Star Case # S1021000004-Bad grease in the 2009 Tremecs - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 50 (permalink) Old 06-24-2014, 04:48 PM Thread Starter
swiftjr's Avatar
Send a message via Skype™ to swiftjr
Good Day All,
Well, I bought my 2009 R/T Tremec 6-speed 2 years ago May. It had 42,000 miles on it and had been regularly serviced, but had never been taken in for the known grease issue. I figured if it had not happened yet, it was fine, so I bought the 3rd party platinum warranty just in case. About 2 months ago (70,000 miles) I started having trouble shifting at high RPM. No big deal, right? Well, the dreaded grease that turns to glue at high heat fused the pilot and throwout bearing to the input shaft. And my "Platinum" warranty blamed the issue on the throwout bearing which is not covered so it's not covering the transmission either. The vibration "warped" the input shaft, so now I am paying out of pocket for the whole kit and kaboodle.
A word of advice, if you have a 2009-2010 6-speed have this checked out. The labor to have your grease redone and 6 bolts changed on the flywheel beats the $3500.00+ I am paying now. My car seemed fine, no vibration, you could still shift at low RPM (around 3000) with one finger so I continued to drive it. My bad I know NOW. I even contacted Dodge to no avail. I really think this should have been a recall. I do not care what Tremec says, these initial units were garbage.
The only bright spot is the dealership is refunding 1/2 my warranty cost. This should get me out with about 700 bucks more than a clutch job, so I am counting my blessings!
Update: You cannot purchase the garbage brass synchros any longer, so another 800 for carbon fiber. Transmission, clutch and labor...$5200.00. Anyone want to buy a kidney?
2009 R/T Deep Water Blue 6-Speed (Only 450 made in this trim in 2009)
20" Foose Legend Wheels and HD Brakes
Drilled and Slotted Rotors with Ceramic Pads
Hurst Linkage w/ G & K Mods and Hurst Pistol Grip Shifter
Lowered 1.7" with Eibach Springs and Sway Bars
Blue BT Catch Can-K&N Air Intake-Cabin Air Filter
Mopar Exhaust Tips,Caps,Front Badge,Steering Wheel,and Fuel Door Insert
Caliper Covers, Polished Stainless Steel Under the Hood
swiftjr is offline
post #2 of 50 (permalink) Old 06-24-2014, 05:04 PM
cannonballcobb's Avatar
Man, your car is the first I've heard to have a warped input shaft because of the known lack of grease issue... Have you considered getting a second opinion?
cannonballcobb is offline
The Following User Says Thank You to cannonballcobb For This Useful Post:
swiftjr (06-24-2014)
post #3 of 50 (permalink) Old 06-24-2014, 05:49 PM
I totally agree that this should have been a recall. It not only effects 2009's, but information on this subject indicates 1/2 the production year for 1010's. Any defect of the clutch system that presents a safety hazard (vehicle rolling under engine power power, with the clutch fully disengaged buy maximum pedal depression) constitutes an obvious safety hazard. Dodge has been VERY lucky on this one. The $3,500 price to repair your car is revolting. I know you just want to get your Challenger back in good form. I hesitate to say that in my personal circumstances, I would be tempted to pull up the numerous archived threads on this site AND other Challenger and LX forum sites. Document the Chrysler Star Fix details, and present this to a legal representative.
This site is monitored by a representative from "Dodge Cares" her name is Rebecca.....
Rebecca, are you listening?
This is just simply not right. Rather than having MANY owners have to go from dealership to dealership, until they found someone who was able to acknowledge the existance of the defect and resolve it under the Chrysler Star FIX, Chrysler/Dodge should have established a recall for this safety hazard back in '09. I wish you the best of luck.
3 peddles is offline
The Following 3 Users Say Thank You to 3 peddles For This Useful Post:
salvy59 (08-22-2014), swiftjr (06-24-2014), The Chromer (07-30-2014)
post #4 of 50 (permalink) Old 06-24-2014, 06:22 PM Thread Starter
swiftjr's Avatar
It's technically listed as a throwout bearing issue. No way to "prove" it was the grease. If I get a second opinion and it's the same, I have to pay the assessor. I trust the guys at my transmission shop. They just gave me the final appraisal. It is now $5100.00 because you can not even get the crappy parts anymore. It's a mandatory upgrade to the carbon fiber synchro kit. I have been in communication with Dodge, I received the "it's no longer under warranty" email. At least with the rebuild I will get a warranty from people I trust.
swiftjr is offline
post #5 of 50 (permalink) Old 06-24-2014, 06:33 PM
SWIFTJR, the fact that the seizing grease on the input shaft problem has never been addressed on your car is records proof positive, that the end result is your current part failures.
Rebecca...Time for Dodge to step up.
post #6 of 50 (permalink) Old 06-24-2014, 07:01 PM Thread Starter
swiftjr's Avatar
Well, at least I got to vent. I documented Dodge's official Star Fix and sent it along with an explanation to my local NBC affiliate and also Dateline NBC. Title, Dodge should have had a recall for safety's sake alone.
swiftjr is offline
The Following User Says Thank You to swiftjr For This Useful Post:
3 peddles (06-25-2014)
post #7 of 50 (permalink) Old 06-25-2014, 11:48 AM
Goes to show you, the aftermarket warranty's are JUNK, platinum or not. How can a bearing not be covered???
