer an issue?
Current muscle: 13 Challenger SRT8 A5•Redline Tri-coat Pearl/Black Stripes•SL Front Brace•Nitto Motivo 275/40/20•MRR GT5•SL Catch Can•Sequential Tail Lights•Quarter Scoops•Drake Fuel Door•180° T-Stat•Diablo T2•Wideband O2•93 octane with 30% ethanol
Muscle cars I've owned.
69 GTO 400
69 Road Runner 383
71 Duster 340
71 Challenger R/T 383
70 Challenger 426
78 Trans Am T/A 6.6
78 Trans Am 6.6 Liter
69 Camero 350
79 Corvette 350
76 Corvette LT1
INNOV8R is offline
post #6 of 24 (permalink) Old 05-26-2019, 06:39 PM
Booky's Avatar
Edit
Booky is offline
post #7 of 24 (permalink) Old 05-26-2019, 06:47 PM
180F thermostat does not help as much as running water/meth and 93 exclusively. Don't forget the SC heats the air as well. Intercoolers help but you will still see about +30F above ambient IATs. I have a coworker running a procharger on his BMW without an intercooler and his IATs are north of 150F...the air charge is hot.
post #8 of 24 (permalink) Old 05-26-2019, 10:42 PM
us1champ's Avatar
Feedback Score: 10 reviews
Get a custom cam. Pushrods. New valve springs retainers ect. Also new timing chain arp studs for the main caps and arp head bolts or arp studs for heads
2009 SRT
CUSTOM HEAD RESTS
us1champ is offline
post #9 of 24 (permalink) Old 05-26-2019, 11:18 PM
So what is your goal of having a 700hp car? Racing (road or drag)? Weekend car or daily driver? 700hp is going to take a build, time and money. There are numerous ways to achieve the goal and the method you choose will impact how the car behaves.
post #10 of 24 (permalink) Old 05-27-2019, 12:15 AM
A thermostat only regulates the minimum operating temperature. Just like a house without an air conditioner, you can set your home thermostat to 68 but if it's 105 outside, you can bet the temp in your house is still going to get hotter than 68.
OregonScat is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Forced Induction
Bought 3.64 rear end for 2013 v6 challenger, going to do a rear end swap ddeennis Dodge Challenger SE/SXT Specific 89 01-12-2017 06:20 AM
Low end grunt as it relates to modern engines randycat99 General Challenger Discussion 128 09-18-2012 07:29 AM
Supercharger, Forced induction and Leaf Blowers omen omega General Challenger Discussion 0 07-12-2012 01:25 PM
Forced Induction 425hpChargerSRT8 Performance Modifications 25 07-01-2008 05:25 PM
