3.92 manual RT differential - Dodge Challenger Forum: Challenger & SRT8 Forums
Drivetrain In this section, you can post up anything in regards to the transmission, differential, etc.
post #1 of 38 (permalink) Old 04-09-2019, 01:51 PM Thread Starter
I have a 2014 manual Challenger RT and my differential just went out, I have a 3.92 ratio. I’ve been looking for a replacement and notice that there are SRT8s with a 3.92 gear ratio as well, I’ve notice they are automatics, I was wondering if it would work? And if it’s better that the RT? Should I get one from an SRT8 or one from an RT?
Lopezel is offline
post #2 of 38 (permalink) Old 04-09-2019, 01:56 PM
72/340's Avatar
I've not seen the 3.92 in an automatic from the factory. With the way the auto is geared (which is why the 3.06) she would be screaming on the highway.
'10 Challenger R/T Classic
Flowmaster Force II cat back, K&N branded CAI with Amsoil dry synthetic filter, Diablo Predator 91 CAI tune,
Mopar '11+ IAT sensor, Mopar hood struts, RPI stealth guards, R/T spoiler emblem
72/340 is offline
post #3 of 38 (permalink) Old 04-09-2019, 02:02 PM
Slidd's Avatar
The SRTs with A5 automatic up thru 2014 used a 3.06 ratio. The 3.92 on Challenger was only used on M6 cars with 20 inch wheels, M6 cars with 18 inch wheels used a 3.73 ratio.
The only cars to use an A5 with a 3.92 far as I know was the 2011 Mopar 11 Charger and the 2012 Mopar 12 Chrysler 300.
Slidd is online now
The Following 2 Users Say Thank You to Slidd For This Useful Post:
72/340 (04-10-2019), ChallyTatum (04-09-2019)
post #4 of 38 (permalink) Old 04-09-2019, 06:31 PM Thread Starter
Yes you are right, those are the cars I’ve seen, but will the differential from those cars (300 and charger) work for the manual challenger? Would they be stronger since they are for SRT8? I’ve checked at some junk yards and they told me they were different that didn’t didn’t interchange.
Lopezel is offline
post #5 of 38 (permalink) Old 04-09-2019, 06:44 PM
Newoldchallenger's Avatar
They will work. All 3.91s (the actual gear ratio, not 3.92) are h226 getrags. Same in a 6spd rt, 6spd srt8s and the special mopar editions.
2013 Challenger R/T Automatic
Newoldchallenger is offline
post #6 of 38 (permalink) Old 04-09-2019, 07:10 PM
Yup just as Newoldchallenger stated, the 3.92 is the same throughout trims levels....scroll to the bottom of the link below.
https://www.stevewhiteparts.com/oem-...mbly-5038237ah
ChallyTatum is online now
post #7 of 38 (permalink) Old 04-09-2019, 07:42 PM Thread Starter
Cool, thanks for the info!
Lopezel is offline
post #8 of 38 (permalink) Old 04-10-2019, 09:44 PM
believe my diff just went out too on my 2012 m6 rt with a whipple, what were your symptoms/ how do you know its blown. mine has severe whine and clunking under any load. the whine drowns out my radio and whipple.
2012 Challenger R/T Classic STP 6M Blue Streak Pearl, MODS Wipple 2.9L Supercharger also Blue streak pearl, Whipple Cold Air Kit, Flowmaster Outlaw Catback, ACE ALLOY AFF002 20X10.5 and 20X9 Nitto invo 315/35 and 275/40. Previously known as KcClassic!!!!
WhippleRTClassic is offline
post #9 of 38 (permalink) Old 04-11-2019, 12:49 AM Thread Starter
After a small burn out, I heard a click and the car wouldn’t move forward or backwards at all in any gear. I do hear a winding noise, which is my driveshaft and I can see it spin when I put it in gear and accelerate, but the tires won’t move so I’m assuming my differential is bad, I drained the oil today but didn’t see any metal shavings. But I am going to take a closer look tomorrow to confirm tho.
Lopezel is offline
post #10 of 38 (permalink) Old 04-11-2019, 10:44 AM
If you are not seeing metal in the diff oil, and the prop-shaft and half-shafts aren't flopping around but visibly spinning...then it could be a bad CV joint or a spline is wiped out.
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Drivetrain
Shaker sub-forum for the Hole In The Hood Gang Members please JB1 ChallengerTalk.com Website Problems 67 06-17-2016 06:46 PM
For those that ORDERED the 2014 Shaker iamawild1 General Challenger Discussion 3223 01-10-2016 11:50 AM
Post Em up Mopar 10 guys SRT8Tech Dodge Challenger R/T Specific 1279 12-08-2015 10:19 AM
2014 Shaker #999/1000 Shaker #999/1000 New Member Introductions 16 09-04-2014 10:25 AM
