Engine failure - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 25 (permalink) Old 01-25-2019, 06:56 AM Thread Starter
SatoriSRT's Avatar
Engine failure
Hi All.
I have a 2014 SRT challenger with 30,000 miles
Last night driving to friends house . I see my whole dash light up like a Christmas tree. Engine stops dead. Had to get it towed back to house .
Then to dodge dealer .now I wait to see if they are going to replace or repair. My question is this a common issue with dodge hemi s ? Also will this hurt car value?
Thanks
SatoriSRT is offline
post #2 of 25 (permalink) Old 01-25-2019, 08:10 AM
Originally Posted by SatoriSRT View Post
Hi All.
Thanks
What makes you think it is a mechanical (i.e. engine) failure and not electrical (i.e. PCM or bad harness)?
post #3 of 25 (permalink) Old 01-25-2019, 08:30 AM
Hi All.
Then to dodge dealer .now I wait to see if they are going to replace or repair. My question is this a common issue with dodge hemi s ? Also will this hurt car value?Thanks
ChallyTatum asks the right question.
If the engine is toast and needs to be replaced the new engine, a new factory engine with some warranty, can actually help boost the car's value if you choose to sell/trade in the car afterwards.
You want to be sure to save all the paperwork that shows the engine failed through no fault of yours.
As for the no longer "matching" numbers (VIN and engine number) big deal. Older Dodges that become worth a lot of money have mismatching numbers the least of their problems when they are found and resurrected. Years of sitting in a barn or worse. Mice and rat you know what knee high in the car. Rust. And so on.
Best thing you can do to preserve the car's value is give it proper servicing. Take care of issues when they arise. Don't mod the car. Avoid accidents. And last but not least just drive the car, enjoy the car.
Rockster is offline
Bob Ricewasser (01-27-2019)
post #4 of 25 (permalink) Old 01-25-2019, 10:15 AM Thread Starter
SatoriSRT's Avatar
Ok thanks for responding. From dealer they know its mechanical. Only question now they are waiting on corporate to say repair or replace motor.
post #5 of 25 (permalink) Old 01-25-2019, 10:30 AM
Clevetown's Avatar
Wow never heard of that happening before at 30K miles!! Good luck!
2015 Scatpack 392 M6
Black/black
Stainless Works LT Headers
High flow cats
Resonator delete
274 Comp Cam with vvt limiter
Arrington 84 mm throttle body
Barton short throw shifter
Unlocked PCM
Diablo Sport Tuner
HHP Tune
Mopar CAI
Mopar front/rear strut tower braces
Speedlogix SS eliminator
Black lug nuts with Hellcat center caps
Mopar Performance Lowering Springs
Hellcat ram air intake
Hellcat red start button
275 Nittos
Heated/Ventilated seats
Clevetown is offline
post #6 of 25 (permalink) Old 01-25-2019, 11:01 AM
Slidd's Avatar
Still have warranty?
And only thing on FCA and the powertrain, do you have service records or proof that you changed your oil and filter at least every 6 months?
Slidd is online now
post #7 of 25 (permalink) Old 01-25-2019, 12:22 PM
rickytan's Avatar
Hi All.
Thanks
I’m having the same issue with my 2014 Dodge Challenger SRT it’s at the dealership due to a cyclinder misfire ignition 6
I haven’t heard anything back from the dealership as of yet it’s been there for a week now.
rickytan is online now
post #8 of 25 (permalink) Old 01-25-2019, 01:10 PM
DodgeCares's Avatar
Hi @SatoriSRT and @rickytan ,
We're terribly sorry to hear that you are experiencing this with your Dodge Challenger! Please let us know if you need additional assistance while your vehicle is in service by sending our team a private message.
Darlene
Dodge Social Care Specialist
DodgeCares is online now
post #9 of 25 (permalink) Old 01-25-2019, 01:38 PM
That may not be the dealer's fault, though of course regardless you are still in the dark.
Had a car in for some servicing. Tech spotted a transmission selector shaft fluid leak. Car under warranty. The dealer service department contacted the factory to ask repair? Or replace? Silence from the factory. Finally after IIRC nearly a week the factory got back to the dealer and said to "replace" and said a new transmission would be shipped. A couple of weeks later the transmission arrived and a day or so later I had the car back. But all told it took around 3 weeks.
Rockster is offline
post #10 of 25 (permalink) Old 01-25-2019, 02:21 PM
I have seen a couple of threads where the cylinder misfire was linked to a bad lifter/cam lobe.
