stock 6.1 Harmonic Balancer / pulley on a 5.7 - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 6 (permalink) Old 03-29-2015, 10:53 PM Thread Starter
is there any performance gains on putting a stock 6.1 under drive pulley on a 5.7
anyone heard of this or done this also iv never really messed with pulleys before is it something i can change my self and are they any down sides to them ? do i need a tune can they be used on a stock engine?
white 2012 challenger R/T automatic 93 tune kn cai and a res delete
22in Vossen cv1's
chrisrt is offline
post #2 of 6 (permalink) Old 03-30-2015, 04:43 AM
R/T-Randy's Avatar
Putting a stock 6.1 under drive pulley on a 5.7 harmonic balancer should work fine if the pulley mounting holes line up.
As far as putting a 6.1 harmonic balancer on a 5.7 motor, I am not so sure. The weight of the 6.1 balancer may not be optimum for the 5.7 motor. You may run into issues, but it might be fine. I would do my home work before doing so.
Things to check into would be the weight difference, hub size (going into the timing cover) so you don't have any leaks, crank hub diameter (will the balancer fit on the crankshaft) and pulley mounting holes. I have no idea about the 6.1 and 5.7 crankshaft specs (to mount the balancer).
I doubt you will have any performance gain from changing the harmonic balancer.
Some people do put under size pulleys as a performance mod. The under size pulley will slow down the rotation of the accessories attached to it. The water pump, A/C compressor, etc. This may free up a pony or 2 at higher RPM.
Not really significant enough to go through the hassle, expense and possibly have a negative effect to something else IMO. Engine cooling and battery charging may not work was well.
Just my opinion, I could be wrong.
2012 Tungsten R/T Classic, 6 speed w/STP, 730 RHR w/sound group II and heritage wheels.
Mods: none
MSgt, USAF Retired
R/T-Randy is offline
post #3 of 6 (permalink) Old 03-30-2015, 05:32 AM
bwbike's Avatar
Feedback Score: 4 reviews
Originally Posted by R/T-Randy View Post
. . . Not really significant enough to go through the hassle, . . .
...............This
2015 Jeep Renegade Trailhawk
2009 R/T 27F, 6-Speed Tremec
Traded
bwbike is offline
post #4 of 6 (permalink) Old 03-30-2015, 06:05 AM
Modern Muscle's Avatar
The 6.1 Balancer on a 05-08 5.7 works as a inexpensive under drive pulley people have been doing it for years with no issues. However it will not fit on the 09+ 5.7
Modern Muscle is offline
post #5 of 6 (permalink) Old 05-14-2019, 06:44 PM
Mopartony345's Avatar
Would it work on my 2012 Dodge Challenger rt 5.7 ? Has anyone does this mod thanks
Mopartony345 is offline
post #6 of 6 (permalink) Old 05-14-2019, 09:40 PM
According to the above post from Modern Muscle it will not work on your 2012.
ChallyTatum is online now
« +25 hp | -
Timing chain failure on the Dodge Challenger raVenX Challenger Issues & Problems 6101 01-31-2019 09:18 AM
procharger SRT 6.1 on R/T 5.7 khalood_996 Dodge Challenger R/T Specific 1 10-19-2014 03:00 PM
Review: Intune Diablosport on a 392 Challenger rayzazoo General Challenger Discussion 25 05-22-2014 11:16 AM
