Water leaking into steering column - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 11 (permalink) Old 04-14-2019, 06:56 AM Thread Starter
KWJCDon's Avatar
I've tried searching with no luck so I going to start this thread. Any help or assistance would be great!
I have a leak in my 13 RT. It is going into the steering column and running onto the floor. When this happens, it shorts out the car not allowing it to start and the alarm goes off randomly. It does not appear to be the windshield so I am thinking it is coming from the drain outside.
My questions are has anyone had this happen to them. If it is the drain what is the best way to rectify it?
This is my 4th problem with this car and now thinking of selling it. My local dealership in Key West is not good at all so would have to go to Miami if someone thinks that what I have to do.
Looking forward to hearing back from someone!
Conceived: 9/11/12
Born: 10/12/12
Delivered: 10/26/12
KWJCDon is online now
post #2 of 11 (permalink) Old 04-14-2019, 07:25 AM
I take it you have a sunroof? If so I would guess the drain tubes might be leaking. If you don't have a sunroof then I would guess your windshield seal might be leaky.
post #3 of 11 (permalink) Old 04-14-2019, 07:52 AM Thread Starter
KWJCDon's Avatar
I forgot to add that it isn't coming from the sunroof. It is bone dry in there. That was the first thing I checked.
post #4 of 11 (permalink) Old 04-14-2019, 09:32 AM
I'd suspect your windshield is leaking - since gravity will have the water go down to the lowest point:
Its leaking and running along inside the dash (probably in the area where the ignition switch / push button and other wiring is).
then, it gets to the column and runs down the column, to the floor.
The column has a seal to the firewall, but that's 2/3 of the way down from the cowl - so water would not travel up from there and short anything out.
-all your modules are either in the dash or at the the steering wheel
Another thing is if water is dripping down to the accelerator pedal, that connection could short out, causing issues as well. Its about the lowest point of any under dash connections in the vehicle - and its bolted to the firewall, if any water was running down it
Hal H is offline
Flat Top (04-14-2019)
post #5 of 11 (permalink) Old 04-14-2019, 11:13 AM
Flat Top's Avatar
Water or moisture is your enemy near any internal wiring. I never buy flood cars as I made that mistake, Once. I agree the windshield my be leaking as Hal said.
FT
Flat Top is offline
post #6 of 11 (permalink) Old 04-14-2019, 11:50 PM
FastScat's Avatar
Possibly your firewall too. Maybe a gasket has shrunk or out of place.
2016 Challenger SPS 392 A8 pitch black
Tech group
Conv. Group
NAV
Harmon Kardon
Sun roof
Tint
Speedlogix oil catch can
MagnaFlow axleback exhaust quad tips pt#19206
FastScat is offline
post #7 of 11 (permalink) Old 04-15-2019, 03:16 PM Thread Starter
KWJCDon's Avatar
Thanks all. I am having the windshield done tomorrow so hopefully that is it. If not, then Plan B. LOL
post #8 of 11 (permalink) Old 04-16-2019, 03:07 AM
Punisher_1's Avatar
Do these cars also have an AC drain that might clog? I also have a Jeep with a air intake drain (by the wipers) which clogged and ran inside through the heater air intake. So I don’t know if a Challenger has a cowl drain also.
Punisher_1 is offline
post #9 of 11 (permalink) Old 04-16-2019, 05:21 AM
there's a A/C plenum drain - on passenger side. Its down low(er), below where the steering column is.
If it were full of water, I'd expect it would leak water out the lower floor vents, which are on either side of the trans tunnel
Hal H is offline
post #10 of 11 (permalink) Old 04-16-2019, 06:22 AM
DodgeCares's Avatar
Hi KWJCDon,
We're sorry to hear you're having such a tough time with your vehicle. If you end up going into the dealer, let us know. We can get a case created and escalate it to a case specialist for further handling.
Jasmine
Dodge Social Care Specialist
DodgeCares is online now
What includes hydrolock testing texpitt Dodge Challenger R/T Specific 12 07-10-2018 02:57 PM
Possible Issue with Steering Column... GearJunkieRTSP Challenger Issues & Problems 2 04-19-2017 10:28 AM
adjustable electric power steering column connections mattv 2015 Challenger Information & Discussions 0 02-19-2017 09:25 PM
Installed Long tubes and have a severe steering column issue! Help Cwarta Performance Modifications 6 02-04-2013 10:32 AM
Water Leaking From Trans-Pan? Redstorm3265 Challenger Issues & Problems 2 09-06-2012 01:00 PM
