Steering Wheel Off Center - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 5 (permalink) Old 05-21-2019, 01:24 PM Thread Starter
jakester's Avatar
I have a 2018 Challenger Scat Pack I recently bought. My steering wheel is off center a bit. The picture shows the wheel when the tires are pointed straight. The car tracks really well, don't expect any sort of front end problem.
Is this common with these cars? Easy to fix?
Name:	Steering Wheel.jpg
jakester is offline
post #2 of 5 (permalink) Old 05-21-2019, 01:28 PM
The steering wheel on my 2018 is perfectly straight (would drive me crazy otherwise). You probably need ot get an alignment to fix it - it is NOT normal. Strange that it needs an alignment so soon in it's life though. I'm assuming you bought it used. I guess it's always possible the previous owner knocked it out of alignment somehow...
jtrosky is offline
post #3 of 5 (permalink) Old 05-21-2019, 05:09 PM
easy to fix - needs to be put on an alignment rack and adjust to tie rod ends with the steering wheel centered
Hal H is offline
post #4 of 5 (permalink) Old 05-21-2019, 06:20 PM
hemi4us's Avatar
^this^ beat me to it..
car is misalligned..prepare for bad news if they are telling you its within alignment specs as it is now.
any accident history?
2015 Mods:
Axis Model II's.
Firestone Indy 275/40/20
Rolling Thunder Reso delete.
GPC Trunk Pull Handle.
Spare/Jack/Foam Delete.
GPC Phantoms.
Mopar O.E. Black Fuel Door.
Hellcat OE. ABS Cover.
Rear Seat Delete.
2014 Dodge Viper Seats.
hemi4us is offline
post #5 of 5 (permalink) Old 05-21-2019, 09:03 PM
What you need is a 4 wheel thrust angle alignment. After the car is placed on the alignment rack with the front tires on the turn tables and the rear wheels on the skid plates, the car is lifted, the sensors mounted & compensated, then the car is lowered back down on the rack. The locking pins are removed from the turn tables and rear skid plates. The rear camber and toe are checked first and adjusted to spec if possible. Then the front caster, camber, and finally toe are checked and adjusted. Any correction on the front suspension will necessitate a toe adjustment. Before adjusting the toe, the car should be started and the steering wheel centered and locked in place with a steering wheel holder. I forgot to mention that a brake pedal depressor should also be used to lock the cars service brakes so it doesn't move on the rack while the alignment is taking place. When the alignment is complete, the car should be road tested to make sure it doesn't pull and the steering wheel is centered.
Bob Ricewasser is offline
Heated Seats and Steering Wheel Won't Shut Off 1340busa Challenger Issues & Problems 7 03-07-2018 04:34 AM
Installing SRT steering wheel in 2012-2014 R/T hemistrong Dodge Challenger R/T Specific 8 09-07-2015 05:14 PM
Centering the steering wheel...any luck? Force10 General Challenger Discussion 6 08-27-2015 05:00 AM
2012 Challenger information thread ResumeSpeed General Challenger Discussion 651 07-31-2015 01:20 PM
Steering wheel options StoneLC Interior Discussion / Modifications 12 07-26-2008 03:38 PM