3boystoys is offline
The Following User Says Thank You to 3boystoys For This Useful Post:
post #8 of 50 (permalink) Old 06-25-2014, 01:09 PM
I have lifetime powertrain AND an additional warranty on my car. I have 59,000 miles and just got denied for the SECOND time. I tried once a few years ago and got shot down then too. My cars clutch is binding so bad that when it sticks I can have the clutch fully depressed and the car will still accelerate forward from a stop! The technician was speechless and had never seen a car do that.
Report it on the NHTSA website. I did and there were already others on there. If they get X number of complaints they have to launch an investigation.
https://www-odi.nhtsa.dot.gov/Vehicl...nt/index.xhtml
This one was previously filed and I filed another one.
Date Complaint Filed: 03/27/2012
Component(s): POWER TRAIN Date of Incident: 11/09/2011
NHTSA ID Number: 10453265
All Products Associated with this Complaint expand
Details close
0 Associated Documents
Crash:No Fire:No Number of Injuries:0 Number of Deaths:0
Manufacturer: Chrysler Group LLC
Vehicle Identification No. (VIN): 2B3LJ54T89H...
SUMMARY:
HELLO! HARD SHIFTING 6SPEED MANUAL: I HAVE BEEN HAVING SHIFTING PROBLEMS WITH MY MANUAL TRANS FOR A COUPLE OF MONTHS. IT STARTED BACK IN NOV 11 WHEN TRAVELING OUT OF TOWN,GOT STUCK IN TRAFFIC AND CLUTCH STARTED TO NOT DISINGAUGE ALL THE WAY (WOULD CREEP) HAD TO HOLD FOOT ON BRAKE OR PUT IN NEUTRAL EVEN AFTER PULLING OFF THE ROAD. LATTER WHEN COMING HOME BAKED INTO PARKING SPACE TURN KEY OFF WANTED TO PUT IN OTHER GEAR WAS VERY HARD TO PULL OUT OF REVERSE. HAS GOTTEN WORSE, IT IS GETTING HARDER TO SHIFT WHILE DRIVING. MY WIFE WENT TO GET ON THE HIGHWAY AND HAD VERY HARD TIME GOING INTO LOWER GEAR ALMOST GETTING HIT IN THE REAR.DODGE SAYS WORN CLUTCH,BUT IT DOESN'T SLIP, BUT THEY HAVE A NOTICE ABOUT GREASE BEING ON INPUT SPLINE THATS THE CLUTCH SLIDES ON GETTING DIRTY FROM TO MUCH GREASE AND DIRT, MAKING THE DISC STICK NOT FULLY DISENGAGING. THIS IS A MANUFACTURING DEFECT,ASSEMBLING LINE DEFECT NOT MINE. BEEN TO TWO DEALERS AND ASK 4 ABOUT THE PROBLEM. *TR
2009 Stone White R/T
D1 w/ Stage II FMIC | 85mm Ported Throttle Body
ARH Longtubes | Corsa Sport Exhaust |
BigRobsRT is offline
The Following User Says Thank You to BigRobsRT For This Useful Post:
swiftjr (06-25-2014)
post #9 of 50 (permalink) Old 06-25-2014, 02:41 PM Thread Starter
swiftjr's Avatar
Details close
SUMMARY:
Thanks Big Rob. I just entered my complaint also.
swiftjr is offline
post #10 of 50 (permalink) Old 06-25-2014, 03:37 PM
Just saw this tread and I too am having similar issues with this transmission. I can't get into first gear when stopped at a light and have an extremely difficult time engaging reverse.
It seems to me the clutch or syncros are not working properly. It also seems that the Camaros and Mustangs are having similar issues with these JUNK Tremec 6060 transmissions.
I have an appointment with the dodge dealer on 7/5. Cant wait to hear the BS from them.
I reported my issue to the NHTSA and hopefully with many more reports of this issue they will force dodge or Tremec to repair or replace these faulty junk transmissions.
Shame on Tremec for not owning up to there quality control issues or issues with this specific transmissions.
Personally I will never buy a car with another TREMEC in it.
Delivered 12/7/2009
2010 DWB R/T 6-SPD Trak-Pak
Elec. Conv. Package
Hood to Fender Stripes
Sound Group II
20" Chrome Clad Wheels
Media Center 730N
Diablosport Tuner
C&L CAI
FlowMasters Force II Cat Back
Jet 180 Thermostat
stamatz is offline
6 Spd input shaft grease Star center case K38556860 needed aarcuda Technical Service Bulletins & Recalls 28 05-19-2015 08:49 AM
P0300 Star Case plmczy14core Technical Service Bulletins & Recalls 1 07-31-2014 02:18 PM
Star Case # K38556860 why isn't a recall? dan30097 General Challenger Discussion 43 12-09-2012 05:59 PM
Star Case # K38556860 why isn't a recall? dan30097 Technical Service Bulletins & Recalls 5 10-22-2012 02:04 PM
2009 Dodge Challenger Pricing! dascrow Dodge Challenger News 890 12-21-2009 05:43 PM
