Pros and cons of 4.05 vs 4.08 crank - Dodge Challenger Forum: Challenger & SRT8 Forums
Strokers Anything to do with Strokers and more in depth engine modifications.
post #1 of 8 (permalink) Old 05-16-2014, 08:51 AM Thread Starter
Is there any advantages or disadvantages between these 2 cranks? Im getting ready to build a new motor and i will be using boost. 10-12 lbs for the street and 20lbs at the track.
Thanks
hpindy is offline
post #2 of 8 (permalink) Old 05-21-2014, 02:25 AM
21SRT8's Avatar
The only advice I can give you is the longer the stroke will help make more torque, in the other hand a longer stroke will give you more rid angle which is bad and causes more wear and tear on your cylinder walks and piston skirts. Is it a problem with our motors? This I don't know.
21SRT8 is offline
post #3 of 8 (permalink) Old 09-29-2015, 06:13 PM
New York Rob's Avatar
This is a hard one to call based on the nominal amount of stroke difference. But the above mention of side loading and piston wear, cylinder wear is a creditable mention. Though I think you know this already.
I would say a bit may depend on exactly how you want the engine to perform and where you want it to peak RPM wise, which is cam related, but, hindered or enabled by stroke. Lack of or to much off it. There has got to be a on line calc some where, like maybe, "Wallace racing." might have something for you?
Drag racing or hot street performer?
New York Rob is offline
post #4 of 8 (permalink) Old 09-29-2015, 09:42 PM
SlowSRT8's Avatar
Thanks
With how big of a cylinder bore?
SlowSRT8 is offline
post #5 of 8 (permalink) Old 04-05-2018, 07:49 AM
Realistically you would want to look at the Rod/stroke ratio and the mean piston speed at what you believe the peak HP/Torque RPM will be.
Ben Mowery
2016 R/T Scat Pack B5 Blue/A8
Petty's Garage STB and Catch Can
HP tuners Tuned
benmowery is offline
post #6 of 8 (permalink) Old 04-05-2018, 08:26 AM
19johned53's Avatar
I had a discussion years ago with a few engine builders/sponsors on this forum about stroke vs cylinder wear. The longer stroke will decrease engine longevity, but more torque and CI's are the plus side of it. Cylinder wear was the issue with longer stroke cranks
I was discussing a street engine with maximum torque in mind, and the expected engine life was considerably reduced, compared to "stock" strokes.
This may or may not be a factor to you if you are just racing.
FWIW, we were discussing 426/440 CI's from a 6.1 block
19johned53 is online now
post #7 of 8 (permalink) Old 04-14-2018, 01:49 PM
kbr577's Avatar
Feedback Score: 2 reviews
Send a message via AIM to kbr577
There really wont be any difference .03 is nothing, don't over think it. I had a 4.25 stroke and after 15,000 miles it still looked like new. yes the rod angle, rod ratio, and piston speed are all important to a certain extent small and big block Chevy's have been running a lot worse rod ratios than mopars and living just fine, just take at what a 440 RB motor is, compared to late model hemi's , go with the either and enjoy.
GO BIG OR GO HOME!!
Mods:Getrag,
10.00s @ 135 + mph at full weight
kbr577 is offline
post #8 of 8 (permalink) Old 05-01-2019, 07:28 PM
Brucer41's Avatar
Send a message via Yahoo to Brucer41
I am at 7 years and 14K with a square stroker 4.08X4.08 and it is holding up just fine. I had to replace a piston, rod and heads a few years back and in checking everything out while I had the bottom open (about 8K at the time) everything was perfect. I beat this thing like the proverbial red-headed stepchild. Street, 1/4, 1/8, pro tour, etc. I built her for all sorts of fun and she is like a Timex.
2009 Challenger SRT8 (Hemi Orange Pearl)
Modern Muscle 426 Hemi Stroker
Arrington Performance Hemi 90mm Billet Throttle Body
Magnaflow TVS 2300 - Black Finish w/90mm Inlet
Arrington Magnaflow TVS2300 Direct Drive System
Kooks Long Tube Headers/ Kooks Catted Midpipes
And way too much to list here!!
Brucer41 is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Strokers
what is the pros & cons of installing the stop/start button in the 2013 challengers ? BERT Interior Discussion / Modifications 31 06-24-2013 07:24 PM
