SXT gear upgrades? - Dodge Challenger Forum: Challenger & SRT8 Forums
Drivetrain In this section, you can post up anything in regards to the transmission, differential, etc.
post #1 of 41 (permalink) Old 02-05-2014, 01:50 PM Thread Starter
WXman's Avatar
SXT gear upgrades?
Does anybody make gear ratio upgrades for the SXT cars? I have the 2.65s and would love something in the 3.23 or 3.55 range. What all is involved and how much cash are we talking?
2014 TorRed SXT - K&N "Aircharger" CAI - Omegalink remote start - Blastin' Bob's Magnaflow muffler kit - Hidden Hitch - waiting for a tuner!
WXman is offline
post #2 of 41 (permalink) Old 02-07-2014, 10:48 AM
Nuke's Avatar
Rear-end Upgrade Options for 2011+ SE/SXT
There aftermarket gears available in varying ratios, but I am not sure if they will fit in the SE/SXT's 200mm pumpkin. Best bet would be to find a 3.06 from a wrecked SXT, but it's not going to be a direct replacement - will require other parts from donor car...I researched this topic a while back, check out this thread for more info: https://www.challengertalk.com/forums...options-99118/
Nuke is offline
WXman (02-07-2014)
post #3 of 41 (permalink) Old 02-07-2014, 11:28 AM Thread Starter
WXman's Avatar
$2K? If so I will pass.
WXman is offline
post #4 of 41 (permalink) Old 02-07-2014, 12:02 PM
Nuke's Avatar
I looked up the aftermarket options at one point to get an idea of price, and I don't remember the exact # I arrived at, but 2K sounds about right...seems like it would have been $1500 or so for parts and $500 for labor to install seems about right (if not a little low).
That's when I started looking at swapping in a pumpkin from a wrecked Challenger, but the unique size of the base model's rear-end (200mm) meant any replacements (215mm or 225mm) wouldn't be a direct drop-in, so I had to find what else had to be replaced along with it (axles, hubs, etc)...pretty soon, the whole idea started losing its luster as something for me to do.
It's a shame that the Challengers that could benefit the most from a rear-end upgrade (base models w/ 2.65) require the most effort and/or money to get the upgrade done.
If you run across a wrecked Rallye Redline being parted out, that's your best bet on getting an upgraded rear-end. It will have a 3.06 (215mm), which is not a huge upgrade, but it will be the cheapest and easiest one to swap into the base model Challenger.
Nuke
Nuke is offline
post #5 of 41 (permalink) Old 02-07-2014, 05:48 PM Thread Starter
WXman's Avatar
Yeah when I bought my car I could have gotten the 3.06 gears for $100 bucks. But I couldn't get the color I wanted so I ended up going 2.65 to get the color I wanted. Starting to wonder if that was a good idea or not.
WXman is offline
post #6 of 41 (permalink) Old 02-07-2014, 11:44 PM
Nuke's Avatar
The 3.06 is definitely preferable to the 2.65, but I don't think it's enough of an improvement to compromise something like the paint color. I mean we are paying a lot of money for these things and will ostensibly be keeping them for a long time, so we should definitely have them in the color we want.
If the 3.2x or 3.73 rear-end were an option at time of purchase, I could see going with that and not getting the color. Although, with something in the mid 3.xx range, I would probably have to start a separate savings account just to pay tickets and such.
I've got three tickets so far in mine (2 in one day - 10 min apart), so I shudder to think how much jack-assery I would engage in with that low of a rear-end in my car.
Nuke is offline
post #7 of 41 (permalink) Old 02-08-2014, 07:02 PM Thread Starter
WXman's Avatar
Lol...two tix in 10 mins. That's awesome.
WXman is offline
post #8 of 41 (permalink) Old 02-28-2014, 07:25 PM Thread Starter
WXman's Avatar
So I found out that Richmond Gear makes 3.23 and 3.55 ring and pinion sets. Apparently you can get them for the 198mm, 210, 215, and 226 axles. They sell for about $500.
So since you can get ring/pinion sets specifically made for your specific differential...doesn't that mean you could avoid having to change the pumpkin, axles, hubs, etc.?? In theory you could just do a ring/pinion swap just like you would on a straight axle car. Or am I missing something?
I assume you would also have to factor in a tuner to program the computer for the new ratio and that's another $500. So you're looking at $1000 before labor. BUT...it gets you into a ratio that is more desirable for mixed track/street use and it wouldn't require a total overhaul of the rear end.
Somebody correct me if I'm wrong about all this.
WXman is offline
post #9 of 41 (permalink) Old 02-28-2014, 10:47 PM
Nuke's Avatar
The 2.65 they put in 2011+ is 200mm, so unless I am remembering that spec incorrectly (and it is really 210mm), or you copied those numbers incorrectly (and 210 is really 200), then we are still on the outside looking in for gear upgrades.
If they do make a set that fits our housing, then yes you would only need to have the computer updated to know about the new rear-end ratio to make it work. Which can be done with a tuner or by having the service dept at a dealership do it for you (unsure what that might cost though).
Nuke is offline
post #10 of 41 (permalink) Old 02-28-2014, 10:56 PM
Nuke's Avatar
If it turns out they do make a set of gears we can swap out in OE housing, please update this thread with the wonderful news. I think the 3.23 gears paired with the A5 transmission's gears would be the bee's knees!
The 3.55 with the A5 gear ratios might be a little too much for anything except full-time jack-assery IMO. And even though I love to do my share of jack-assing around, I also take out-of-town trips often enough to enjoy the great miles per gallon the 3.6L provides.
Nuke is offline
  Dodge Challenger Forum: Challenger & SRT8 Forums > General, Performance, and Technical > Performance Modifications > Drivetrain
2014 Challenger information thread ResumeSpeed General Challenger Discussion 373 04-03-2017 10:56 AM
Vibration when downshifting Renlo Challenger Issues & Problems 10 09-07-2014 06:22 PM
5-Speed Auto. Transmission Specs. Cuda340 General Challenger Discussion 0 01-30-2014 10:42 AM
SXT touring performance raven1 Dodge Challenger SE/SXT Specific 17 08-23-2013 11:34 AM
