Whistling noise in 392 Shaker Hemi - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 7 (permalink) Old 12-10-2018, 05:55 PM Thread Starter
Rdbegley's Avatar
I have an 2018 392 Scat Pack Hemi and after the first oil change at 3,000 miles, I am hearing a whistling noise while idling. Don’t hear it when I rev it up, only at idle. It’s getting annoying but the Dodge dealer that looked at it said that the shaker hoods are prone to make air noises. This isn’t a normal low air noise, it’s a high pitch whistle that others can also hear outside of the car. Anyone else have this problem and surely it can be fixed, it’s kinda embarrassing to have a hot rod that is whistling
Rdbegley is offline
post #2 of 7 (permalink) Old 12-10-2018, 06:48 PM
that sounds like a vacuum leak.
Might want to see if the tube to throttle body is secure.
Another item might be if throttle body to manifold is secure.
The other steps:
(this would require removing the shaker scoop and the base plate)
check the 10 manifold bolts to see if any are loose / need tightening (they only require 105 in.lb. of torque)
a remote possibility is if an injector seal to the runner is leaking vacuum
one other area to investigate - the vacuum hose from rear of intake to power brake booster. If there's any damage to the hose or possibly the connector that is attached to the booster unit...
The Shakers will have a whistle under acceleration (you'd hear with window open), but that's about it.
Hal H is offline
post #3 of 7 (permalink) Old 12-10-2018, 10:22 PM
PlumChallenger's Avatar
It does sound like a vac leak.
The variable is the oil was changed and then the noise started.
Shaker assembly gets removed I believe for oil service, so reverse engineer it and look for a loose hose, seal, etc. that would get removed or knocked off when changing the oil.
R&R shaker assembly
Use a stethoscope to pinpoint the noise maker if needed. Take the probe tip off and point the hoses around until the leak gets loud.
PlumChallenger is offline
post #4 of 7 (permalink) Old 12-10-2018, 11:00 PM
Poor mans whistle finder
A Guy is offline
post #5 of 7 (permalink) Old 12-11-2018, 04:39 AM Thread Starter
Rdbegley's Avatar
The mechanic took the shaker off and said he checked the seals and also greased the seals but couldn’t find any reason why it was whistling. I’ll see if I can’t find someone else to check it again at Dodge since it’s under warranty and I’m not happy. Thanks for y’alls suggestions
Rdbegley is offline
post #6 of 7 (permalink) Old 12-11-2018, 05:58 AM
as @PlumChallenger mentions, using a stethoscope (versions are made for tracing engine noises) - while the engine is running to trace down the location of the whistle / sound will narrow down what to look for.
The other item I forgot to mention in the prior post is whether the PCV system has a leak. This wouldn't have been an item involved with the oil change (the shaker base plate covers this up, normally base plate isn't removed for oil change service...).
another item to check is the MAP sensor (rear of intake) if that O-ring seal has a leak
From what you describe, its an item that has a constant high vacuum source at idle, and that points to a vacuum leak somewhere.
Today's cars don't have the myriad vacuum lines we used to see on the 70s/80s/90s engines, so there's fewer items to trace down.
You used to have vacuum lines for:
air diverter valves [A.I.R. pumps]
distributor timing vacuum advance
EGR valves
HVAC dampers
exhaust heat valve / crossovers
thermostatic air cleaner heat control
coolant over temperature valves
MAP / BARO sensors
turbocharger waste gates
and so forth. There was a lot of "spaghetti" under the hood and the fittings or hoses would deteriorate and leak. The computer controls eliminated a lot of vacuum / mechanical system that used to be in many applications.
Hal H is offline
post #7 of 7 (permalink) Old 12-12-2018, 03:26 PM
DodgeCares's Avatar
Hi Rdbegley,
We understand why this may be concerning. We would be happy to have a case escalated for you so a Case Specialist can work with your dealer to help find a potential solution to this. If you are interested, just send us a private message!
Lydia
Dodge Social Care Specialist
DodgeCares is online now
