392 Engine noise - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 48 (permalink) Old 08-07-2018, 09:03 PM Thread Starter
spaceshipon22s's Avatar
392 Engine noise
Can someone please tell me what is this Tap/Tick im hearing? This is my 3rd Hemi, One 5.7 and Two 392’s so im well aware of what the ole Hemi tick sounds like but this is not that. Took it to dealer today and of course the noise was gone. They told me to bring it back in a couple days and drop it off so the car can sit overnight. This way they can hear it on a cold start to see if the noise is there. https://youtu.be/omUfjJ-ZctI
spaceshipon22s is offline
post #2 of 48 (permalink) Old 08-07-2018, 09:17 PM
us1champ's Avatar
Feedback Score: 10 reviews
Sounds like a rocker arm to me. Does it do it after warmed up?
2009 SRT
CUSTOM HEAD RESTS
us1champ is offline
post #3 of 48 (permalink) Old 08-07-2018, 09:18 PM
EngiNerd's Avatar
Always hard to tell in a video but that sure sounds like lifter noise...might have a spongy one. Unfortunately it does happen.
The 'good' news is it should get consistently worse/louder if it is a bad lifter.
And in the meantime I'd show that video to your dealer or service adviser.
EngiNerd is offline
post #4 of 48 (permalink) Old 08-07-2018, 09:27 PM Thread Starter
Yes it usually does it once the engine is warm as well. It started about a week ago. Ive been researching and there are videos with fuel injectors making this noise. Is that a possibility? I did put gas in it this morning before heading to dealership.
post #5 of 48 (permalink) Old 08-07-2018, 10:13 PM
EngiNerd's Avatar
Injectors do tap & rattle sometimes but usually it's a very quick tap-tap-tap sound since they spray a few times a second. The 'hard' tap I'm hearing at the top of the engine is most likely in the valvetrain.
2018 Challenger T/A Destroyer Grey
EngiNerd is offline
post #6 of 48 (permalink) Old 08-08-2018, 09:38 AM
That's a rather weird noise. Generally valve train related noise is a pretty regular noise. Kind of like "tick" "tick" "tick".
Not "tick"...."tick".........."tick".."tick"...
A mechanic stethoscope is very useful to help pinpoint where the noise is coming from. Knowing this helps reduce the guess work diagnosing what's going on. I'm sure when you take the car in the tech will use this unless it is clear to him where the noise is coming from.
Being that I'm not at the car and unable to confirm where the noise is coming from from just the clip that sounds more like an accessory drive noise. With the engine off check the accessory belt for any signs of degradation. With the engine running at idle and a bright light watch the belt to see if you can spot any abnormal movement.
With one of my cars after a brief stop to buy some food off a lunch truck when I restarted the engine I heard an irregular tick. Nothing appeared to be wrong, no warning lights, or messages, engine vital signs were ok, and I drove the car the couple of blocks to the office. Later in the day I restarted the engine and the noise was still present. Had the car flat bedded to the dealer. At the dealer the car was rolled off the truck. With SM and senior techs around I started the engine. Crickets.
Senior tech did a thorough check out of the accessory drive and found nothing. I took the car on a 30 minute test drive -- which duplicated the 30 minute drive to work -- and was unable to make the noise reappear. SM and tech told me that what probably happened is some trash got blown up and caught in the belt. Told me they see this with other cars maybe 6 times a year. Not common but not unknown either. In the case of my car the air blast the car was exposed to while on the back of the flat bed probably dislodged whatever it was that got caught.
There is another possible explanation though I don't know if this is plausible with your engine but there have been a few cases where something gets caught in the crank pulley and as the engine runs and this something rattles around inside the pulley cavity it makes an irregular "ticking" noise. In one case an owner found a small bolt caught. But a small rock can do it too.
Rockster is offline
post #7 of 48 (permalink) Old 08-08-2018, 10:36 AM Thread Starter
Thanks for the great info, im going out to the Garage right now and check the belt. I will definitely mention to the service manager to have the technician use a stethoscope. I know the manager pretty well and im sure he’ll do everything he can to pinpoint the sound IF it even does it again. It’s kind of funny how cars with wierd noise always fix themselves at the dealership. It makes it even harder since no warning lights are on.
post #8 of 48 (permalink) Old 08-08-2018, 10:36 AM
Isn't the EVAP purge solenoid located near there?
On my 5.7, during cold start up and 1/2 tank of gas the evap purge solenoid would cycle like crazy making it sound like a lifter.
ChallyTatum is online now
post #9 of 48 (permalink) Old 08-08-2018, 11:30 AM Thread Starter
Ok, I just did a cold start and the tick/Tap is definitely back. So hopefully it will do the same thing when i leave it with dealership. Here are a couple more clips, cold start with hood opened and closed. I even let the exhaust be heard just in case someone thinks the engine is misfiring. https://youtu.be/Bc6NjWMxfLQ https://youtu.be/itcksIF-h8w
post #10 of 48 (permalink) Old 08-08-2018, 12:07 PM
Have you confirmed the noise is not coming from the evap solenoid? It will cycle on cold starts when tank is not full.
Just heard the 2nd video, that ain't no evap tick...sound more like a clack.
2014 Core 6 spd, loud clunk at low speeds Toxic 6.4L / 392ci (2011 - ?) 53 12-27-2015 11:46 AM
Change Oil Message RYGLaunch General Challenger Discussion 17 12-13-2013 04:00 PM
Chrysler's SEMA surprise: 392 HEMI Dodge Challenger Super Stock ekool Dodge Challenger News 44 06-04-2007 03:50 PM
New Dodge Challenger SUPER SPORT At Sema... Vanishing Point General Challenger Discussion 100 11-15-2006 01:41 PM
