+25 hp - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 80 (permalink) Old 04-28-2019, 01:11 AM Thread Starter
+25 hp
So I have a 19 RT. And honestly I just want like 25 more HP and whatever amount of torque comes as a result of that. I come from turbo 4 bangers so I’m used to being able to just turbo tube and bam easy stage 1 power. But now that I’m in the all motor club, where should I start?
AttackHelicopter is offline
post #2 of 80 (permalink) Old 04-28-2019, 08:18 AM
Newoldchallenger's Avatar
25 crank or rear wheel?
Longtubes and a tune will get you pretty close to what you are after and are probably the most cost efficient for power.
2013 Challenger R/T Automatic
Newoldchallenger is offline
post #3 of 80 (permalink) Old 04-28-2019, 11:30 AM
^^^ what he said, RTs definitely benefit from long tube headers. Cost wise you are looking at:
$250 for PCM unlock
$300 for HP tuners
$100 for HP credits
$1400 for LT headers & high flow cats
$250 for tune (will most likely consist of tweaking injector fueling as opposed to going speed density and messing with the VE tables which is a lot more work)
$2300 for ~+30RWHP ($77 per HP) and a very aggressive WOT exhaust note. Just make sure state emissions won't cause you any grief. I would also spend a couple of hundred more and get a wideband and weld in some O2 bungs...makes tuning a whole lot easier.
ChallyTatum is online now
post #4 of 80 (permalink) Old 04-28-2019, 12:42 PM Thread Starter
Well shit. That’s a whole lot more money than I thought it would be.
post #5 of 80 (permalink) Old 04-28-2019, 01:12 PM
HP ain't cheap on these rides...add-ons vary from $65-$80 per HP. I think on your 2019 you don't have to unlock the PCM but you will need a bypass cable.
post #6 of 80 (permalink) Old 04-28-2019, 07:10 PM
Well....That’s a whole lot more money than I thought it would be.
Welcome to Dodge. We've discussed this many times here. The little extra that's possible costs big $$$
Then there's the fact that when ya go to sell the car in a couple years, nobody wants it because of the mods you've made. Sure ya wanna do this?
Reason it costs so much to pick up such a small amount of power? We've said before that Dodge did some serious development with these engines. They're tuned pretty aggressively right from the factory according to the consensus on this forum over the past several years. Since they didn't leave much "on the table," the usual upgrades that produce big power on other platforms don't work so well here. Dodge already squeezed most of what could be had out of these engines.
garyahouse is offline
Pauljw (04-28-2019)
post #7 of 80 (permalink) Old 04-28-2019, 07:20 PM
19johned53's Avatar
Yep, buy as much factory HP as you can afford, then enjoy the heck out of it.
19johned53 is offline
The Following 5 Users Say Thank You to 19johned53 For This Useful Post:
72/340 (05-02-2019), garyahouse (04-28-2019), Jazz Blue Scat (04-30-2019), MrMac (05-06-2019), Pauljw (04-28-2019)
post #8 of 80 (permalink) Old 04-28-2019, 07:36 PM
+25 hp
Gears ..........(instant gratification)
Ronan978 is online now
post #9 of 80 (permalink) Old 04-28-2019, 10:49 PM
Would be my other suggestion (other than the holy nitrous).
post #10 of 80 (permalink) Old 04-29-2019, 04:13 AM Thread Starter
I think I’m gonna avoid nitrous lol.
The Following User Says Thank You to AttackHelicopter For This Useful Post:
silver scat (05-01-2019)
