8 degrees of st knock from 4500 to 6300rpm - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 26 (permalink) Old 04-07-2019, 07:45 PM Thread Starter
I have a 2005 dodge magnum rt. new to this site wondering if someone could help. I just installed heads, cam on my 5.7 I went with xfi260h13 from comp cams with the beehive valve springs, diamond power valves, new valve seals, ported heads port to match, comps hi tech push rods, timing chain set, shorty headers, water pump, 180 tstat, all new bolts and gaskets full exhausts, 3.90 gear, 27-10-15 Hoosier slicks, 150 nx wet shot.
The problem I am having is and 4500 to 6300 when it shifts I am getting 8.5 of st knock and nothing i do seems to fix the problem I have zip tied any loose parts that may have been tapping the engine. I have also put 2 bottles of octane booster in to make around 98 octane didn’t not seem to help a bit and replace both knock sensor with standard. Went through checks all my rockers and pushrods again and changed oil Hemifever added fuel and pulled timing nothing seems to help still have st knock at high rpm under load only
05magnumrt is offline
post #2 of 26 (permalink) Old 04-08-2019, 07:51 AM
Are you running a wideband? If not, you really should especially if you are throwing 150 shot at the motor.
I wonder if it is drivetrain noise? I know the earlier challengers have a rubber coupler at both ends of the prop shaft that weakens over time.
post #3 of 26 (permalink) Old 04-08-2019, 08:03 AM Thread Starter
I do not have a wide band but my car shows its at 11.8 af at wot I haven’t ran the 150 shot sense my cam and heads just trying to tune for na but as far as the driveshaft damper they look good I replaced the rear 3 times now I get a horrible wobble on acceleration when they go bad, I forgot to mention i also replaced my lifters with non mds and have a balancer on the way the stock one looks like the rubber inside is coming out in areas
post #4 of 26 (permalink) Old 04-08-2019, 08:15 AM
How are you seeing AFR if you don't have a wideband?
If it is commanded AFR that you are looking at, there is no guarantee that the you truly are getting 11.8 without using a wideband to confirm.
post #5 of 26 (permalink) Old 04-08-2019, 08:47 AM Thread Starter
Im looking at my data logs with diablo. I got a new tune sent to me today if this doesn’t work Ill go ahead and order a wide band and gauge thanks
post #6 of 26 (permalink) Old 04-08-2019, 12:02 PM Thread Starter
It shows desired afr I looked at the logs before cam install and it showed 11.25 at wot now after cam 11.81 at wot
post #7 of 26 (permalink) Old 04-08-2019, 01:30 PM
Yup that is what the PCM is commanding based off power enrichment table, but without a wideband you don't know if that is actually being delivered.
Flat Top (04-12-2019)
post #8 of 26 (permalink) Old 04-08-2019, 01:33 PM Thread Starter
Yeah the new tune that was sent this morning didn’t fix it still getting 8.5 degrees of knock
post #9 of 26 (permalink) Old 04-08-2019, 02:09 PM
Just out of curiosity are you still running a stock fuel pump?
post #10 of 26 (permalink) Old 04-08-2019, 02:21 PM Thread Starter
Yes I’ve never had replace the fuel pump
Using HP Tuners Pector55 Tuning/Data 94 04-06-2019 04:25 PM
Octane, Knock & Performance DTru Performance Modifications 27 10-17-2018 01:54 PM
Clank, Clatter, Knock - 392 Engine Noise rayzazoo Challenger Issues & Problems 59 04-07-2015 05:24 PM
what is knock? chrisrt Performance Modifications 1 01-17-2015 10:40 PM
Probably dumb questions about knock and datalogging RallyeRingo Tuning/Data 8 01-11-2015 08:41 PM
