S&M driveshaft loop and 4" one piece shaft - Dodge Challenger Forum: Challenger & SRT8 Forums
post #1 of 13 (permalink) Old 04-12-2019, 09:18 AM Thread Starter
Well I pulled the trigger on a driveshaft loop. About a year ago nothing was available for a 4" one piece driveshaft...at least for a manual trans. I reached out to S&M and they said their loop will fit but it is tight. Guess I will see how tight is tight...unless someone already has first hand experience?
https://www.highhorseperformance.com..._p/smpmdsl.htm
post #2 of 13 (permalink) Old 04-12-2019, 01:46 PM
Gila Hemi's Avatar
I tried to add a driveshaft loop when I installed my DSS driveshaft. It didn't even come close to fitting with a 4" driveshaft installed...
Member:
Gila Hemi is offline
post #3 of 13 (permalink) Old 04-12-2019, 01:50 PM Thread Starter
I will be sure to post my results. I remember the Petty DS loop that didn't work with a 4"...couldn't find anything about S&M.
post #4 of 13 (permalink) Old 04-12-2019, 02:07 PM
Gila Hemi's Avatar
The S&M was what I tried to install.
post #5 of 13 (permalink) Old 04-12-2019, 03:10 PM Thread Starter
Well crap...was it auto or manual?
Ah, I just read your sig...manual...nutz! Well nothing left but the crying.
Wait, you have a 2014...I have a 2015, trans mount and driveshaft designs are different...no?
post #6 of 13 (permalink) Old 04-14-2019, 08:41 PM
Gila Hemi's Avatar
I have no idea. Good luck with yours.
post #7 of 13 (permalink) Old 04-17-2019, 05:07 PM Thread Starter
Loop arrived...would it have killed them to send an installed pic?! I can find them for an auto but nothing for a manual. Also, the kit came with various bolts of which 3 are very long...hopefully it is obvious on how to install and where the bolts go.
Ah ok, now I see how it goes.
post #8 of 13 (permalink) Old 04-19-2019, 03:31 PM Thread Starter
Well just tried to install the loop and it will work with a 4" driveshaft. Problem is it will not work with the stainless works mid-pipes as the last set of bends sit about 3" closer to the trans cross-member. The SW system uses reducers that allow you to use 2.5, 2.75 and 3 inch catbacks but because of these reducer they have to bring the last set of bends closer. Bummer!
post #9 of 13 (permalink) Old 04-23-2019, 07:38 PM
boatsnhoses's Avatar
Good to see there's finally something for manuals and 4" shafts (that sounds dirty). Were you able to get more pictures or did your midpipes completely throw off your install?
boatsnhoses is offline
post #10 of 13 (permalink) Old 04-23-2019, 09:17 PM Thread Starter
The bracket that bolts to the trans plate won't clear the SW mid-pipes. Basically if you look at the pic I posted from another person's install, and imagine the mid pipes sit about 3" closer towards the trans plate, you will see there is no way to bolt the bracket to the plate.
