Hurst Shifter + 2012 392 = WOWOWOW - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 14 (permalink) Old 06-07-2013, 03:22 PM Thread Starter
Ironside's Avatar
What a GREAT purchase! This shifter is absolutely AMAZING - definitely a MUST BUY for anyone still on the fence!
I opted to re-use the stock pistol grip since I prefer the OEM look (that, and the two times I touched the white cue ball shifter it got filthy so I figured it would be a pain in the ass to keep clean being so gleaming white and all)
I think the best way to describe this shifter is FIRM and HEAVY (but a GOOD heavy)... the throw is WAY less than stock and this shifter makes the stock one feel sloppy and ridiculous.
Install was pretty straight forward; two areas that were a pain was getting the one bolt off that had the lock-tight (but a little elbow grease solved that problem) and getting the two pins lined up and installed on the shifter linkage (it wasn't that it was super difficult, it was just that you have minimal room to fit your hands and BOY are things sharp down there!)
All in all, definitely worth the money! Anyone contemplating this purchase needs to bust out their wallet.
I can't speak for the noise issue with the Hurst shift stick but I will say that with the stock shifter it is ALMOST exactly the same as stock... you can hear the EVER SO SLIGHTEST "whirring" sound every now and again but I could only hear it with my windows up and if I leaned my ear down near the shifter so definitely don't panic about this issue if you're keeping the OEM shift knob.
Here are some pictures from the install... no final pic because, well, it looks the same as stock.
ID:	69063   Click image for larger version
ID:	69064   Click image for larger version
2015 Challenger SRT Hellcat, 6-spd, Sublime
BUILD #3155 (240th in Canada)
Ironside is offline
The Following 2 Users Say Thank You to Ironside For This Useful Post:
Js78 (06-07-2013), ken kamins (06-08-2013)
post #2 of 14 (permalink) Old 06-07-2013, 04:17 PM
70barcuda's Avatar
Nice, I know a couple guys that have installed them and they all seem pretty happy with it as well.
2014 SRT Core - 12.091 @ 114.03 mph
2010 R/T - PB 12.87 Traded
I know my car runs 10's because I once beat a guy who said his car runs 11's.
70barcuda is offline
post #3 of 14 (permalink) Old 06-07-2013, 04:43 PM
teddyp's Avatar
What if any special tools are needed. I eventually want to do this. And about how long, if you work straight through, taking your time do you figure it takes. Good job by the way. Congrats.
Sent from AutoGuide.com App
Black 2013 SRT8 6 speed, dual gray metallic stripes, radar red interior, tinted windows and side markers, Goodyear F1 front tires, (OEM), BF Goodrich g-force sport comp 2 275/40/ZR20 rears, Legmaker "True" fender pull CAI, 87mm ported throttle to match ported intake manifold by Peakspeed, Mishimoto 180* T-Stat, Diablosport H.F. custom 93 Tune, Magnaflow comp series cat back, Speedlogx front tower brace, MOPAR stage ones, Barton shifter, catch can.
teddyp is offline
post #4 of 14 (permalink) Old 06-07-2013, 05:10 PM
Supporting Vendor
SRT8U's Avatar
Send a message via AIM to SRT8U Send a message via Skype™ to SRT8U
Glad you like it, very worthwhile mod for the 6 speeds!
Kris
2018 Durango SRT
2017 Charger Hellcat
2006 Charger SRT8 Road Course Car
SRT8U is offline
post #5 of 14 (permalink) Old 06-07-2013, 05:12 PM
Supporting Vendor
SRT8U's Avatar
It isn't too bad of an install. Here is a writeup with pics we did a while back
https://www.challengertalk.com/forums...=hurst+install
SRT8U is offline
post #6 of 14 (permalink) Old 06-07-2013, 05:49 PM
JustForFun's Avatar
Feedback Score: 2 reviews
How did you reuse the stock shift handle since it attaches to the linkage differently?
JFF
JustForFun is offline
post #7 of 14 (permalink) Old 06-07-2013, 06:30 PM
DT1
DT1's Avatar
The hurst has a stock style mount for stock shifters. I'm using a gunslinger pistol grip with my hurst, works perfectly.
DT1 is offline
post #8 of 14 (permalink) Old 06-07-2013, 10:04 PM Thread Starter
Ironside's Avatar
JFF
The Hurst shifter has an extra slot that allows the stock shifter to slide in and bolt up. Mikey from Speedlogix originally told me this was not possible due to Chrysler changing the design of their stock shifter slightly but I found no problems hooking it right up without any modification; just plug and play.
I let a few buddies try out the shifter tonight and they were blown away!
[NOISE UPDATE] After driving around tonight i can see the noise people are referring to; if you are sitting idle in traffic with the windows up and radio off you can hear a slightly annoying, intermittent rattle (only hear it occasionally) from the transmission. The same sound can be heard from outside but was very muted in the cabin before; now, not so much.
It's not absolutely terrible by any means but noticeable enough that my wife was like "is your car supposed to make that sound?" so it definitely sounds out of place.
I think the car sounds more raw, reminds me more of a brute force race car... When you're actually moving, I kinda like the noise the car makes, actually sounds good.
That being said, I can see how some might dislike it. A Chrysler 300 luxury car this is not!
A little noise still doesn't take away from the fact that this is the greatest mod I've done next to Zoomers!
Ironside is offline
post #9 of 14 (permalink) Old 06-07-2013, 10:24 PM
CHALLENGEmeSE's Avatar
Nice thread! I've herd these are pretty sweet! Definitely a future mod for me when I upgrade
BTW, here's a link to Speedy's Garage which is a step by step video on how to install the HURST shifter....
https://www.youtube.com/watch?v=2Int...e_gdata_player
Good Luck Guys :thumbup:
Sofas are made to sit // Cars are made to DRIVE!!!
CHALLENGEmeSE is offline
post #10 of 14 (permalink) Old 06-08-2013, 02:35 AM
wasp392's Avatar
Did you use the dynamat kit that came with it?
When you press the clutch all the way down, do you hear the little rattling noise go away?
wasp392 is offline
Hurst shifter kit for 2012 sxt? stormTrooper Interior Discussion / Modifications 2 01-09-2013 08:11 PM
Manual Hurst Pistol grip shift handle (OEM) installed into HURST assembly Rudedog Interior Discussion / Modifications 13 09-01-2012 06:11 AM
Chrysler's SEMA surprise: 392 HEMI Dodge Challenger Super Stock ekool Dodge Challenger News 44 06-04-2007 03:50 PM
