Injector size recommendation for NA E85 coversion - Dodge Challenger Forum: Challenger & SRT8 Forums
Builds For those who want to talk about in depth builds.
post #1 of 3 (permalink) Old 06-09-2019, 09:22 PM Thread Starter
I'm looking for recommendations for injectors that will effectively run E85 in my 2017 392. I am considering a lower output supercharger later this year as well, so I'd like to make 1 purchase with that goal in mind also.
I would like the ability to run an E85 tune on the track, and a 91 octane around town (E85 is about 1.5 hours away, so my cans will be filled periodically).
Are there any other considerations that I should think about?
Thanks!
2017 Challenger R/T 392 (Scat Pack Trim)
Redline Pearl
6 Speed
Current Mods:
  • Barton Shifter
  • UPR Catch Can
  • Speedlogix Skip Shift Eliminator
  • Hellcat Air Box and Filter
  • TAZER
John of the North is offline
post #2 of 3 (permalink) Old 06-09-2019, 09:28 PM
Look for a thread by @chizzle1 , he is making considerable power and switched to E85 which not only required bigger injectors but a bigger fuel pump. In fact, I think he ran a return style set-up.
Here is the thread I was referring to.
https://www.challengertalk.com/forum...7=#post8427625
BTW I don't think the PCM can be set-up to run gas...then E85 without re-flashing. I know a lot of guys want to run flex fuel and HP tuners has a patch for it but it is not as simple as..."just install the patch".
ChallyTatum is online now
John of the North (06-10-2019)
post #3 of 3 (permalink) Old 06-10-2019, 06:09 PM Thread Starter
Thanks!
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Builds
