Broken rear cradle bolt nightmare *Need assistance - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 27 (permalink) Old 04-14-2019, 12:28 PM Thread Starter
Janson's Avatar
Exclamation Broken rear cradle bolt nightmare *Need assistance
Yesterday I set out to install Petty's front/rear sway bars and front/rear strut tower bars. I was hoping to be able to post pictures with excitement but as luck would have it, this is not the case.
I installed the rear sway bar and was torquing the cradle bolts. I snugged all four down and used a torque wrench to torque them. I got to the final bolt (in the front) and the bolt snapped. I have never had such a good day go to shit so fast. I feel completely defeated and need advice on how to fix this.
I have attached pictures of the broken bolt and the location of where it goes.
How would you recommend fixing this? I have fixed broken bolts before but never in a spot like this.
Is my car even drivable if I decide to take it to a dealer to fix?
Any help is much appreciated. Thanks in advance.
ID:	943601   Click image for larger version
2015 Scat Pack
8-speed auto, black on black, SP appearance group, leather, sound group II, Mopar stage 1 performance springs, DFS wickerbill, Luxe reflector tint, Tredwear tire letters
Janson is offline
post #2 of 27 (permalink) Old 04-14-2019, 01:08 PM
BlackHemi41's Avatar
Might have to drop the cradle down again to gain access to what's left of the bolt. If there is enough left sticking out, you might be able to grab it with a good set of vice grips, or weld a nut on the end of it. If there isn't enough to grab on to, it's going to be a challenge. It may require an extractor set, or drilling a pilot hole in the center and hammering a torx socket into it to grab on. Then push it into it as you loosen. If that's something you're not comfortable doing, definitely take it to a shop.
At least you know it's not seized, and without the head of the bolt, there shouldn't be much torque on it.
Maybe consider replacing all of the cradle bolts.
Edit: Just looking at your picture, that looks like the diff mounting bolt location. Is that what you broke?
BlackHemi41 is offline
The Following User Says Thank You to BlackHemi41 For This Useful Post:
Janson (04-17-2019)
post #3 of 27 (permalink) Old 04-15-2019, 08:36 AM Thread Starter
Janson's Avatar
Thanks for the advice BlackHemi41... Yes it is the differential mounting bolt location that snapped. I dont believe there is any threads hanging out but will take a better look today. It broke at the end of the day Saturday after working on the car all day. I was demoralized and tired so I called it quits.
I found out what i did wrong. Dodge calls the two bolts on the front of the cradle (near the differential) the rear axle forward mount isolator bolts (see attached image). Their torque specifications for those bolts is only 52 lbs. I confused this with the rear crossmember bolts and over torqued them.
I am capable of dropping the cradle but my fear is that to extract this I would have to fully drop it and get it out of the way which may be more than I want to do on my garage floor. At this point I am going to reach out to the dealer as well in case it looks like I can't get to the threads. I'm so disappointed in myself for making such a stupid mistake. Either way, life goes on.. Hopefully this will help others out.
If anyone has any additional advice feel free to let me know. Thanks!
Name:	rear axle forward mount isolator bolts.PNG
Janson is offline
post #4 of 27 (permalink) Old 04-15-2019, 09:06 AM
Looks like you will need to just drop the diff and use a left-hand drill with a screw extractor. If there is a little of the bolt sticking out I have had success welding a nut (need a nut with a larger i.d. than the bolt o.d.) to the bolt and backing it out. Good luck man!
Janson (04-17-2019)
post #5 of 27 (permalink) Old 04-15-2019, 09:56 AM
Yeah I was kinda wondering about that. Not just lower torque value but those diff isolator bolts are only one time use as well. It sucks but **** happens.
Janson (04-17-2019)
post #6 of 27 (permalink) Old 04-16-2019, 06:55 AM
SlammedRT's Avatar
I would definitely try a left hand screw extractor before dropping the craddle.
2014 R/T M6 - Granite Crystal
LMI True CAI V2, MM 87mm Ported TB, Port matched intake manifold, JBA Long Tube Headers, JBA midpies w/ Cat delete, SLP loudmouth I, 180 TStat, Custom Tune by Heldenburg's, Staggered TSW Tremblant on Nitto NT555 G2, KW Suspension Coilovers
SlammedRT is offline
The Following User Says Thank You to SlammedRT For This Useful Post:
Janson (04-17-2019)
post #7 of 27 (permalink) Old 04-17-2019, 08:20 AM Thread Starter
Janson's Avatar
I did some research and dropping the rear diff doesnt seem so bad. Hopefully, the bolt plays nice and is easy to remove. I used my endoscope to get a better picture of the snapped bolt. It looks like a pretty clean snap. There is a small ridge so i may try to soak in pb blaster and use a punch to see if i can tap it at an angle to get it to spin back out. If not, I will try left handed drill bits.
Now if I can only find the bolts in time.. Steve white didnt have the "single use" driveshaft bolts in stock. I didnt even ask about the isolator bolts.
Janson is offline
post #8 of 27 (permalink) Old 04-17-2019, 08:46 AM
Looks like a perfect candidate for a screw extractor. Although, I have only used the square type extractor.
Janson (04-17-2019)
post #9 of 27 (permalink) Old 04-17-2019, 03:09 PM
McCloud's Avatar
yeah I would use a left handed drill bit to set your pilot for the extractor. Based on the design of that bolt and how it snapped you may get lucky and have it come out just by using the left handed drill bit.
McCloud is offline
post #10 of 27 (permalink) Old 04-17-2019, 04:50 PM
409 Fever's Avatar
Let us know how it turns out Janson.
Best of Luck to you!
Some people just gotta be different...
409 Fever is offline
The Following User Says Thank You to 409 Fever For This Useful Post:
Janson (04-20-2019)
Tags
cradle , rear differential , sway bar
Rear suspension cradle alignment NMRT Wheels, Tires, Brakes, and Suspension 9 02-22-2019 07:18 AM
Rear Cradle BlackHorse Wheels, Tires, Brakes, and Suspension 0 12-29-2015 05:04 PM
How to lower your r/t or se mopar stage one stevewhiteparts Steve White Motors 155 04-30-2015 12:25 PM
Rear axle seal broken SGT2012RT Challenger Issues & Problems 4 07-06-2012 11:09 PM
