WHY can't I clear a CEL (P0456) on 2011 SRT8?? - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 16 (permalink) Old 04-06-2019, 09:24 PM Thread Starter
11srt8's Avatar
Owned this car over a year, and it picks TODAY, the day I need to get an inspection sticker to throw it's first CEL. Are you Fin kidding me? Scanned it, P0456 evap code loose gas cap, probably my own fault since I pump my own gas. NP I'll just clear it with my scanner, put 50 miles on it on a beautiful 65 degree day and get the inspection later. WIN WIN right? WRONG!!!
Neither my scanner, nor the Diablo will clear the dam code. WTF??? I have successfully used my scanner on dozens of cars...never seen it fail.
Yes, I am aware I could simply disco the battery for a bit but don't really feel like reprogramming everything - Bluetooth, etc.
Also learned that remote start gets shut down after 3 seconds with a 'fuel related' CEL. GRRRRRR
11srt8 is offline
post #2 of 16 (permalink) Old 04-06-2019, 11:27 PM
Is is stored as a permanent code? If you can't clear it, I suspect it must be. This indicates that the leak still exists and the computer must see three fault free operating cycled before the code will clear. I think you can also do a dtc clear then only need on fault free operating cycle. This is so you can't get around cel issues for inspections by disconnecting the battery or clearing the code.
KDodge75 is offline
post #3 of 16 (permalink) Old 04-07-2019, 05:03 AM
SRT8 Mike's Avatar
Key on engine off? Most Mopar the engine can’t be running to clear engine codes.
SRT8 Mike is offline
The Following User Says Thank You to SRT8 Mike For This Useful Post:
A Guy (04-07-2019)
post #4 of 16 (permalink) Old 04-07-2019, 08:25 AM
Permanent codes cannot be cleared by scanners/readers. Only the PCM itself can clear them once the evap monitor runs and achieves the pass criteria.
ID:	943029   Click image for larger version
post #5 of 16 (permalink) Old 04-07-2019, 08:52 AM
SRT8 Mike's Avatar
Where does it state it can’t be reset by a scanner? I can reset any codes on almost any car with my Snap On Solus . If the criteria is not met it may not reset. But it will reset and codes. Especially on Chrysler. Through the scanner you can do what they call a battery disconnect without disconnecting the battery or a complete reset which will scan every code in every module and clear them.
post #6 of 16 (permalink) Old 04-07-2019, 08:55 AM
Again, "permanent" codes cannot be cleared by scanners.
https://www.autoserviceworld.com/car...ermanent-dtcs/
https://www.motor.com/magazine-summa...erify-repairs/
Next time you try to clear a code, check if it is listed as permanent...I guarantee your Solus or even a dealership tool will not be able to clear the code.
Even HP tuners brings this to everyone's attention
https://forum.hptuners.com/showthrea...ight=permanent
This is why if you have fairly strict emissions in your state that you need to rethink your decision to run cat-less as no amount of disabling DTCs will get rid of O2/Cat codes and there is absolutely nothing you can do about it...except to put the cats back.
post #7 of 16 (permalink) Old 04-07-2019, 09:56 AM
As others have mentioned the code could be permanent. In this case it can only be cleared by the engine controller after so many warm up cycles with the error condition absent.
A permanent code should not have the CEL on.
Don't know if the presence of a permanent code will have the vehicle failing an inspection.
If the CEL is on though the code is not a permanent code but an active code. And you can clear it but as soon as the engine is started the error condition is detected and the CEL comes right back on with the same error code.
Rockster is offline
post #8 of 16 (permalink) Old 04-07-2019, 10:54 AM
Anything Evap is emissions monitored...hence a permanent code. If you read the first image I posted you will see the fail does not reset until the system sees a valid condition. I am pretty sure the evap monitor shows incomplete. In IL you are allowed 1 incomplete monitor on vehicles 2001 and newer.
post #9 of 16 (permalink) Old 04-07-2019, 01:02 PM Thread Starter
11srt8's Avatar
Looks like my Diablo worked. Think I just needed it to be in IGNITION mode but NOT running. Thanks for the input!
11srt8 is offline
post #10 of 16 (permalink) Old 04-10-2019, 04:53 PM
turbotato's Avatar
Make sure your PCM is IM-ready before you take it in for inspection...otherwise they will not be able to inspect it. IM-readiness prevents the "clear the code and take it to be inspected" trick from happening. Some cars can be a PITA to clear IM-readiness...I've seen it take hundreds of miles of driving to reset the monitors. Most good scan tools will have an IM-readiness scanning capability. Good Luck!
turbotato is offline
2019 Challenger information thread ResumeSpeed General Challenger Discussion 600 02-19-2019 06:34 AM
New Site Upgrade and Look Feedback Thread AG Jeff ChallengerTalk.com Website Problems 253 07-26-2017 08:54 AM
Unable to start a new thread Yahooligan ChallengerTalk.com Website Problems 9 10-13-2016 08:16 AM
8 Speed for GC SRT Go Goody The Garage: For OTHER car talk 5 07-20-2013 06:21 PM
