2014 SXT Transmission Limp Mode? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 9 (permalink) Old 05-09-2019, 10:02 PM Thread Starter
Hey, everyone. I'm looking at a 2014 SXT that is for sale at a local dealership. It has 58,000 miles, looks great, and the Carfax shows routine maintenance. I test drove the vehicle today and it wouldn't go over 40mph or 3500rpm and the check engine light came on while I was driving. Took it back to the dealer and he drove it and had the same issue and said the mechanic would fix it. Other than this issue, the car is great and a good price. Is this a problem anyone else has experienced and fixed? Could this be something that happens often if I buy the car? Thanks in advance for any advice.
Phen2187 is offline
post #2 of 9 (permalink) Old 05-09-2019, 10:46 PM
wasp392's Avatar
I don’t think you get up to 40mph if it were in limp mode. Who knows what the issue(s) can be. Have them tell you the whole story and put it in writing. If they fix it and you decide to buy it, ask for extended warranty on the dealer’s dime.
wasp392 is offline
post #3 of 9 (permalink) Old 05-10-2019, 05:08 AM
Frank Julian's Avatar
I would not buy it. I would move on and find another one, preferably a new 18 or 19 with full warranty.
Frank Julian is online now
post #4 of 9 (permalink) Old 05-10-2019, 06:50 AM
19johned53's Avatar
Too many good used Challengers on the market to start out with a potential long term headache.
Move on and keep looking.
19johned53 is online now
post #5 of 9 (permalink) Old 05-10-2019, 11:33 AM
if the dealer can't repair the issue successfully, move on.
potential issues:
>different tire sizes (if dealer replaced some but not all tires)
>ABS sensor / harness / tone ring problem
>transmission conductor plate
>transmission solenoid issue
Hal H is offline
post #6 of 9 (permalink) Old 05-10-2019, 02:34 PM
If car is in limp mode then one or more DTCs have been triggered. Dealer should be able to pull the code to see what is causing all the fuss but I would walk away from this one...unless they give you a real good deal or extended warranty.
ChallyTatum is online now
post #7 of 9 (permalink) Old 05-10-2019, 04:43 PM
YellowDuc's Avatar
+1 on walking away.
2010 Challenger SRT8 M6: TorRed, Barton (skip shift+), Mopar Performance Long Ram CAI and Exhaust Tips, Fastman TB mod, Speedlogix Strut Tower Brace (front and rear), Brass Monkey Wheels (clones), Arrington Catch Can, 30% Tint (doubles the hp)
2016 Subaru CrossTrek (daily driver)
2006 Ducati 999s (scary fast)
1998 Ducati 748 SPS (far from stock)
"Who Dares Wins"
YellowDuc is offline
post #8 of 9 (permalink) Old 05-10-2019, 07:31 PM
hemi4us's Avatar
you do know that challengers will go into limp mode if the battery level is too low / or the batt was dead /has died and they jumped it thru the under hood terminal it just enough to bump it over and start but didnt fully charge it. A full batt charge with cables off, and car restart will generally clear that up.
YES - it really could be that simple.
..or it could be something else more serious.
if you are really concerned after the dealer gives it the "all clear" have it evaluated by another mechanic, but its not uncommon for a car thats sat on the dealer lot for 3-6 months to have a dead battery.
2015 Mods:
Axis Model II's.
Firestone Indy 275/40/20
Rolling Thunder Reso delete.
GPC Trunk Pull Handle.
Spare/Jack/Foam Delete.
GPC Phantoms.
Mopar O.E. Black Fuel Door.
Hellcat OE. ABS Cover.
Rear Seat Delete.
2014 Dodge Viper Seats.
hemi4us is offline
post #9 of 9 (permalink) Old 05-15-2019, 04:57 PM
I had a 2013 300c with the A5 that would "miss" the occasional shift and go into limp mode - used to happen about once a year. The trick is, it could happen on the highway and the car would go into neutral and you coasted to a stop and restarted the car. After that, things were normal again... till the next time.
The trouble code it would throw was "incorrect gear for speed" or something. Even with the valve body replaced under warranty, the car had that issue. As others have said, I would run from that 2014 SXT - A really good service department spent time and money trying to fix mine and it was never fixed.
Lanzz is offline
The Following User Says Thank You to Lanzz For This Useful Post:
ChallyTatum (05-15-2019)
2014 Challenger information thread ResumeSpeed General Challenger Discussion 373 04-03-2017 10:56 AM
MY2015 SRT Challenger "Refresh" - Announcement Spring Fest 2014 rayzazoo General Challenger Discussion 128 06-23-2014 02:48 AM
8 Speed for GC SRT Go Goody The Garage: For OTHER car talk 5 07-20-2013 06:21 PM
2014 Camaro Refresh to Debut at the NYIAS Whiskey Tango Foxtrot! The Garage: For OTHER car talk 34 03-28-2013 10:29 AM
